Ziroli AT6 rudder help - pull-pull or pushrod??
My Feedback: (10)
Hi, working on the Ziroli AT6, how are you guys actuating your rudder, pull -pull or with a push rod and what seems to be working the best?
I'm intend to mount all my servos just ahead of the C of G to less any nose weight required[8D], I am using a G62.
thanks in advance - ken k.
RE: Ziroli AT6 rudder help - pull-pull or pushrod??
Hi Kenair,
I'm finishing up a Byron T-6 , I had it set up for a carbon fiber push rod , I like the ones Central Hobbies sells ,
although , i just removed it , I didnt like the fact that nearly five inches of rod was visable outside the fuse,
so i'm going back to the Pull Pull set up, I will still be using the Carbon fiber rods for the elevators & Tailwheel.
In the photos , you can see where the pushrod exit was for the rudder , also , the two center servo locations will be for Rudder & tailwheel.
Hope this helps, hope to have mine painted in the next few weeks , 51-D GUY .
