Reload this Page >
Knowledge Quiz for Warbird wiz
Old 08-20-2015, 11:08 AM
  #11726
Hydro Junkie
Hydro Junkie's Avatar
P51 B/C, faster than the P-51, P-51A or A-36 due to the installation of the 1650 Packard Merlin instead of the 1710 Allison. One bit of side trivia, the Mustang D, H and K were all slower than the B/C due to the loss of streamlining associated with the installation of the bubble canopy
Old 08-20-2015, 06:59 PM
  #11727
JohnnyS
All good guesses, but not what I'm looking for...
1. It was based on its predecessor aircraft, but was faster due to reduced drag from a major design change.
2. Single engine, 6 cylinder.
Old 08-21-2015, 05:18 AM
  #11728
JohnnyS
3. Inverted tailfin.
Old 08-21-2015, 09:57 AM
  #11729
JohnnyS
4. There are no modern military aircraft in service of this specific type and purpose.
Old 08-21-2015, 10:46 AM
  #11730
elmshoot
[h=1]Junkers J.I[/h]
Old 08-21-2015, 02:09 PM
  #11731
JohnnyS
Not the J.1
5. Operated by either 8 or 7 different nations, depending on how you count them.
Old 08-22-2015, 06:12 AM
  #11732
Ernie P.
Originally Posted by JohnnyS
Not the J.1
I'm pretty sure I have this one figured out, but I've been up a lot lately. I'll give it a bit longer before I speak up. Thanks; Ernie P.
Old 08-22-2015, 06:20 AM
  #11733
JohnnyS
6. Crew of 2.
7. Monoplane.
Old 08-23-2015, 11:47 AM
  #11734
JohnnyS
6. Crew of 2.
7. Monoplane.
8. It was a fighter aircraft.
9. For armament, it had the following:
1 or 2 Χ fixed, forward-firing 7.92 mm (0.312 in) LMG 08/15 machine guns
1 Χ flexible 7.92 mm (0.312 in) Parabellum MG14 in rear cockpit
Old 08-23-2015, 03:42 PM
  #11735
JohnnyS
NO guesses yet? Come on guys: Ernie P. has already figured it out!
6. Crew of 2.
7. Monoplane.
10. The engine had 150 horsepower.
Old 08-23-2015, 04:20 PM
  #11736
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
RCKen's Avatar
I think I have it, but as I have no quiz ready to go at the moment I'm going to hold off with my answer for the moment. If I can work up a quiz then I'll answer. But I just don't want to get caught short like I did last time without a quiz after I answered correctly.
Ken
Old 08-24-2015, 04:45 AM
  #11737
JohnnyS
6. Crew of 2.
7. Monoplane.
11. Floatplane.
Old 08-24-2015, 05:02 AM
  #11738
Evenbigger D
Hansa-Brandenburg W.29
Old 08-24-2015, 06:32 AM
  #11739
MJD
MJD's Avatar
If you cut and paste "1 Χ flexible 7.92 mm (0.312 in) Parabellum MG14 in rear cockpit" - the W.29 pops right up on Wiki.
Old 08-24-2015, 07:32 AM
  #11740
Ernie P.
I thought clues 1 -5 pretty much nailed it down; particularly clues 3 and 4. But it's up to JohnnyS; he'll let us know. But, there's a reason I try to avoid using canned or copied phrases in the clues I provide when asking questions. I may be wrong, but I believe the inverted tailfin was intended to reduce the aircraft's profile, to allow storage in smaller sheds or hangers. Thanks; Ernie P.
The Hansa-Brandenburg W.29 was a German monoplane fighter floatplane which served in the closing months of World War I, from bases on the North Sea coast.
It was based on the W.12 biplane that it was designed to replace. The monoplane configuration created less drag, and thus gave greater speed.
[h=2]Operators[/h] Austria-Hungary
  • Austria-Hungary placed an order for 25 W.29s, powered by 185 hp (138 kW) Austro-Daimler engines, to be built under license by Ufag at Budapest. One completed by the end of World War I.
Denmark
  • Royal Danish Navy - purchased one W.29 from Germany in 1919, building a further 15 powered by the 150 hp Benz or 160 hp (120 kW) Orlogsvζrftet O-V six-cylinder inline engine under license at the Orlogsvζrftet (Danish Royal Naval Dockyard) as the HM.1 from 1921 to 1927, the type remaining in service until 1930, being replaced by the Heinkel HE 8.
Finland
German Empire
Hungary
  • Hungarian Soviet Republic ordered production of the W.29 at Ufag to restart. At least two were completed, which together with the single W.29 completed for Austria-Hungary, were operated by the 9th Floatplane Squadron operating from Cspel near Budapest.
Japan
Netherlands
Norway
  • Norwegian Army received two ex-German W.29s in 1920, using them for support of coastal artillery. The two W.29s, designated Mεke I, were transferred to the Royal Norwegian Navy in 1928, along with the army's W.33s and the Coastal Artillery arm.
  • A/S Aero
[h=2]Specifications (W.29)[/h]Data from Encyclopedia of Military Aircraft
General characteristics
  • Crew: Two (pilot & observer/gunner)
  • Length: 9.38 m (30 ft 8 in)
  • Wingspan: 13.50 m (44 ft 4 in)
  • Height: 3.00 m (9 ft 11 in)
  • Wing area: 32.2 m² (348 ft²)
  • Empty weight: 1,000 kg (2,200 lb)
  • Loaded weight: 1,494 kg (3,285 lb)
  • Powerplant: 1 Χ Benz Bz.III 6-cylinder water-cooled inline engine, 112 kW (150 hp)
Performance
Armament
  • 1 or 2 Χ fixed, forward-firing 7.92 mm (0.312 in) LMG 08/15 machine guns
  • 1 Χ flexible 7.92 mm (0.312 in) Parabellum MG14 in rear cockpit
Old 08-24-2015, 07:56 AM
  #11741
Hydro Junkie
I was thinking like a few others, had several in the past couple of months, time to take a break. I figured it was German since nothing the western forces had, that I know of anyway, had an inverted vertical tail
Old 08-24-2015, 10:22 AM
  #11742
JohnnyS
And we have a WINNER!!!!
Take it away, Evenbigger D!
Notes:
1. The inverted tail was intended to give the rear gunner an excellent field of fire: The gunner could traverse the gun while firing to the rear and not worry about shooting the rudder off. Handy in a dogfight!
2. The problem back then was that wings were very thin, so that it was hard to make a monoplane rigid enough. The W.29 had a very strong undercarriage to support the floats, so the remaining wing was braced against that undercarriage when the upper wing was removed. This allowed for a strong wing structure for a safe airframe but with much lower drag than the preceding W.12 biplane version. That was a very clever trick to make a better aircraft, and it was quite successful from the references I pulled up.
Hansa-Brandenburg W.29 - Wikipedia, the free encyclopedia
Wingnut Wings - 1/32 Hansa-Brandenburg W.29
Old 08-24-2015, 10:28 AM
  #11743
Evenbigger D
This plane had two significant "firsts", what was the plane and what were the two "firsts"?
Old 08-24-2015, 10:57 AM
  #11744
Hydro Junkie
Dehavland Comet:
First pressurized airliner
First jet powered airliner
Old 08-24-2015, 11:03 AM
  #11745
Evenbigger D
Good guess but not what I was after.
Six cylinder engine
Old 08-25-2015, 01:59 AM
  #11746
Evenbigger D
Six cylinder engine
Only one built destroyed by the RAF early in WW2
Old 08-25-2015, 03:35 PM
  #11747
Evenbigger D
Six cylinder engine
Essentially an experimental or pioneer aircraft
Old 08-27-2015, 03:37 AM
  #11748
Evenbigger D
Six cylinder engine
2 seater, 81mph
Old 08-27-2015, 01:22 PM
  #11749
Evenbigger D
Six cylinder engine
2 seater, 81mph
Wing construction technique was later used in B17
Old 08-28-2015, 05:39 AM
  #11750
Evenbigger D
Six cylinder engine
2 seater, 81mph
Wing construction technique was later used in B17s
"early in WW2" is a very misleading twist
