Knowledge Quiz for Warbird wiz
Afternoon clue. Thanks; Ernie P.
Question: What warbird do I describe?
Clues:
1.This aircraft was originally an attempt to redesign and correct the design flaws in an earlier, failed aircraft.
2.It essentially married together the design features of the failed aircraft, with the design features of a remarkably successful aircraft.
3.It also, in turn, influenced the design of a very famous aircraft, although that program was never completed.
4.One of the interesting things is that the aircraft was designed in one country, but built in another.
5.And eventually completed and flown by the second country.
6.It was to have been a high speed, high altitude bomber.
7.But the plane wasn’t completed in time to participate in the war; and was abandoned by the designer country.
8.But there is no question that, had it been completed in time, it would have been almost invulnerable to interception.
9.It was completed and used by the builder country for some years.
10.It was used for high altitude research initially.
11.Then it was used for research into air launched experimental aircraft.
12.This project actually began as a proposal to build a high altitude version of the failed bomber project which served as the “parent” of what later became this aircraft.
13.The idea was to create a high altitude version of a twin engined bomber by adding pressurized crew compartments, reducing the number of crew members and defensive armament and extending and redesigning the wings.
14.This eventually led to a complete redesign, which added two engines.
15.The result was an aircraft which was considerably faster; and which could fly at more than twice the altitude of the parent aircraft.
16.The combination of altitude and speed was such that it was felt the opposing fighter aircraft would be unable to intercept the aircraft.
17.At the same time, a very long range version of the new design was being prepared.
18.Since the offspring of our subject aircraft was also coming into being at the time, this resulted in three different, but very closely related, projects being developed simultaneously.
19.Thus, the decision was made to have this, our subject aircraft, built in a different country; one with considerable experience building aircraft and with a lot of unused capacity in terms of facilities and trained technical staff.
20.The offspring of our subject aircraft was, ironically, itself a twin engined aircraft.
21.Thus the cycle of two engines, four engines, two engines; in the succession of what were three different aircraft designs; versions of each which were intended to fulfill a variety of roles ranging from bomber to long range and high altitude bombers.
22.And, to complete the irony, the offspring aircraft, originally designed as a bomber, was redesigned as a high speed fighter.
23.A night fighter.
24.Our subject aircraft was to have been a high speed, high altitude bomber, but was only flown as an experimental, high altitude research aircraft; which was later used to launch test experimental high speed aircraft.
25.Our subject aircraft was first envisioned in 1938.
26.And first flew in 1945.
27.Had any of the three parallel development aircraft become operationally ready a bit earlier; they would be household names today.
28.The second aircraft was first flown in 1947.
29.And those two were the only ones ever built.
30.Empty, they were to have weighed over 45,000 pounds.
31.Fully loaded and armed, they were to have weighed over 80,000 pounds.
32.Maximum speed was to have been over 350 MPH.
33.At over 35,000 feet.
34.This aircraft was designed by a major designer and manufacturer of aircraft; one easily recognized.
35.The eventual completion and flight use was also done by an easily recognizable aircraft manufacturing entity.
36.And, it was actually being built, prior to its abandonment by the designers, by yet another well-known and easily recognizable aircraft manufacturing entity.
Clues:
23.A night fighter.
A couple of evening clues to help you along. And a strong hint. Read (19) again. Big, big hint. Thanks; Ernie P.
Clues:
23.A night fighter.
37.The designer company was also working on a small handful of prototypes at its headquarters plant in the owning country; but those were never completed.
38.The company which ultimately completed the two known prototypes actually utilized the facilities of the company in (36).
Clues:
23.A night fighter.
Clues:
23.A night fighter.
39.That company, the one which was originally building the two prototypes, was by then largely defunct; although they managed to survive, to some degree, until the mid-1950’s.
40.That company, over its lifetime, had designed and/or built more than 200 different types of aircraft.
As it is now morning, I am posting my morning clue; the 41st in this series. And, after posting this clue, the floor is now open to the first person to ask me a question about this warbird. The first person to ask an allowable question will get an answer. Thanks; Ernie P.
Clues:
23.A night fighter.
41.And its name was that of a famous aviation pioneer.
Clues:
23.A night fighter.
Top_Gunn; yes the design was German. And, since you have now asked a question, I will post another clue. I don't plan on using this method very often, but it seemed the best way to help you guys get on track a bit faster without giving it away. Thanks; Ernie P.
Clues:
23.A night fighter.
42.The subject aircraft itself had a wingspan of nearly 150 feet.
Clues:
23.A night fighter.
Clues:
7.But the plane wasnt completed in time to participate in the war; and was abandoned by the designer country.
12.This project actually began as a proposal to build a high altitude version of the failed bomber project which served as the parent of what later became this aircraft.
23.A night fighter.
39.That company, the one which was originally building the two prototypes, was by then largely defunct; although they managed to survive, to some degree, until the mid-1950s.
Clues:
23.A night fighter.
Clues:
23.A night fighter.
43.In wartime use, it was to have had a crew of four.
Sorry, uncljoe; but no. We've already (see above from Top-Gunn) established the design was German. But here's another clue and now I'll accept another question. Thanks; Ernie P.
Clues:1.This aircraft was originally an attempt to redesign and correct the design flaws in an earlier, failed aircraft.
23.A night fighter.
44.It could fly more than 2,000 miles.
23.A night fighter.
Clues:
3.It also, in turn, influenced the design of a very famous aircraft, although that program was never completed. 4
23.A night fighter.
36.And, it was actually being built, prior to its abandonment by the designers, by yet another well-known and easily recognizable aircraft manufacturing entity. 3
41.And its name was that of a famous aviation pioneer. 4
45.It was to have carried a bombload in excess of 8,000 pounds.
Clues:
23.A night fighter.
29.And those two were the only ones ever built. 3
46.The bombload was carried internally.
Waiting on a question. If you don't know the answer, you should have lots of questions, right? Now's your chance to get answers. Thanks; Ernie P.
No, Sir; the plane was not built by an American firm. But here's another clue, to reward your attempt. Thanks; Ernie P.
Clues:
23.A night fighter.
47.It had two separate pressurized crew compartments.
Clues:
23.A night fighter.
Hydro Junkie; the answer is "No", the subject warbird was not designed by Messerschmitt. FWIW, I always thought the Me 264 was an awesome looking aircraft; very brutal and powerful in appearance. But, nothing to do with this quiz. However, you now have another clue and another opportunity to ask yet another question. Thanks; Ernie P.
Clues:
23.A night fighter.
48.In its design the capacity for inflight refueling was under consideration.
Clues:
23.A night fighter.
BTW; just so everyone is clear on this point: This question involves an actual aircraft, which was designed, built and which flew. It isn't about someone's pipedream paper design. Just reassuring everyone. Thanks; Ernie P.
