Reload this Page >
Knowledge Quiz for Warbird wiz
Old 04-18-2018, 05:49 AM
  #15701
Ernie P.
Morning clue. Thanks; Ernie P.
What warbird do I describe?
1. Sometimes things just don’t work out as planned.
2. This aircraft was one such attempt that certainly didn’t work as planned.
3. It was intended to fulfill a very narrow role; so large scale production was probably never in the plan.
4. Although it made its way into limited production, the results were very disappointing.
5. The first prototype was produced immediately prior to Pearl Harbor.
6. Five more were built in the next year.
7. The aircraft had no less than three interesting (for the time) innovations, all unique as far as it’s owning service was concerned.
8. None of the three innovations worked quite as planned.
9. This aircraft was intended to be the fastest of its type, for its time. While it was the fastest of its service, it was eventually surpassed by other aircraft of its type.
10. Primarily because two of the three innovations simply didn’t work, and the other was of limited value.
11. Interestingly, the aircraft made it into limited production without one of the innovations actually being tried in practice.
12. It was a specialized type of recon bird.
13. And was, obviously, intended to be able to outrun enemy fighters.
14. This plane used a laminar flow wing.
15. And contra rotating propellers.
Old 04-18-2018, 12:59 PM
  #15702
Ernie P.
Afternoon clue. Thanks; Ernie P.
16. And floats.
Old 04-19-2018, 05:06 AM
  #15703
elmshoot
cant z.515
Old 04-19-2018, 07:42 AM
  #15704
Ernie P.
Not the Cant Z.515, elmshoot, as this next clue will show. But a good guess and I hope you try again. Thanks; Ernie P.
16. And floats.
17. It used a central float and twin stabilizing floats.
Old 04-19-2018, 08:19 AM
  #15705
Hydro Junkie
Hydro Junkie's Avatar
Kawanishi N1K1 Kyofu fighting floatplane
Old 04-19-2018, 08:27 AM
  #15706
Ernie P.
Great answer, Hydro Junkie; but the Kyofu is not quite what we're looking for. But you earn a bonus clue, and maybe this will help narrow your search. Thanks; Ernie P.
16. And floats.
18. The stabilizing floats were intended to retract into the wings.
Old 04-19-2018, 08:43 AM
  #15707
proptop
My Feedback: (8)
proptop's Avatar
I was also thinking of the "Rex"...but it didn't fly until 1942...
Been bouncing something round in my head...
Just a sneakin' suspicion...how 'bout the "Norm"...
https://en.wikipedia.org/wiki/Kawanishi_E15K
Old 04-19-2018, 08:55 AM
  #15708
Ernie P.
And proptop nails it again! See, that wasn't so hard, was it? The "Norm" was an interesting aircraft, with great potential; but it simply didn't work. They were only intended to be used on small cruisers, acting as lookouts for a squadron of submarines; so they never intended to produce a lot of them. Only fifteen (15) were ever completed. The stabilizing floats retracted into the wings, but sometimes didn't return to the down position when the plane landed; destroying the plane when it landed. And the main float was supposed to be jettisoned if the plane was in danger, increasing its speed. Except that feature was never tried when the plane was tested; only in actual combat. And it didn't work. and so, the plane was shot down by attacking fighters. And the contra rotating propellers were trouble prone and hard to maintain. As I said; interesting innovations that simply didn't work in practice. Good job, proptop; and you are up! Thanks; Ernie P.
16. And floats.
19. Which they did.
20. They could then be deployed for landing.
21. Which didn’t always work as designed.
22. And which often ended in the loss of the plane.
23. The central float was designed to be jettisoned in an emergency; to give it extra speed to escape enemy fighters.
24. Which didn’t always work as designed.
25. And which often ended in the loss of the plane.
26. Then again, the jettisonable float was never tried in testing.
27. But was tried in combat.
28. And didn’t work.
29. Single engine.
30. Crew of two.
31. Its code name was that of a noted squadron leader.
32. Fl
Answer: The Kawanishi E15K Shiun The Kawanishi E15K Shiun (紫雲, "Violet Cloud") was a single-engined Japanese reconnaissance floatplane of World War II. The Allied reporting name for the type was "Norm" after Squadron Leader Norman O. Clappison of the RAAF, a member of the Allied Technical Air Intelligence Unit (ATAIU).
