Reload this Page >
Knowledge Quiz for Warbird wiz
Old 10-23-2015, 03:45 AM
  #12101
Andy_S
Not the Sturmovik. Whereas assembly ships were painted for friendly bombers to form up behind them while leaving on a mission, this plane was a member of a squadron tasked with escorting aircraft both leaving and returning to base. While escorting a certain type of plane close to base, it was painted with a high visibility livery to prevent attacks from friendly ground forces.
Last edited by Andy_S; 10-23-2015 at 05:18 AM. Reason: Both leaving and returning. livery.
Old 10-23-2015, 08:13 AM
  #12102
Andy_S
1. Please name the specific WWII "Circus" aircraft upon which the phrase "In service for the national rail" was painted (translation altered slightly to obscure the clue).
2. Whereas assembly ships were painted for friendly bombers to form up behind them while leaving on a mission, this plane was a member of a squadron tasked with escorting a certain type of aircraft both leaving and returning to base. In order to perform its mission, it was partially painted with in high visibility livery to prevent attacks from friendly ground forces.
3. This was the Commander of the unit to which the Warbird was assigned.
Old 10-23-2015, 10:23 AM
  #12103
perttime
perttime's Avatar
Oh, THAT Circus...
Do you want the tactical code and the pilot's name?
(I just had a turn, so think I'll sit this out)
Old 10-23-2015, 10:32 AM
  #12104
castlebravo
Hs 123....?
CB
Old 10-23-2015, 11:11 AM
  #12105
Andy_S
Sorry CB, no.
Old 10-23-2015, 11:13 AM
  #12106
castlebravo
cb
Old 10-23-2015, 11:14 AM
  #12107
Andy_S
Originally Posted by perttime
Oh, THAT Circus...
I don't know, if it takes too long, I might ask you for your answer. I think I came up with kind of an overly detailed question.
Old 10-23-2015, 11:19 AM
  #12108
Andy_S
2. Whereas assembly ships were painted for friendly bombers to form up behind them while leaving on a mission, this plane was a member of a squadron tasked with escorting a certain type of aircraft both leaving and returning to base. In order to perform its mission, it was partially painted in a high visibility livery to prevent attacks from friendly ground forces.
4. The unit the Warbird belonged to was known as Die Würger-Staffel (Butcherbird Squadron).
Old 10-23-2015, 11:27 AM
  #12109
castlebravo
Jv 44.....me-262
cb
Old 10-23-2015, 11:29 AM
  #12110
Andy_S
Ha… You're getting warmer! Look at all the clues.
Old 10-23-2015, 11:33 AM
  #12111
David Johnston
David Johnston's Avatar
Due to prior commitments - I cannot participate with a new quiz question - however, here is a clue for others to follow up on!
Old 10-23-2015, 11:34 AM
  #12112
castlebravo
D'oh!
alright...left field guess....I know he flew Gloster Meteors for Argentena.....
CB
Old 10-23-2015, 11:37 AM
  #12113
castlebravo
Well....I didn't think it would be as obvious as a FW 190....I swear...I typed in the "train Station" phrase all over the place....
CB
Old 10-23-2015, 11:38 AM
  #12114
MJD
MJD's Avatar
Waldermar Wubke - Red 3 / Rot 3
FW190 D9
Old 10-23-2015, 11:50 AM
  #12115
Andy_S
MJD, you win!
The FW 190 D9 known as Red 3, flown by Waldemar Wübke served in the Galland Zirkus, or Galland's Circus escorting Me 262s to and from base. Notice the distinct Red/White undersides used to identify the aircraft as friendly to ground forces.
CB, sorry I made the phrase "Im Auftrage der Reichsbahn" a little too ungoogle-able!
ID:	2127221   Click image for larger version
Old 10-23-2015, 11:56 AM
  #12116
castlebravo
No worries mate.....at least I learned a bit about "Dolfo"
CB
Old 10-23-2015, 11:57 AM
  #12117
Sekhet
Sekhet's Avatar
MJD, you win!
The FW 190 D9 known as Red 3, flown by Walter Wübke served in the Galland Zirkus, or Galland's Circus escorting Me 262s to and from base. Notice the distinct Red/White undersides used to identify the aircraft as friendly to ground forces.
proper translation is "In orders of the Reich Railway"
Old 10-23-2015, 12:16 PM
  #12118
Andy_S
Yes, the word Reich was omitted to avoid giving away the nation of origin.
Old 10-23-2015, 12:52 PM
  #12119
Sekhet
Sekhet's Avatar
Well played!
