Reload this Page >
Knowledge Quiz for Warbird wiz
Old 05-24-2018, 05:53 AM
  #15851
Ernie P.
Originally Posted by Hydro Junkie
The P-43 Lancer
A good guess, Hydro Junie; but not correct. There is nothing wrong with your thinking process; so keep trying. And here's a bonus clue to help you. Thanks; Ernie P.
What warbird do I describe?
1. This aircraft never reached production.
2. But, it wasn’t because there was anything wrong with the aircraft itself.
3. Although the plane was certainly adequate for its intended mission, a policy decision made its intended mission irrelevant.
Old 05-24-2018, 12:01 PM
  #15852
Ernie P.
Afternoon clue. Thanks; Ernie P.
4. Nevertheless, the original mission and intention was resurrected some 20 years later.
Old 05-24-2018, 01:38 PM
  #15853
Hydro Junkie
Hydro Junkie's Avatar
I know, the B-70 Valkyrie
Old 05-24-2018, 03:13 PM
  #15854
Ernie P.
It does kind of sound like the B-70, doesn't it? But it isn't, so keep trying. Here's another clue to aid your search. Thanks; Ernie P.
5. And our subject aircraft was again offered to fulfill the mission.
Old 05-24-2018, 04:38 PM
  #15855
elmshoot
I didn't think of the B-70 so much as a prototype but as a research aircraft..... and to scare the crap out of the Soviets!
Sparky
Old 05-24-2018, 04:51 PM
  #15856
Ernie P.
An evening clue to speed things along. Thanks; Ernie P.
6. Our subject aircraft was easy to fly, very maneuverable and a real handful for other contemporary aircraft to handle in mock combat.
Old 05-24-2018, 06:10 PM
  #15857
Hydro Junkie
Sparky
Actually, the B-70 was supposed to be used as a high altitude supersonic nuclear bomber to hit targets in the Soviet Union. The thought was that using high speeds and altitudes, it would be impossible to stop. That all changed when the Russians shot down a U-2 and captured its pilot, alive. The Pentagon then scrubbed the program in preference to low altitude aircraft that could use terrain to hide their approach. This was the basis of several subsequent aircraft programs, leading up to the F-111(originally designed as a fighter), B-1 and B-2
Old 05-24-2018, 07:23 PM
  #15858
Ernie P.
Right you are, Sirs. And for sharing that info, you two are awarded a bonus clue. The aircraft in question definitely went low, rather than high. Thanks; Ernie P.
7. However, the advance of technology resulted in a new design being chosen for the mission.
Old 05-25-2018, 12:21 AM
  #15859
Mr.Alvaro
Sabre II that became the JF-17 Thunder?
Old 05-25-2018, 02:12 AM
  #15860
Ernie P.
Welcome, Sir! A new voice and an interesting guess. The Sabre II isn't a well known plane. Interesting. But, not the plane for which we seek; so here's another clue to reward your participation. Please try again. Thanks; Ernie P.
8. The aircraft which won out over our subject aircraft, 20 years later, went into production.
Old 05-25-2018, 09:30 AM
  #15861
Ernie P.
9. More than one thousand of that aircraft were produced; and it is well known.
Old 05-25-2018, 03:18 PM
  #15862
Top_Gunn
The Beechcraft XA-38 Grizzly seems to fit almost all of the clues (with the A-10 as the modern plane that reached production), but I can't find anything to fit Clue 5. And I'm not sure A-10 production went over 1000, unless you count major upgrades as additional production. Still, the XA-38 fits clues 1 to 4 and 6 very well, and it's a plane well worth looking at.
Old 05-25-2018, 06:06 PM
  #15863
Ernie P.
A good guess, Top_Gunn; but not where we're headed. Here's a bonus clue to reward your diligence, though. Thanks; Ernie P.
10. Our subject aircraft had one serious flaw in its original design, revealed when its guns were fired.
Old 05-25-2018, 07:17 PM
  #15864
elmshoot
F-104 shot itself down on a strafing run in flight test.
I believe the A-10 also had a flame out from gun gasses being ingested in the engines.
Sparky
Old 05-25-2018, 08:33 PM
  #15865
Ernie P.
Sparky
Neither the F-104 or the A-10, Sparky. But I will award another bonus clue for your efforts. And since today is going to be a really long one, I'll go ahead and drop a couple more. Thanks; Ernie P.
11. The muzzle flash temporarily blinded the pilot.
12. And the gases produced by firing knocked out both engines very rapidly.
13. Even a single gun firing a few shells was sufficient to knock out the engine on that side.
Old 05-26-2018, 04:23 PM
  #15866
Ernie P.
A bonus clue for... for.... Today! Thanks; Ernie P.
14. This defect in design was corrected by moving the air intakes forward.
Old 05-27-2018, 01:47 AM
  #15867
Ernie P.
Morning clue. Thanks; Ernie P.
15. And mounting the guns on the bottom of the fuselage.
Old 05-27-2018, 05:12 PM
  #15868
JohnnyS
Avro Arrow?
Old 05-27-2018, 07:59 PM
  #15869
Ernie P.
Originally Posted by JohnnyS
Avro Arrow?
Not the Avro Arrow, JohnnyS; but here's a bonus clue to thank you for your participation. Thanks; Ernie P.
16. This resulted in a rather unusual profile. A profile which brought something unrelated to mind very quickly.
Old 05-28-2018, 04:02 AM
  #15870
Ernie P.
17. But, in my opinion at least, never has a military aircraft looked quite so aggressive.
Old 05-28-2018, 11:39 AM
  #15871
Ernie P.
18. This plane had a crew of two.
Old 05-28-2018, 05:00 PM
  #15872
proptop
My Feedback: (8)
proptop's Avatar
I recall reading of the guns firing and the smoke knocking out the engines...and moving the intakes fwd...I think it was the F-89 Scorpion?
Old 05-28-2018, 08:08 PM
  #15873
Ernie P.
I don't recall any problems with the guns knocking out the engines on the F-89, proptop. Some flutter problems if I recall correctly, but we're not looking for the F-89 in any event. But thanks for trying and here's a bonus clue for your effort. Thanks; Ernie P.
19. The aircraft was ordered into production, but only five had been produced when the policy shift mentioned put an end to the program.
Old 05-29-2018, 02:30 AM
  #15874
Ernie P.
20. The aircraft was heavily armored.
Old 05-29-2018, 08:41 AM
  #15875
Hydro Junkie
Originally Posted by proptop I recall reading of the guns firing and the smoke knocking out the engines...and moving the intakes fwd...I think it was the F-89 Scorpion?
Originally Posted by Ernie P. I don't recall any problems with the guns knocking out the engines on the F-89, proptop. Some flutter problems if I recall correctly, but we're not looking for the F-89 in any event. But thanks for trying and here's a bonus clue for your effort. Thanks; Ernie P.
From what I can tell, moving the intakes forward wouldn't do any good on the F-89 anyway. The muzzles the lowest four 50 cal machine guns are actually right in front of the engines on both sides of the nose as shown in this picture:
