panel lines
CA
Hi builders
I am putting panel lines and rivets dots on my yellow zero, i have only been able to get
1/32 graphgic tape. is that going to be to big, or is it just fine. Ian
follow this thred. there is a option here its 1/64 .. pretty much the same scale plane
http://www.rcuniverse.com/forum/m_9080616/tm.htm
ORIGINAL: Bluffman
Hi builders
Hi builders
Go here
[link=http://wyliewarbirds.com/products/products.htm]http://wyliewarbirds.com/products/products.htm[/link]
1/64 no problem...
My Feedback: (8)
1/64 inch chart pack tape would be your better solution. This size simulates a 1/8 inch gap between panels on a 1/6th scale bird (which is what the Yellow is).
1/32 inch chart pack tape is a bit large. This size simulates a 3/16 inch gap between panels on a 1/6 scale bird.
You can buy 1/64 inch chart pack tape here. http://www.rcscaleproducts.com/finish_acc.htm
Good luck.
Good luck.
GA
Bluff, fwiw I recently discovered I could use a 15 watt soldering iron with a fine pencil tip to create very good panel lines in my primered plane, using a metal ruler with a cork backing for a straightedge. I haven't seen this used before, so I don't know what others experience may be.......but it works for me.
Rick
Rick
