Reload this Page >
Knowledge Quiz for Warbird wiz
Old 05-31-2016, 07:34 PM
  #13101
Ernie P.
Originally Posted by JohnnyS
AANNDD we have a WINNER!
Well done sir! I was trying to lead you towards a rotary wing answer to draw out the quiz, but YOU saw through it. Well done and please go ahead with your quiz!
JohnnyS; thanks for the kind words. However, trying to mislead me is a waste of time and effort. My brain doesn't work quickly enough to be misdirected. I have a question ready, but want to think about how to direct the clues. Otherwise, it will be a very short session. I'll post my first clue in the morning. Thanks; Ernie P.
Old 06-01-2016, 01:43 AM
  #13102
Ernie P.
This early warbird made quite a name for itself, although it has been largely forgotten. Thanks; Ernie P.
Question: What early warbird do I describe?
Clues:
1.This aircraft was considered to be quite fast in its day.
2.It was also considered to be quite dangerous by its opponents.
Old 06-01-2016, 02:20 AM
  #13103
Hydro Junkie
Hydro Junkie's Avatar
You do realize those three clues leave a lot of room for interpretation, don't you?
Old 06-01-2016, 10:48 AM
  #13104
Ernie P.
Actually, yes; but, maybe this afternoon clue will narrow things down a bit. Thanks; Ernie P.
Clues:
3.This aircraft was armed with a machine gun; which was pretty unusual at the time,and about all that was required to be considered very dangerous.
Last edited by Ernie P.; 06-01-2016 at 10:50 AM. Reason: adding spaces that were deleted.
Old 06-01-2016, 01:26 PM
  #13105
Ernie P.
Evening clue. Thanks; Ernie P.
Clues:
4.The observer sat in the front; the pilot to his rear.
Old 06-02-2016, 01:45 AM
  #13106
Ernie P.
Morning clue. Thanks; Ernie P.
Clues:
5.It was a pusher aircraft; which left the observer/gunner free to utilize the still rare, and still more dangerous, machine gun in an offensive role.
Old 06-02-2016, 10:19 AM
  #13107
Ernie P.
Afternoon clue. Thanks; Ernie P.
Clues:
1.Thisaircraft was considered to be quite fast in its day.
2.Itwas also considered to be quite dangerous by its opponents.
3.Thisaircraft was armed with a machine gun; which was pretty unusual at the time,and about all that was required to be considered very dangerous.
4.Theobserver sat in the front; the pilot to his rear.
5.Itwas a pusher aircraft; which left the observer/gunner free to utilize the stillrare, and still more dangerous, machine gun in an offensive role.
6.Theengine was considered quite powerful for its day, which contributed to therather high speed of which it was capable.
Old 06-02-2016, 01:48 PM
  #13108
Ernie P.
Evening clue. You will notice the first two words of each clue are not separated by a space. There is a space between the two words in the document from which I copy the clues; and I see a space when I paste the clues. For some reason, the spaces are removed after I paste the clues. When I try to edit the post, it takes a very long time to do so, and sometimes I can't edit the post at all. Sorry for the inconvenience. Thanks; Ernie P.
Clues:
7.Theengine was first introduced in 1914.
Old 06-02-2016, 01:52 PM
  #13109
Ernie P.
Clues:
6.The engine was considered quite powerful for its day, which contributed to therather high speed of which it was capable.
7.The engine was first introduced in 1914.
Old 06-02-2016, 03:32 PM
  #13110
sjhanc
sjhanc's Avatar
Dh.2
Old 06-02-2016, 06:41 PM
  #13111
Ernie P.
Originally Posted by sjhanc
Dh.2
Welcome, sjhanc; and have fun with us. No, not the single seat Dh2. This was a two seater. However, to reward your participation, here is a bonus clue. Thanks; Ernie P.
Clues:
8.A single float plane version was produced.
Old 06-02-2016, 08:35 PM
  #13112
sjhanc
sjhanc's Avatar
Sorry, F.E.2
Old 06-03-2016, 01:41 AM
  #13113
Ernie P.
Sorry, F.E.2
No, not the F.E. 2; although the F.E. 2 and this plane did share some common characteristics. Perhaps this morning clue will narrow your search. Thanks; Ernie P.
Clues:
9.This aircraft had, unfortunately, a rather short service life.
Old 06-03-2016, 08:37 AM
  #13114
zippome
zippome's Avatar
How about the AGO C II ?
Old 06-03-2016, 11:37 AM
  #13115
Ernie P.
