FPE 5.8 three blade prop?
RE: FPE 5.8 three blade prop?
ORIGINAL: luckyb001
Peter I have two Brison 5.8s on my Tiger cat and I run 22 X12 wood three blade. They turn 6600 rpm. Good luck. Mike
And they're made by ??????????????????
ORIGINAL: luckyb001
My Feedback: (28)
ORIGINAL: Doolittleraider
I have a FPE 5.8 thats going in a ziroli corsair. What three balded prop should I use?
Peter
Peter
Heres a 44 lb Ziroli Hellcat....
My Feedback: (72)
Hey Mike,
I pulled the spark plug which is brand new no carbon built up.... it was clean. I cleaned the magnetic sensors on the fly wheel with steel wool and alcohol to get the rust off. I then called Dick Bennett at bennett built and he told me its sounds like a misfire in the ignition and since it was one time and not a chain of them all at once not to worry about it. He also suggested 3 and 1 oil on the sensors to prevent future rust built up. I am not saying it was that, and neither did he but, he said it wasn't a bad idea to clean them anyway. He has new magneto ignitions for 30 dollars but he told me that the old one should be fine and he wouldn't replace so I didn't. I may make it hair leaner or richer depending on how it does next time........Overall the engine is doing way better than when I first got the plane. It was sagging and droping power and hard to tune. I have put a new fuel tank, all new lines and did the brass tube on the carb trick. Since those modifications.....its been pretty solid aside from what you saw. On another note that engine is really old. I bought this corsair a while back
http://www.rcuniverse.com/forum/m_52...tm.htm#5202272
without the saito radial and I am now finally getting around to put FPE 5.8 in it. I chose the FPE because Greg had one and it was super reliable and the weight is dead on to the saito radial...
I am a die hard corsair fan especially the ziroli. In addition to those two I am building another z-corsair now (here is the wing). I have a moki 150 to put it. I ordered mine with Greg's from troybuilt. Its because on me having shipped to my dad in NYC he saved the tax! Some graditude, he's still a jerky ....lol...
That should update you!
All the best,
Peter
All the best,
Peter
