Reload this Page >
Knowledge Quiz for Warbird wiz
Old 09-26-2016, 10:12 PM
  #13426
Hydro Junkie
Hydro Junkie's Avatar
The Lancaster
Old 09-27-2016, 12:43 AM
  #13427
Ernie P.
Originally Posted by Hydro Junkie
The Lancaster
Not the Lancaster, Hydro Junkie; but here's a morning clue to aid your search. Thanks; Ernie P.
Question: What warbird do I describe?
Clues:
1. Perhaps the most amazing fact about this warbird is the annual production number was only a few numbers greater than the number of countries utilizing it.
2. It is noted for two significant “firsts”.
3. It was a very advanced aircraft for its time.
4. In fact, only one other manufacturer was producing aircraft which could even be called “comparable” as relates to their modernish design.
5. Various models utilized various engines, from various manufacturers.
6. Both inline and radial engines were used.
7. It was in production for more than ten years.
8. It was in regular use for more than twenty years.
9. It was utilized as a passenger plane, a bomber and as a transport.
10. However, it was first introduced as a transport plane; one which could easily be utilized as a passenger plane.
11. One of the reasons for its popularity was the ease with which alternate landing gear could be fitted.
12. It was a low wing monoplane.
13. It was a cantilever monoplane.
14. Without any supporting wires or external bracing.
15. At a time when such designs were very unusual.
Old 09-27-2016, 08:09 AM
  #13428
Hydro Junkie
Kingfisher
Old 09-27-2016, 09:42 AM
  #13429
Ernie P.
Kingfisher
No, Hydro Junkie; not the Kingfisher. But, please try again. And, as usual, your participation earns another clue. Thanks; Ernie P.
Clues:
16. Even at the end of its production run, it was considered to be a very advanced design.
Old 09-27-2016, 11:59 AM
  #13430
Top_Gunn
How about the Junkers F-13?
Old 09-27-2016, 07:28 PM
  #13431
Ernie P.
And once again, Top_Gunn nails it! Good going; and you are up, Sir. Thanks; Ernie P.
Clues:
17. Most designs even then were externally braced biplanes with fabric covering.
18. Did I mention this aircraft was of all metal construction?
The Junkers F.13 (also known as the F 13) was the world's first all-metal transport aircraft, developed in Germany at the end of World War I. It was an advanced cantilever-wing monoplane, with enclosed accommodation for four passengers. Over 300 were sold. It was in production for thirteen years and in commercial service for almost twenty.
The F.13 was a very advanced aircraft when built, an aerodynamically clean all-metal low-wing cantilever (without external bracing) monoplane. Even later in the 1920s, it and other Junkers types were unusual as unbraced monoplanes in a biplane age, with only Fokker's designs of comparable modernity. It was the world's first all-metal passenger aircraft and Junkers' first commercial aircraft.
The designation letter F stood for Flugzeug, aircraft; it was the first Junkers aeroplane to use this system. Earlier Junkers notation labelled it J 13. Russian-built aircraft used the designation Ju 13.
Like all Junkers duralumin-structured designs, from the 1918 J 7 to the 1932 Ju 46, (some 35 models), it used an aluminium alloy (duralumin) structure entirely covered with Junkers' characteristic corrugated and stressed duralumin skin. Internally, the wing was built up on nine circular cross-section duralumin spars with transverse bracing. All control surfaces were horn balanced.
Behind the single engine was a semi-enclosed cockpit for the crew, roofed but without side glazing. There was an enclosed and heated cabin for four passengers with windows and doors in the fuselage sides. Passenger seats were fitted with seat belts, unusual for the time. The F.13 used a fixed conventional split landing gear with a rear skid, though some variants landed on floats or on skis.
The F 13 first flew on 25 June 1919, powered by a 127 kW (170 hp) Mercedes D IIIa inline upright water-cooled engine. The first production machines had a wing of greater span and area and had the more powerful 140 kW (185 hp) BMW IIIa upright inline water-cooled motor.
Many variants were built using Mercedes, BMW and Junkers liquid-cooled inline engines, see Variants below and by Armstrong Siddeley Puma, Gnome-Rhτne Jupiter and Pratt & Whitney Hornet radial engines. The variants were mostly distinguished by a two letter code, the first letter signifying the airframe and the second the engine. Junkers L5-engined variants all had the second letter -e, so type -fe was the long fuselage -f airframe with a L5 engine.
[h=2]Operational history[/h]
F 13 fy D-190 of Lloyd Ostflug then Junkers Luftverkehrs AG.
Any manufacturer of civil aircraft immediately after World War I was faced with competition from the very large numbers of surplus warplanes that might be cheaply converted - for example, the DH.9C. German manufacturers had further problems with the restrictions imposed by the Inter-Allied Aeronautical Commission of Control, which banned the production of warplanes and of any aircraft in the period of 1921-2. Junkers picked up orders abroad in 1919 in Austria, Poland and the USA and, in the following years with SCADTA (Colombia) and the United States Post Office Department. John Larsen Aircraft in the USA purchased a production licence, their machines being designated JL-6. In 1922 there were sales in England, France Italy and Japan.
In Bolivia, LAB's first airplane was a Junkers F-13; first flight took off from Cochabamba on September 23, 1925.
Junkers set up its own airline - Junkers Luftverkehr AG in 1921 - to encourage the acquisition of the F.13 by German airlines which was flying 60 of them by 1923. They also established a branch of this airline in Iran. Other marketing techniques were used, providing F.13s on cheap leases and free loans, with such effect that some 16 operators across Europe were flying them. When Junkers Luftverkehr merged into Luft Hansa in 1926, 9.5 million miles had been flown by them. Luft Hansa itself bought 55 aircraft and in 1928 were using them on 43 domestic routes. Even in 1937, their F.13s were flying over 50 flights per week on four routes. They were finally withdrawn in 1938.
Most of the F.13s produced before completion of the marque in 1932 were built at Junkers German base at Dessau. During the difficult 1921-3 period production was transferred to Junkers plants at Danzig and Reval. In 1922-3, Hugo Junkers signed a contract with the Soviet Union to produce the aircraft in a Soviet factory at Fili near Moscow which became known as "Plant no. 22". Some of these aircraft served Soviet airlines and some the Red Army.
There were some other military users. The Colombian Air Force used the F.13 (and the related W.33, W.34 and K.43) as bombers in the Colombia-Peru War in 1932-3. The Republic of China flew F.13s converted into scout bombers until the January 28 Incident in 1932, when they were destroyed by the Japanese along with the Shanghai Aircraft Factory. The Turkish Flying Forces flew a few.
A feature that made the F.13 popular internationally was the ease with which its landing gear could be converted to floats. During the formative years of commercial aviation, bodies of water such as rivers, lakes, seas and oceans were more abundant than landing strips and civil airports in many parts of the world, so seaplanes were commonplace and even, in some places, more useful than regular aircraft. Aside from the obvious addition of floats, little modification was needed for this conversion; however, the different configuration could cause issues with directional control, and so some models had their rudder extended to compensate for this.
From their introduction in 1919, commercial F.13s were in service for more than thirty years; the last commercial F.13 was retired in Brazil in 1951.
General characteristics
  • Crew: two
  • Capacity: four passengers or 689 kg (1,519 lb) payload
  • Length: 9.59 m (31 ft 6 in)
F.13fe: 10.50 m (34 ft)
  • Wingspan: 14.8 m (48 ft 7 in)
F.13fe: 17.75 m (58 ft)
  • Height: 3.50 m (11 ft 6 in)
F.13fe: 3.60 m (12 ft)
  • Wing area: 34.50 m[SUP]2[/SUP] (371.4 sq ft)
F.13fe: 44 m[SUP]2[/SUP] (474 sq ft)
  • Empty weight: 951 kg (2,097 lb)
F.13fe: 1,480 kg (3,263 lb)
  • Max takeoff weight: 1,640 kg (3,616 lb)
F.13fe: 2,318 kg (5,110 lb)
  • Powerplant: 1 Χ Mercedes D.IIIa 6-cyl.water-cooled in-line piston engine, 118 kW (158 hp)
F.13fe: 1 x 228 kW (306 hp) Junkers L5 6-cyl. water-cooled in-line piston engine
Performance
  • Maximum speed: 173 km/h (107 mph; 93 kn)
F.13fe: 198 km/h (123 mph)
  • Cruising speed: 160 km/h (99 mph; 86 kn)
F.13fe: 170 km/h (106 mph)
  • Range: 1,400 km (870 mi; 756 nmi)
  • Service ceiling: 5,000 m (16,404 ft)
F.13fe: 5,090 m (16,699 ft)
  • Rate of climb: 2.40 m/s (472 ft/min)
  • Power/mass: 0.0712 kW/kg (0.0443 hp/lb)
Old 09-28-2016, 04:24 AM
  #13432
Top_Gunn
Looking for an airplane.
1. Low-wing monoplane.
2. Crew of two.
3. Under 1000 produced.
Old 09-29-2016, 04:21 AM
  #13433
Top_Gunn
2. Crew of two.
4. Similar in appearance to a much-better-known and somewhat larger plane manufactured by a different company.
Old 09-29-2016, 05:39 AM
  #13434
Ernie P.
2. Crew of two.
Now that is an interesting clue. Thanks; Ernie P.
Old 09-29-2016, 05:16 PM
  #13435
Hydro Junkie
Going back to the Boeing 247. It was Boeing's version of the DC-3 that was the stimulus for Douglas designing the DC-3
Old 09-30-2016, 04:30 AM
  #13436
Top_Gunn
Not the Boeing 247, though it does fit the clues so far. But not today's.
2. Crew of two.
5. The better-known plane referred to in Clue no. 4 was widely used in peacetime and flown by civilians, both before and after the war in which it served. But the plane whose name I'm looking for was flown only by the military (apart from test flights and perhaps deliveries).
Old 10-01-2016, 04:49 AM
  #13437
Top_Gunn
Today's clue:
2. Crew of two.
6. The plane was considered unsuitable for civilian use because of a particular feature of its design.
Old 10-02-2016, 05:40 AM
  #13438
Top_Gunn
Today's clue:
2. Crew of two.
7. The prototype was fabric covered, but the production airplanes were not.
Old 10-03-2016, 04:26 AM
  #13439
Top_Gunn
Today's clue:
2. Crew of two.
8. Its unofficial nickname was the same as that of a widely used ground vehicle.
Old 10-03-2016, 06:41 AM
  #13440
Hydro Junkie
Has to be the Curtis-Wright AT-9 Fledgling twin engine trainer
Old 10-03-2016, 07:04 AM
  #13441
Top_Gunn
That's the plane, more commonly referred to as the "Jeep." Designed to handle like a bomber, so it was difficult to fly and therefore not sold to civilians after the war. Wikipedia article with picture here: Not a bad looking plane.
https://en.wikipedia.org/wiki/Curtiss-Wright_AT-9
Old 10-03-2016, 07:18 AM
  #13442
Hydro Junkie
Guess I have to come up with another one. I'm going to go with a "Daily Double" requiring two aircraft be identified in this one:
1) One was developed by a well known manufacturer, the other was by a relative "upstart"
Good Luck
Old 10-04-2016, 05:38 AM
  #13443
Hydro Junkie
No takers? Time for another clue:
2) Both of these planes evolved into aircraft that be came legends a few years later
Good Luck
Old 10-04-2016, 10:14 AM
  #13444
SimonCraig1
I'll bite with the obvious ones: Hawker Hurricane and Supermarine Spitfire
Old 10-04-2016, 10:59 AM
  #13445
Ernie P.
He's not looking for famous planes; rather planes which developed into famous planes. I was thinking the Mustang Mark I and the Republic P-43 Lancer. Thanks; Ernie P.
Old 10-05-2016, 09:06 AM
  #13446
Hydro Junkie
You hit it head on with the first sentence, Ernie. Unfortunately, you were a bit off the mark with the Mustang Mark I. There were three versions that could be referred to as MK I, the original P-51, the P-51A and the A-36. The only difference between the three was the armament package they carried and, with the A-36, it also had dive brakes in the wings. The B and C, making the MK II, only changed the engine to the Merlin which increased the altitude rating of the plane, as well as the top speed. The D, H and K only changed the plane by going to a bubble canopy as compared to the razor back, being designated the MK III by the British. Other than the engine change and the bubble canopy the plane didn't change so it doesn't really fit.
Now, time for another clue:
3) Neither plane was considered a true dogfighter in it's original form or after it evolved
Good Luck
Old 10-05-2016, 02:37 PM
  #13447
Ernie P.
Good Luck
I'm going to stick with one of my answers and change the other. Not a dogfighter? How about the Republic P-43 Lancer,which became the P-47; and the Lockheed Model 22, which became the XP-38/YP-38and evolved into the P-38? Thanks; Ernie P.
Old 10-05-2016, 06:17 PM
  #13448
Hydro Junkie
Not the Lockheed 22. Time for another clue:
4) While one plane stayed close to it's original form, the other ended up with a similar wing and tail section in a slimmer design than it originally had
Good Luck
Old 10-06-2016, 02:05 PM
  #13449
Hydro Junkie
And, once again, it's time for another clue:
5) While both of the final versions of the planes were combat veterans, only one of the original designs saw real combat
Just for a clarification, both the original planes were designed, built, accepted and put into service by their country's military
Good Luck
Old 10-06-2016, 11:03 PM
  #13450
Hydro Junkie
6) One plane used Boeing designed reward retracting landing gear, the other used the more conventional type
Good Luck
Just a heads up.
I'll be away from my normal internet access points for a few days so if you don't see me, that's why.
