Reload this Page >
Knowledge Quiz for Warbird wiz
Old 10-14-2015, 06:20 PM
  #12051
MJD
MJD's Avatar
This aircraft was developed just prior to WWII. The winning aircraft is well known.
9. Not a DH-2. Too many booms. However this one had problems with the one it did have, and problems with the tailgroup thusly attached.
Old 10-15-2015, 06:22 AM
  #12052
SimonCraig1
Blohm and Voss bv 141?
Old 10-15-2015, 07:09 AM
  #12053
MJD
MJD's Avatar
Sorry, not the BV-141. But you're much closer now.. it ain't a de Havilland, or Stinson, or American Champion, or Interstate Cadet, or..
Recap, more clues:
1. Pusher, single engine, single boom, high wing braced monoplane
2. Did not go into production, was competing against two other candidates for an observation role
3. If a bunch had been made then scrapped, the cockpits would have likely showed up as urban backyard greenhouses.
4. Inverted V-8 power
5. Tandem seating for pilot and observer
Old 10-15-2015, 07:46 AM
  #12054
SimonCraig1
Seibel Si 201?
Old 10-15-2015, 08:42 AM
  #12055
MJD
MJD's Avatar
Originally Posted by SimonCraig1
Seibel Si 201?
You got it! Love that canopy. These markings would look great on an ultralight.
Genuine Wiki cut 'n' paste:
Design and development
Designed to meet a requirement for an air observation post and army co-operation aircraft the Si 201 first flew in 1938. Evaluated against the Fieseler Fi 156and Messerschmitt Bf 163*. The Fi 156 was ordered into production and only the two prototype 201s were built.
The Si 201 was a high-wing braced monoplane with a tail-wheel landing gear. Powered by an Argus As 10C mounted above the wing and driving a pusher propeller.[SUP][1][/SUP] It had a boxy, fully glazed forward fuselage with room for a pilot and observer in tandem.
Specifications
Data from Warplanes of the Third Reich
General characteristics
  • Crew: 2
  • Length: 10.401 m (34 ft 1 [SUP]1[/SUP]⁄[SUB]2[/SUB] in)
  • Wingspan: 14.002 m (45 ft 11 [SUP]1[/SUP]⁄[SUB]4[/SUB] in)
  • Height: 3.397 m (11 ft 1 [SUP]3[/SUP]⁄[SUB]4[/SUB] in)
  • Wing area: 31.00 m[SUP]2[/SUP] (333.7 sq ft)
  • Empty weight: 1,120 kg (2,469 lb)
  • Gross weight: 1,440 kg (3,175 lb)
  • Powerplant: 1 Χ Argus As 10C air-cooled inverted V8 engine, 180 kW (240 hp)
Performance
  • Maximum speed: 185 km/h; 100 kn (115 mph) at sea level
  • Cruise speed: 150 km/h; 81 kn (93 mph)
  • Range: 451 km; 243 nmi (280 mi)
  • Service ceiling: 5,502 m (18,050 ft)
  • Rate of climb: 4.20 m/s (827 ft/min)
  • Time to altitude: 4.5 min to 1,000 m (3,300 ft)
* also issued to Me-163
Old 10-15-2015, 08:45 AM
  #12056
MJD
MJD's Avatar
p.s. you'll note that the Wiki picture is of a scale model..
The Siebel Si 201 was designed to meet a specification calling for an air observation post and army co-operation aircraft placing emphasis on STOL and slow-flying performance and all-round visibility. The specification was issued early in 1937, by which time the Luftwaffe was already evaluating the Fieseler Fi 156 Storch, and the Bayerische Flugzeugwerke produced a competitive design, the Bf 163, which, built by the "Weser" Flugzeugbau, flew in 1938 as did also the Si 201. Whereas the Bf 163 closely followed the Fi 156 concept, the Si 201 was unorthodox in that its Argus As 10 eight-cylinder inverted-vee aircooled engine was mounted above the wing as a pusher, driving a four-bladed fixed-pitch airscrew which rotated above a slim, circular-section tailboom. High-lift devices included full-span automatic leading-edge slots, a fixed slot at one-third chord on the outboard wing sections, and four-section Fowlertype flaps which occupied almost the entire trailing edges, the outboard sections serving as ailerons.
