Knowledge Quiz for Warbird wiz
#3927
RE: Knowledge Quiz for Warbird wiz
No correct answers thus far. And, I think you guys must be 'way overthinking this one. When some one gets it, the rest of you are going to say "Oh; of course!". Thanks; Ernie P.
Background: Aircraft designers tend to re-use successful designs as long as the resultant aircraft perform well. This question is about a designer who did exactly that, and the great warbirds he produced.
Question: What four warplanes do I describe?
Note: To be fair to all participants, all four warplanes must be included in the same answer. Answers which include less than four named aircraft will be ignored.
Clues:
(1) The four are consecutive designs by the same aircraft factory.
(2) Three of the four are well known aircraft; the other perhaps not so well known, except to enthusiasts.
(3) Three shared the same fuselage.
(4) Three shared the same wing design.
(5) One is among the most recognizable designs in history.
(6) One is the most successful design of its time.
Clues:
#3929
ORIGINAL: uncljoe
just a SWAG...
Clarence ''kelly'' Johnson Lockheed's Hudson.Ventura,Harpoon,& Lexington
Semper Fi
just a SWAG...
Semper Fi
No, sorry. This should help. Thanks; Ernie P.
Clues:
(7) Three performed well with below par engines, because they were light.
#3931
ORIGINAL: SimonCraig1
Last post of the year! again if I am right, I'll throw the question open...
Nieuport 10, 11, 17 and 24.
All the best for 2011!
Clues:
(8) One was relatively heavy, but had a great engine.
#3932
Last clue for the evening. Thanks; Ernie P.
Clues:
(9) Three were rotary engined.
Clues:
#3935
No one is getting closer. One hint: I said "rotary", not "radial". This should be a lot simpler than you guys are making it out to be. Thanks; Ernie P.
Clues:
(10) One had an inline engine.
Clues:
#3936
ORIGINAL: Ernie P.
You are incorrect, but you are thinking correctly. Thanks; Ernie P.
You could add the Lancastrian and Shackleton to that list!
Taking a different tack and a cue from Ernie's response, how about the Sopwith Pup, Triplane, Camel and Snipe? The triplane of course being the less well known, having been overshadowed by it's imitator, the Fokker DRI.
#3937
Next clue. Thanks; Ernie P.
Clues:
(11) One was a backup; in case the next one didn’t work out.
Clues:
#3940
Couldn't resist one more go....
Fokker DRI, DVI, DVII and EV/DRIII
Happy new year everyone!
Clues:
Fokker DR-1, D-6, D-7 and D-8.
The D-6 isn't so well known as the others.
The DR-1, D-6 and D-8.
The D-6, D-7 and D-8.
The Red Barons Triplane.
The D-7.
The D-7.
The D-7.
The D-6; in case the D-7 didn't work out.
(12) They all served in the same war.
WWI.
(13) One scored the last victory in one war; and the first victory of the next.
The D-8 scored the last victory of WWI and the first of the Russo-Polish War.
(14) Three were flown by notable aces.
Voss, Udet and Lowenhardt.
(15) One was flown by the best.
Richthofen.
(16) One was a monoplane; two were biplanes; and one was…
Fokker Dr-1, D-6, D-7 and D-8. Dr-1, D-6 and D-8 shared same fuselage. D-6, D-7 and D-8 shared same wing.
#3942
ORIGINAL: a65l
Gotta disagree, I think the D8 wing design was different, the D6 and D7 were fabric covered trusses, the D8 was a plywood skinned semi monocoque, but they were all internally braced.
To me, the amazing thing was the performance Fokker could get using the puny 110 HP engines. Thanks; Ernie P.
#3943
Interesting! The Fokker D I thru DV were developed from the Eindekker. The D-I had an inline engine. Most had wing warping and some had versions of aileron and wing warp. Mssr.A. Fokker definitely designed and built aircraft on a 'continuum'.
#3944
Okay; it looks as though SimonCraig1 is out of touch. (He did indicate previously he would throw the next question to the floor if he was correct) I'm calling time on him and opening the floor to anyone who would like to ask the first question of 2011. If no one posts in the next three or four hours, I'll post a new one myself. Any takers? Thanks; Ernie P.
#3945
ORIGINAL: ARUP
#3946
ORIGINAL: Ernie P.
Background: This has always been kind of an interesting aircraft to me.
Question: What seminal prototype aircraft do I describe?
Clues:
(1) It was, essentially, the front half of a production fighter; although…
(2) … it was originally intended to be a testbed for a civilian airliner.
#3947
Another clue for this morning. Thanks; Ernie P.
Clues:
(3) All three prototypes were destroyed in crashes, and all three resulted in the death of the pilot.
Clues:
#3948
And another clue. Thanks; Ernie P.
Clues:
(4) One of the pilots was the son of the company owner and chief designer.
Clues:
#3949
Dehavilland DH-108?
It utilised the forward section of a Vampire and a new wing section for testing a tailess configuration for the Dehavilland Comet.
#3950
ORIGINAL: GraemeEllis
Dehavilland DH-108?
Dehavilland DH-108?
That's the plane; and you are up, Sir. A really interesting aircraft; and very influential in its time. Thanks; Ernie P.
Clues:
(5) The first to crash had set an unofficial speed record; and was preparing to attempt an official run.
(6) The plane bore a close resembelance to a German WWII aircraft.
(7) Not the first jet aircraft to exceed the speed of sound, but probably the second.
(8) A few years after the first crash, the third aircraft set a new closed course speed record.
(8) Established three important “firsts” for British aircraft.
Answer: de Haviland DH108
De Havilland Chief Test Pilot Geoffrey de Havilland Jr., son of de Havilland company owner-designer Geoffrey de Havilland, died in test crash.
In 1949, VW120 put on an aerial display at Farnborough and scored third place in the Society of British Aircraft Constructors Challenge Trophy Air Race before being turned over to the Ministry of Supply and test flown at RAE Farnborough. It was destroyed on 15 February 1950 in a fatal crash near Brickhill, Buckinghamshire, killing its test pilot, Squadron Leader Stuart Muller-Rowland. Accident investigation pointed to a faulty oxygen system that incapacitated the pilot.
Finally, on 1 May 1950 during low-speed sideslip and stall tests the first prototype, TG283, was lost in a crash at Hartley Wintney killing the pilot Sqn Ldr George E.C. Genders AFC DFM, when, after abandoning the aircraft at low altitude in an inverted spin, his parachute failed to open in time. In all, 480 flights had been made by the three Swallows.
DH108 Research Aircraft
The Vampire fuselage was incorporated into the DH108 swept-wing research aircraft. This aircraft had wings swept at 43 to 45 degrees, a swept fin (vertical stabilizer) and no tail (horizontal stabilizer). It was the first British swept-wing aircraft and first flew on 15. May 1946
It was actually built to investigate the nature of swept wings. Among other things, it was intended to provide data for the Comet jet airliner and the DH110.
Three were built
