Reload this Page >
TFGE F4U Corsair 60 Kit Build
Old 02-27-2012, 08:21 AM
  #351
pilotx
Default RE: TFGE F4U Corsair 60 Kit Build
Hello well its been a while but i can say its almost done, here is some pictures of the painted plane i still plan on adding some numbers and stencils yet to be finished and more weathering this is my first ever sport scale fiberglassed and painted airplane,Top Flite 60 size Kit .
ID:	1732886   Click image for larger version
ID:	1732887   Click image for larger version
ID:	1732888   Click image for larger version
ID:	1732889   Click image for larger version
ID:	1732890   Click image for larger version
ID:	1732891   Click image for larger version
Old 02-27-2012, 09:00 AM
  #352
glazier808
glazier808's Avatar
Very nicely done!
Casey
Old 02-27-2012, 09:19 AM
  #353
RCGuy41
Tracey,
Very nice job, have been able to maiden her?
Old 02-27-2012, 09:36 AM
  #354
pilotx
no maiden yet, just finishing the paint. last summer i had health issues and so no work in the shop for 7 months but back at it now. I
hope to maiden in the spring. still more details to finish on this one, and a Giant TF P-51 just about ready for paint, that i would like to have finished for Fond du lac, WI Warbirds & Classics in late augeust...ill post finished pictures and maiden shots as they happen.
Old 02-27-2012, 11:33 AM
  #355
drube
drube's Avatar
Looks great! Did you get a final weight on it yet?
Old 02-27-2012, 11:35 AM
  #356
drube
drube's Avatar
Oh... Cool pilot too!
Old 02-27-2012, 03:10 PM
  #357
pilotx
No total weight yet but before painting started I had weighed the plane with everything installed and it was just under 10lbs I hope, I didn't add much to it at all. fingers crossed that it is around 10.5lbs..
Old 03-11-2012, 08:07 PM
  #358
pilotx
well I finally got to weight the Corsair today with out clear coat it is 10lbs 10oz. I wish I could say that I wasn't concerned about weight but at this point all I can do is Fly it, it should be interesting.
Old 03-11-2012, 09:50 PM
  #359
Chad Veich
My Feedback: (60)
10lbs, 10oz is a very reasonable weight for this airplane and it should perform just fine.
Old 03-12-2012, 03:05 AM
  #360
CorsairJock
My Feedback: (90)
CorsairJock's Avatar
WOW!!! Looks GREAT!
And as Chad said: 10 1/2 lbs should be no problem.
It's the 12 pound ones that I would be concerned about (they fly, but many times have landing gear problems)
Old 12-30-2013, 10:00 AM
  #361
dreddbatfan
Hi Brad,
I'm new to the forum and I saw your post for the Top Flite F4U Corsair build.I plan on building this kit as soon as I get all the necessary parts.I have a question about your build.Which propellar did you use?Which robart hinge pins did you use for this build?Which tail wheel did you use from Du-Bro(they have several kinds)?I'm sure I'll have more questions as I go along,so I hope I don't become a pest asking so many questions.Thanks for any help that you can give me,I hope you and your family have A Merry Christmas and I hope to hear from you soon.
Danny Redd
(dreddbatfan)
Hi Firepower R/C,
I see on RCGuy post for the Top Flite F4U Corsair that you make tanks and bomb kits for this airplane.I was wondering how much you charge for this kit?I'm a new member and I plan on starting this kit as soon as I get all the parts I need.Thanks for your help and I hope to hear from you soon.
Old 02-11-2014, 09:11 PM
  #362
rfmillte
Hi Danny; My name is Tim. I also have read all of this thread on the Corsair Build, as I am building one also. I was hoping to see someone who has filmed his instead of glassing it. But apparently I am the only one doing it with flat 21st Century Insignia Blue. I have completed all but the covering. I will be using an OS 91 FS in mine, mounted inverted. There are a lot of good ideas on this thread. If you have not read the entire thread I encourage you to do so. I used Robart #308 hinge points. I also used the Robart #615 retracts. I will have an onboard ignition system. Good Luck with the build. Tim