Design and development
In 1939 the Imperial Japanese Navy instructed the Kawanishi Aircraft Company to develop a two-seat high-speed reconnaissance floatplane, which was required to have sufficient performance to escape interception by land based fighters. It was planned to equip a new class of cruisers, intended to act as a flagship for groups of submarines, operating six of the new floatplanes to find targets. The first of the new cruisers, Ōyodo was also ordered in 1939. Kawanishi designed a single-engined low-wing monoplane, powered by a 1,460 hp (1,090 kW) Mitsubishi MK4D Kasei 14 14-cylinder radial driving two Contra-rotating two-bladed propellers, the first installation of contra-rotating propellers produced in Japan, while a laminar flowairfoil section was chosen to reduce drag. It had a single main float under the fuselage and two stabilising floats under the wing. The stabilising floats were designed to retract into the wing, while the central float was designed to be jettisoned in case of emergency, giving a sufficient increase in speed (estimated as approximately 50 knots (90 km/h)) to escape enemy fighters. The first prototype of Kawanishi's design, designated E15K1 in the Navy's short designation system made its maiden flight on 5 December 1941. Five more prototypes followed during 1941–42. Problems were encountered with the retractable stabilising floats, resulting in several accidents when the floats could not be lowered for landing, and the system was eventually abandoned, with the stabilising floats being fixed, and a more powerful Mitsubishi MK4S Kasei 24 engine fitted to compensate for the increased drag.
Operational history
Despite these problems, the E15K1 was ordered into limited production as the Navy Type 2 High-speed Reconnaissance Seaplane Shiun Model 11. Six were sent to Palau in the South Pacific, but these were quickly shot down by Allied fighters, as the jettisonable float failed to separate on demand (although subjected to wind tunnel testing, the float separation system had never been tested on the actual aircraft). This resulted in the cancellation of production in February 1944, with only 15 Shiuns completed, including the six prototypes.
Commander of 12rh recon Sq. (Shiun Sq.), Lt Kiyoshi Aikawa wrote "Never made again such aircraft as Shiun".He wrote reliability of Shiun is too low, and need high Maintenance effort.
Specifications (E15K)[edit]
Data from Japanese Aircraft of the Pacific War[8] General characteristics· Crew: Two· Length: 11.59 m (38 ft 0 in)· Wingspan: 14.00 m (45 ft 11 in)· Height: 4.95 m (16 ft 2⅞ in)· Wing area: 30.0 m² (323 ft²)· Empty weight: 3,165 kg (4,978 lb)· Loaded weight: 4,100 kg (9,039 lb)· Max. takeoff weight: 4,900 kg (10,803 lb)· Powerplant: 1 Χ Mitsubishi MK4S Kasei 24 14-cylinder air-cooled radial engine with two two-blade contra-rotating propellers, 1,159 kW (1,540 hp)at 5,500 m (18,045 ft) Performance· Maximum speed: 468 km/h (253 knots, 291 mph) at 5,700 m (18,700 ft.) (float attached)· Cruise speed: 296 km/h (160 knots, 184 mph)· Range: 3,373 km (1,820 nmi, 2,095 mi)· Service ceiling: 9,836 m (32,270 ft)· Wing loading: 136.7 kg/m² (28 lb/ft²)· Power/mass: 0.28 kW/kg (0.17 hp/lb)· Climb to 6,000 m (19,700 ft): 10 min Armament· 1 Χ 7.7 mm (0.303 in) machine gun in rear cockpit
Old 04-19-2018, 10:09 AM
  #15709
proptop
My Feedback: (8)
proptop's Avatar
The Japanese had quite a few interesting and unusual designs, aye? I recall reading of a problem of harmonics and/or vibrations caused by 2 (x2) blade contra props...seems that when the blades cross they set up a chop chop pulsating vibration...which is exacerbated by the 2 bladed props.
3 or 4 props blades lessen the effects...I guess because they are closer together...different frequency or timing of the pulsations / chop chop effects?
Anywayze...got a subject in mind..
Will be back later this eve with more, but will get us started now...
Old 04-19-2018, 10:25 AM
  #15710
proptop
My Feedback: (8)
proptop's Avatar
Got a plane in mind...
