Reload this Page >
MOKI RADIAL Care and Maintenence
Old 10-15-2014, 07:30 AM
  #3101
Maxam
My Feedback: (62)
Nice plane Israel! Nice to see "Moki's around the world" -Tom
Old 10-17-2014, 06:03 AM
  #3102
msouers
Hey guys,
I have the Moki 250 with the APS fuel pump in my CARF P47. What are you guys doing to winterize the motor. It is starting to get cold here. Thanks for the input.
Mark
Old 10-17-2014, 08:39 AM
  #3103
Greg Wright
Greg Wright's Avatar
If anything i would just take and put some after-run oil thru the intake valves and turn it over a few times to help distribute it thru the motor. That should help to resist any rust from forming in the bearings and the cylinder walls.
Old 10-18-2014, 09:51 AM
  #3104
DavidQ
My Feedback: (12)
DavidQ's Avatar
Biela 32 x 16 Fokke Wulf 190 - 250cc Moki
How is the performance of this prop on the Fokke Wulf
Old 10-18-2014, 12:22 PM
  #3105
Jaketab
Question please,
Has anyone experience with the Zimmerman 2 into 1 exhaust ??? It appears that once the elbows are locked in place to the exit tube that it would be difficult to remove unless the welds are broken. It's advertised to give the Moki a more Harley like sound.
Thanks - Jaketab
Old 10-18-2014, 03:48 PM
  #3106
Maxam
My Feedback: (62)
To Mark and everyone. A very good thing to do to "winterize" and every 30 flights is to do a valve clean with brake cleaner. Black carboney build-up occurs on the valve stems especially the exhaust. What to do....The spray brake cleaner with the straw is aimed directly at the valve spring. The straw is placed in the area beside the rear portion of the rocker angled toward the spring. Spray and you wont believe the amount of black guck coming out. Wait a minute or two and hit it again and yep a ton more guck will come out. If you have an air hose, blow the remainder of the brake cleaner out and VERY IMPORTANT immediately oil everything because the brake cleaner removes all traces of lubricant. The hidden valve stems are especially difficult to oil so use a spray lubricant the foams up thus insuring the stem gets it. This will also insure the valves wont stick either. No one likes to loose pushrods!!! -Tom
Old 10-18-2014, 04:33 PM
  #3107
Jaketab
Tom,
I use this. Good results freeing up stuck valves.
Lubricates as it cleans.
http://seafoamsales.com/deep-creep/
Jaketab
Old 10-19-2014, 11:08 AM
  #3108
Maxam
My Feedback: (62)
Jaketab, I will look this stuff up. Thanks. -Tom
Old 10-19-2014, 12:25 PM
  #3109
flyguy
My Feedback: (20)
I also use Seafoam in all of my Mokis and never lost a pushrod in four years. Jaketab I used the Zimmerman two into one exhaust on my moki 250 on the Jungmeister. I would suggest using Silver solder on the pieces when it is installed, otherwise you`ll never get it on the engine. Rick
Old 10-19-2014, 03:27 PM
  #3110
Jaketab
Rick,
On the Zimmerman exhaust - when you soldered the tubes together, will the exhaust unit slide on and off the collector ring in event the engine needs service or repair ???
Did you solder the unit to the collector ring permanently ???
Does the center tube need additional support or bracing ???
The way the end tubes bend greater then 90 degrees, it appears it may be a permanent installation.
Thanks - Jaketab
Old 10-19-2014, 03:47 PM
  #3111
flyguy
My Feedback: (20)
When you solder the exhaust together it is on the exhaust ring permanently you can not take it off.
Old 10-20-2014, 07:34 AM
  #3112
Jaketab
Question - Has anyone used standard plumbing 3/4" copper tubing for exhaust stacks on the 250 ???
Good or bad results ????
The pipe nicely fits around the exit stacks.
Thanks - Jaketab
Old 10-20-2014, 02:06 PM
  #3113
nine o nine
Thanks - Jaketab
I use the corrugated stainless tubing made for natural gas hookups. Bends are possible with the stuff. Looks cool too! Mitch
Old 10-21-2014, 02:42 AM
  #3114
Primi
Hi Jaketab,
yes I did see below so far worked fine I did some test runs only, hasn't been flown yet but I believe it will stand up as it is silver soldered and the exhaust stack temp was only ~150degC. I used high temp engine paint to paint it and also some exhaust sealant.
