MOKI RADIAL Care and Maintenence
#2679
FL
Hello,
does anyone know how far the carburetor intake end, were one would mount a velocity stack , is from the face of the firewall on a 150/180? In front or behind the FW ? Updraft, down draft, side draft?
Thanks Richard
Thanks Richard
#2682
My Feedback: (9)
Hello Guys
In the next few days will received my moki 250-5
Actually this is the first Radial engine for me ,so I need some advice from you
1- What is the best prop for Break in 2B and 4B prop (Scale) for normal use ?
2- I have Redline and Mobil 2 stroke oil, which one of them is better for this engine and fuel ratio ?
3-For the best way break in Procedure on the bench or from the box to sky?Lol
Thanks for all
Meshari
Thanks for all
Meshari
#2683
My Feedback: (10)
Richard, the carb points straight back towards the firewall on the Moki 150, since I don't know the length of the velocity stack I can't answer the question definitively but I have opened holes in both my firewalls to allow airflow to the carb due to its closeness withe the firewall. I would be very surprised if you did not wind up with the velocity stack going into the firewall.
If needed I can easily measure the carb face to radial mount back face distance on one of my engines that currently dismounted. Since I don't get regular reminder emails of the thread reliably, pls PM me as well so you don't wait forever....
Whit
Whit
#2688
FL
Whit, Thanks for the info. It appears that I'll have to go through the FW if I use a velocity stack. Still on the fence about getting a Moki. Nothing to do with it's maintenance but my limited flying experience.
Regards Richard
Regards Richard
#2692
My Feedback: (221)
"Take offs are optional, landings are mandatory" they say.
#2694
FL
Gary,." However, a prop strike for an engine with a gear box is a very serious event. Much more serious than for a direct drive 2-stroke IMO. You are wise to consider this before you put one of these in the air." Hence my worry. I live over two hundred miles from a field that I can fly from so don't get much stick time. However I do log a bunch of Jet time on the Real Flight stimulator :-) and getting good enough to grease em on most of the time. MOST being the concerned worry. Still it is not like flying the real model.
#2697
My Feedback: (221)
#2699
My Feedback: (9)
Thanks guys for responded
In fact, I got some answers, but I need more information
I read some of words that confused me (Fuel Pump , turbulator )
Do I have to buy any parts that doesn't come with the moki 250?
As for the prop, what about Biela prop?
Any other tips
Any other tips
#2700
My Feedback: (62)
The fuel pump and turbulator are accessories that are made to improve the performance of the 215 and 250 engines. The fuel pump addresses problems with the pulse pump that causes the Walbro carburetor to pump fuel. Some work well, others do not. Also grease can accumulate in the pulse tube to the carb resulting in less fuel being pumped and therefore a lean run causing overheating and loss of power. The turbulator was invented by Detlef Kunkle in Germany who has deep knowledge of the Mokis but was dissatisfied with unequal distribution of fuel to the cylinders. Many of these engines suffer negatively in this regard. The turbulator swirls the fuel in a way to greatly improve engine running qualities, which result in cooler running, more power and more even running at all throttle settings. I have owned 3 moki engines, a 150 (pre 2009), and 2 215's. All three responded greatly to the turbulators use as well as the fuel pump. -Tom
