Knowledge Quiz for Warbird wiz
#8401
RE: Knowledge Quiz for Warbird wiz
Just got home from work. Good thing I recently stumbled upon a warbird that I'd never heard of before....
What aircraft?
1) it is a low wing monoplane with fixed landing gear
2) production aircraft used a 115hp engine
3) it required precise piloting
What aircraft?
#8403
ORIGINAL: perttime
What aircraft?
What aircraft?
Me, me, me.... Wait, I'm typing with one (and that the left) hand for a while. Maybe I'd best lay back for a while. It was a cute little plane, though. Thanks; Ernie P.
#8404
PT-19 is NOT what I was thinking of...
What aircraft?
4) in addition to its primary role, it was used as reconnaissance and improvised ground attack plane
What aircraft?
#8406
noo...
What aircraft?
5) it's engine was a 5 cylinder radial. In addition to the 115hp engine, a 150hp variant was also used.
What aircraft?
#8407
What aircraft?
6) the first prototype flew in 1936
#8408
What aircraft?
7) production ended in 1940
8) well over 1000 were built
#8409
What aircraft?
9) it was designed - and mainly used - as a trainer
#8413
ORIGINAL: Top_Gunn
Yak UT-1?
Yak UT-1?
http://en.wikipedia.org/wiki/Yakovlev_UT-1
http://www.aviastar.org/air/russia/yak_ut-1.php
Wikipedia photo of a captured one:
Your turn, Top_Gunn.
#8421
Name the plane.
1. Ground attack.
2. Two engines.
3. Piston engines.
4. Only prototypes built.
5. Although the prototypes performed as well as or even better than expected, the order was cancelled. One reason was that the engines were used in another aircraft that was considered more important.
1. Ground attack.
2. Two engines.
3. Piston engines.
#8424
Wow. I didn't expect to win this quickly!
OK, here's a weird one.
1. Twin engined monoplane.
2. In the 1930s, one characteristic of this aircraft's deployment surpassed all other aircraft of its type.
#8425
3. It was nicknamed by its crews after a certain dinosaur.