Thanks - Jaketab
ID:	2041450   Click image for larger version
Old 10-21-2014, 08:12 AM
  #3115
Maxam
My Feedback: (62)
Jaketab, I use heater hose that is pre-bent. When you go the auto parts store they have all kinds of funny shaped pre formed hose in different diameters. If you ask they will usually let you go back and study them. The weigh almost nothing, the exhaust temps do not bother them at all. You do not even need clamps!!! When you want to remove a cowl you can just pull them off. Another upside is they, being rubber, actually quiet the engine down...or is that bad? Been using them for years. -Tom
Old 10-21-2014, 08:52 AM
  #3116
Jaketab
Mitch,
Went to Lowes. The corrugated tubing for water tank gas line was to small diameter. Possibly I was not looking at the right tubing.
Tom,
The heater hose sounds like a great idea. I was afraid the heat would melt it.
If I had my way, the Moki could stand a bit more rumble.
Primi,
That's exactly what I had in mind. I can use the added weight. Will make some thin cuts in the copper where it clamps on to the exhaust stack so it will clamp tightly.
Permatex Ultra Copper should help seal it and keep it removable.
I'll include a picture when I get the cowl back off.
Thanks - Jaketab
Old 10-21-2014, 10:57 AM
  #3117
Jaketab
This is what I had in mind for the exhaust. It may or may not need a hanger for support?
Jaketab
Old 10-21-2014, 11:19 AM
  #3118
nine o nine
Hi Jaketab, The gas tubing I found was perhaps for a stove installation. The ID was just the right size for a push fit. A hose clamp won't work unless you slit it where the clamp needs to be. I drilled a 1/16th hole directly through the tubing and the exhaust pipe and out the other side. Stainless steel safety wire prevents it from sliding around and a clamp screwed to the firewall maintains whatever angle needs to be made for the exhaust exit. Mitch
Old 10-21-2014, 03:44 PM
  #3119
wphilb
My Feedback: (10)
I used the copper elbows on my 150 and just held them on with 4-40 bolts right through both elbow and collector ring and used nuts and then nylon locknuts to kep them in place. High heat paint blackened them down so not noticeable.
Whit
Old 10-21-2014, 04:51 PM
  #3120
Jaketab
On first go around, I used a worm clamp to hold tubes on the collector ring. It deformed the outlets.
They will distort with little uneven pressure.
The pictured type of clamp worked better and kept from distorting the outlets.
Jaketab
Old 10-22-2014, 01:32 PM
  #3121
flyguy
My Feedback: (20)
Jaketab, I wonder were you buy clamps like that
Old 10-22-2014, 02:55 PM
  #3122
Jaketab
Flyguy,
Got the clamps at McMaster-Carr.
http://www.mcmaster.com/#standard-hose-clamps/=u9n6r0
Jaketab
Old 10-25-2014, 04:47 AM
  #3123
reyn3545
reyn3545's Avatar
Originally Posted by shaked israel
another good fligth with moki 250 at show event in israel. so much Satisfaction and Beauty
https://www.youtube.com/watch?v=90G5icIVwLE
How do you have the smoke set up? I have a basic smoke nipple on mine, but it doesn't seem to produce smoke as nice as yours.
Old 10-25-2014, 04:51 AM
  #3124
reyn3545
reyn3545's Avatar
Question please,
Thanks - Jaketab
I use the 2-into-1 setup on mine... don't really notice the sound being any different than any other Moki. I tried forever to silver solder the pieces together, but I either don't know what I'm doing, or I used the wrong sliver solder, so I gave up and JB-Welded them together... works great. You can get the pipes off, just break the JB-weld, then slide them off of one side, pretty easy actually. I do like the finished pipe sticking out of the cowl instead of a piece of flex pipe.
Old 10-31-2014, 09:07 PM
  #3125
badgerord
Hi All,
Does the Moki have needle bearings on the connecting rods where they fit on to the crank? or just bushings?
Marty