No, Zip; not the AGO CII. For one thing, there were only around a dozen of the AGO CII's produced. And, there were two, not one, float plane versions produced. But, to be fair, it WAS the AGO CI I had in mind; and I guess that's close enough. And, it's probably the plane you had in mind anyhow, knowing your expertise. The AGO CI was a recon plane, but since it was armed with a front firing machine gun, it was often used as a fighter, or pursuit plane as they were then known. It was quickly overshadowed by the Fokker E.I, so it's place in History was rather short. So, you are now up, Sir. Make it a good one, Zip! Thanks; Ernie P.
Clues:
1. This aircraft was considered to be quite fast in its day.
2. It was also considered to be quite dangerous by its opponents.
3. This aircraft was armed with a machine gun; which was pretty unusual at the time, and about all that was required to be considered very dangerous.
4. The observer sat in the front; the pilot to his rear.
5. It was a pusher aircraft; which left the observer/gunner free to utilize the still rare, and still more dangerous, machine gun in an offensive role.
6. The engine was considered quite powerful for its day, which contributed to the rather high speed of which it was capable.
7. The engine was first introduced in 1914.
8. A single float plane version was produced.
9. This aircraft had, unfortunately, a rather short service life.
10. It suffered by comparison with an aircraft creating rather a scourge among allied aircraft.
11. It came into service around the same time as the aircraft mentioned in (10) above.
12. It was, like the Dh.2 and the F.E.2, a pusher aircraft, with the tail surfaces attached by two booms.
The AGO C.I was a First World War German pusher reconnaissance biplane that used a pod-and-boom configuration.
The crew and pusher engine shared a central nacelle, and the twin booms carried the tail and the four-wheeled landing gear. The observer sat at the nose and was armed with a machine-gun. It was produced in both two bay and three bay versions. A single example was fitted with floats for coastal patrol duties for the Imperial German Navy (designation C.I-W).
[h=2]Operators[edit][/h] German Empire
[h=2]Specifications[/h]General characteristics
  • Crew: two, pilot and observer
  • Length: 9.0 m (29 ft 6 in)
  • Wingspan: 15.0 m (49 ft 2 in)
  • Wing area: 41.5 m[SUP]2[/SUP] (447 ft[SUP]2[/SUP])
  • Powerplant: 1 Χ Mercedes D.III, 117 kW (158 hp)
Performance
  • Maximum speed: 140 km/h (90 mph)
  • Range: 480 km (300 miles)
  • Service ceiling: 4,800 m (16,000 ft)
Armament
Old 06-03-2016, 01:29 PM
  #13116
Ernie P.
Zip; I forgot to say "Congratulations and well done!" on your answer. Few people have even heard of the AGO CI or CII. Good job on your part, buddy. Thanks; Ernie P.
Old 06-03-2016, 05:33 PM
  #13117
zippome
zippome's Avatar
Actually Ernie, that was wild guess so you would toss us another clue! 😉
OK, lemme dig something up, and I'll be back with a new quiz!
Old 06-03-2016, 07:07 PM
  #13118
Ernie P.
Actually Ernie, that was wild guess so you would toss us another clue! 
A wild guess? At least you knew of the plane; so that makes it, at worst, an educated guess. Looking forward to your question, Zip. Thanks; Ernie P.
Old 06-05-2016, 10:28 AM
  #13119
zippome
zippome's Avatar
Ok guys, here we go again....
1. This aircraft first took to the sky during the 80's.
2. A single engine powers this aircraft thru the sky. ,
There's a start.. it's not much I know, but at least there's no bubblegum involved. .....yet.....
Old 06-05-2016, 11:21 AM
  #13120
tunakuts3d
Yakolev Yak-41 Freestyle/Yak 141 VTOL ? W.A.G.
Old 06-05-2016, 06:25 PM
  #13121
zippome
zippome's Avatar
Not the Yakkity Yak!
3. It looks like there are 4 militaries that use this aircraft.
4. The U.S. bought a couple.
There's a start..
Thanks!
Zip
Old 06-05-2016, 06:35 PM
  #13122
tunakuts3d
Alenia Aermacchi S-211 ?
Old 06-06-2016, 06:26 PM
  #13123
zippome
zippome's Avatar
Sorry, not the S-21 nor the s-211 .
5. Can be equipped with rockets and or cannons.
6. But, in my own opinion... that may look cool until you're in a situation in this aircraft to actually need them.
Ok, thats it for now....
Thanks!
Zip
There's a start..
Thanks!
Zip
Old 06-07-2016, 06:27 PM
  #13124
zippome
zippome's Avatar
7. It has a crew of 2.
8. But there is a version where they are optional.
Thanks!
Zip
There's a start..
Thanks!
Zip
Old 06-07-2016, 07:10 PM
  #13125
Hydro Junkie
Dassault/ Dornier Alpha jet