The fuselage was of welded steel-tube construction with metal skinning and the plywood-covered wing was of wood. The pilot and observer were seated in tandem in the extensively-glazed forward fuselage, the observer being positioned ahead of the pilot with his seat offset to starboard. The first of two prototypes of the Si 201 flew during the early summer of 1938, revealed excellent short take-off and landing characteristics, and was found to possess acceptable slow-flying characteristics closely comparable with those of the Storch, but at the upper end of the speed scale tail flutter proved troublesome. Considerable effort was expended in damping out oscillation in the tailboom which developed under certain flight conditions, and the second prototype, which featured some simplification of the high-lift devices, was flown with a somewhat sturdier tailboom. The most serious shortcoming of the Si 201 proved to be the extremely limited cg travel permitted by its configuration, and when Siebel was ordered to abandon further development of the aircraft the problem of tail flutter remained largely unsolved.
Old 10-15-2015, 10:15 AM
  #12057
SimonCraig1
Okay, let's see how long this one lasts....
I’m looking for a rather obscure aircraft:
1. Unfortunately for the country developing the plane, events overtook its development and only one prototype was produced and test flown.
2. Test flights of the prototype showed it would have made a good match against it contemporaries.
Old 10-15-2015, 02:13 PM
  #12058
SimonCraig1
2. Test flights of the prototype showed it would have made a good match against its contemporaries.
3. Power was provided by the type of engine used on a much better known, long established aircraft.
Old 10-15-2015, 08:37 PM
  #12059
Hydro Junkie
Hydro Junkie's Avatar
Xp-42
Old 10-16-2015, 06:23 AM
  #12060
MJD
MJD's Avatar
Martin Baker MB-5?
Old 10-16-2015, 06:57 AM
  #12061
SimonCraig1
Nice tries both of you but not the correct answer...
4. For simplification it adopted everything in front of the firewall from the better known design including the armament.
Old 10-16-2015, 07:18 AM
  #12062
Hydro Junkie
Chain Lightning
Old 10-16-2015, 08:34 AM
  #12063
SimonCraig1
another guess another clue
5. The better known design was supplied by an ally country.
Old 10-16-2015, 02:11 PM
  #12064
SimonCraig1
not sure if I'll have a chance to post again today so here's another clue, this one should help a lot...
6. Because of the country’s natural resources and general shortages of metals an unusual but not unique material for the time was used where ever practical in the airframe.
Old 10-17-2015, 01:03 AM
  #12065
perttime
perttime's Avatar
VL Pyφrremyrsky?
https://en.wikipedia.org/wiki/VL_Pyφrremyrsky
Old 10-18-2015, 07:51 AM
  #12066
SimonCraig1
Spot on Perttime! (and sorry for the delay in confirmation)
Old 10-19-2015, 07:27 AM
  #12067
perttime
perttime's Avatar
I' ve seen the Pyφrremyrsky prototype several times, so it is no wonder bells started ringing.
"The Pyφrremyrsky design was considered quite successful. It could outclimb the Bf 109G-6 and it was very manoeuvrable. The only major problem with the design was found to be the low-quality glue used in the joints.
The aircraft was still in the prototype stage when the war ended and this also meant that the funds allocated for the project decreased.
http://ww.airliners.net/photo/1164417/
New question in a moment...
Old 10-19-2015, 07:40 AM
  #12068
perttime
perttime's Avatar
What warbird?
1) Its rate of climb and high service ceiling were its most notable features.
2) Apparently, landings could be tricky.
Old 10-19-2015, 12:07 PM
  #12069
Hydro Junkie
P-38 Lightning
Old 10-19-2015, 12:21 PM
  #12070
castlebravo
I'm goin U-2/TR-1
CB
Old 10-19-2015, 08:52 PM
  #12071
perttime
perttime's Avatar
Not quite what I was thinking of.
What warbird?
3) At a quick look, it appears very similar to the preceding model, but has different wings and some other improved details.
Old 10-19-2015, 09:41 PM
  #12072
rcguy59
My Feedback: (8)
rcguy59's Avatar
P-47n?
Old 10-20-2015, 05:21 AM
  #12073
perttime
perttime's Avatar
Not P-47N either.
What warbird?
4) After the initial order, several more followed, as it became clear how good it was.
Old 10-20-2015, 07:43 AM
  #12074
Hydro Junkie
P-51B and C or the Spitfire Mk PRXIX
Old 10-20-2015, 08:26 AM
  #12075
perttime
perttime's Avatar
Not a P-51 or Spitfire
What warbird?
5) The company that built it ceased aircraft production after the peace treaty.