1) Monoplane...
2) Twin engined...
3) Propeller driven...
4) Manuf. used the same name twice...for two totally different aircraft...almost 2 decades apart...
Old 04-19-2018, 03:51 PM
  #15711
Ernie P.
1) Monoplane...
2) Twin engined...
Sorry; can't resist. The Thunderbolt? Thanks; Ernie P.
Old 04-19-2018, 04:18 PM
  #15712
proptop
My Feedback: (8)
proptop's Avatar
Ahhh...but that would be far too easy...(as in nope...not what we're lookin fer...)
1) Monoplane...
2) Twin engined...
5) Designed to a mid-war requirement...(WW2)
6) Thinking of the above mentioned contra props...some versions had these as well...
Old 04-19-2018, 06:38 PM
  #15713
Hydro Junkie
I was going to say the Corsair until you threw a wrench into it by saying it had twin engines. That said, how about the Lightning
Old 04-19-2018, 08:54 PM
  #15714
proptop
My Feedback: (8)
proptop's Avatar
Nope...not the Lightning...
I have a penchant for obscure aircraft, at least where our quiz thread here is concerned...
(gotta try to make ya'll scratch your heads for a little while...)
1) Monoplane...
2) Twin engined...
7) Designed to be utilized as a Bomber...Recon, or Torpedo attack craft...
Old 04-19-2018, 08:57 PM
  #15715
proptop
My Feedback: (8)
proptop's Avatar
1) Monoplane...
2) Twin engined...
8) Some complaints of inadaquite power led to use of the then new turboprop engines, in some later versions.
Old 04-20-2018, 03:51 AM
  #15716
elmshoot
Fisher P-75 Eagle
and a lovely plane to behold in person at the USAF museum, If it had USN on one version I'd put it on my someday list.
Sparky
Old 04-20-2018, 05:16 AM
  #15717
FlyerInOKC
FlyerInOKC's Avatar
Originally Posted by elmshoot
Fisher P-75 Eagle
Sparky
Great looking airplane, I wonder if it has a "Body by Fisher" label on it?
Old 04-20-2018, 11:38 AM
  #15718
proptop
My Feedback: (8)
proptop's Avatar
When I worked at a Body and Paint shop, we used to jokingly call it "Body by Fissure"
But I digress...nope...not the P-75
Be back in a few...
Old 04-20-2018, 12:08 PM
  #15719
proptop
My Feedback: (8)
proptop's Avatar
O.K...let's add another clue or two...
1) Monoplane...
2) Twin engined...
9) The bomb bay could be used to house bombs or depth charges...
10) The first flight(s) were after the end of the war...
Old 04-20-2018, 12:29 PM
  #15720
proptop
My Feedback: (8)
proptop's Avatar
1) Monoplane...
2) Twin engined...
11) Some of the later versions were modified after the war, for Anti-Submarine Warfare / Detection use, but they were Short lived...
Old 04-20-2018, 06:51 PM
  #15721
proptop
My Feedback: (8)
proptop's Avatar
1) Monoplane...
2) Twin engined...
12) The ASW versions were Turboprop engined, with single props (not contra-rotating) and transformed a decent looking plane into a hideous (IMO) looking thing that also had rather abysmal flight characteristics.
13) The first aircraft to use the name was a late 1920's biplane...almost 20 years prior...
Old 04-20-2018, 07:01 PM
  #15722
elmshoot
Fairey Gannet
One of the ugliest airplane to ever make production.
Old 04-20-2018, 08:48 PM
  #15723
FlyerInOKC
FlyerInOKC's Avatar
Fairey Gannet
Now that's ugly to the bone!
Old 04-20-2018, 08:57 PM
  #15724
proptop
My Feedback: (8)
proptop's Avatar
Fairey Gannet
I will agree with ya on the ugly part...but...not the Gannet...
Not quite the same "twin engined" layout...
Old 04-20-2018, 09:07 PM
  #15725
proptop
My Feedback: (8)
proptop's Avatar
1) Monoplane...
2) Twin engined...
14) It had folding wings...which oughta narrow the field somewhat...
15) A few were used as target tugs...but there were so many other (more common) types available after the war that our quiz aircraft became superfluous.