Old 10-23-2015, 01:06 PM
  #12120
Hydro Junkie
Hydro Junkie's Avatar
You didn't give it away until you included that picture of Adolf Galland. His uniform, with the German black cross with swords and the nazi pin on the right side gave away the fact he was from Germany in WWII. I was thinking "Genda's Flying Circus" over Japan in the 1930s myself:
https://forum.warthunder.com/index.p...-and-the-a2n1/
Old 10-23-2015, 04:06 PM
  #12121
MJD
MJD's Avatar
I found a list of pilots in JV 44. OK, now I gotta come up with a Q..
Old 10-26-2015, 02:02 AM
  #12122
Ernie P.
MJD; please either post your question or declare the floor open to whoever first posts a question. Thanks; Ernie P.
Old 10-26-2015, 02:29 PM
  #12123
Ernie P.
All; the floor is open to the first person to post a question. If no one posts anything by tomorrow, I will do so. Thanks; Ernie P.
Old 10-26-2015, 02:32 PM
  #12124
castlebravo
I got one.....
The AC in question was a modification to a well known airframe making it an entirely different airplane.
CB
Old 10-26-2015, 07:04 PM
  #12125
Ernie P.
Originally Posted by castlebravo
I got one.....
CB
How about the TA 152? Thanks; Ernie P.
The Focke-Wulf Ta 152 was a World War II German high-altitude fighter-interceptor designed by Kurt Tank and produced by Focke-Wulf. The Ta 152 was a development of the Focke-Wulf Fw 190 aircraft. It was intended to be made in at least three versions—the Ta 152H Höhenjäger ("high-altitude fighter"), the Ta 152C designed for medium-altitude operations and ground-attack using a different engine and smaller wing, and the Ta 152E fighter-reconnaissance aircraft with the engine of the H model and the wing of the C model.
The first Ta 152H entered service with the Luftwaffe in January 1945. While total production—including prototypes and pre-production aircraft—has been incorrectly estimated in one source at approximately 220 units, only some 43 production aircraft were ever delivered before the end of the European conflict. These were too few to allow the Ta 152 to make a significant impact on the air war.
Due to the difficulties German interceptors were having when battling American heavy bombers at altitudes above 20,000 feet, and in light of rumors of new B-29 bombers with better altitude capabilities, the Reichsluftfahrtministerium (German Air Ministry, or "RLM") requested proposals from both Focke-Wulf and Messerschmitt for a high-altitude interceptor. Messerschmitt answered with the Bf 109H, and Focke-Wulf with the Fw 190 Raffat-1, or Ra-1 (fighter), Ra-2 (high altitude fighter) and Ra-3 (ground-attack aircraft).
These designs developed into the Fw 190 V20 (Ta 152A), V30 (Ta 152H) and V21 (Ta 152B) prototypes, all based on the then successful Fw 190 D-9 but with varying degrees of improvement. The V20 used the same Jumo 213E engine as the Fw 190 D-9, while the V21 used the DB 603E. Neither of these offered any significant improvement over the Fw 190 D-9, and so further development of the Ta 152A and B was cancelled. The V21 airframe, however, was further modified as the V21/U1 and became the prototype for the Ta 152C.
Kurt Tank originally designed the Ta 152 using the 44.52 litre displacement Daimler-Benz DB 603 engine as it offered better high-altitude performance and also a greater developmental potential. The DB 603 had been used in the Fw 190C with many problems and was considered too difficult to implement in the Ta 152 by RLM officials. With this in mind, Tank focused his efforts on the Junkers Jumo 213E as the Ta 152H's power plant. However, he insisted that the Daimler-Benz DB 603 be retained for the Ta 152C versions and as an option for later versions of the Ta 152H.
The Ta 152's fuselage was an extended version of the Fw 190 D-9 fuselage with wider-chord fixed vertical tail surfaces (especially the top half), and hydraulic rather than electrically-controlled undercarriage and flaps. Due to the changes in the center of gravity and overall balance, the nose was also lengthened. Wingspan was changed from the FW 190's 10.51 m (34 ft 5 in) for both versions. The H had a span of 14.44 m (48 ft 6 in) and the C a wingspan of 11.00 m (36 ft 1 in).
The Ta 152 also featured the FuG 16ZY and FuG 25a radio equipment (some aircraft were issued with FuG 125 Hermine D/F for navigation and blind landing, LGW-Siemens K 23 autopilot, and a heated armorglass windscreen for bad-weather operations).
