J2M3 Raiden in 1:5 scale
#129
RE: J2M3 Raiden in 1:5 scale
Life work and economy got in the way. I hope to have it in the air early spring. After it's flight tests plans, kit ect will be available. Hang in there!! John
#131
After the glass cured I trimmed the excess off and gave the wing a good sanding with 80 grit then I sanded it again with 180 grit. Next I will do 2 coats of of water based primer. I apply it with a foam roller. Spot fill and sand. John
#134
ORIGINAL: Baldeagle
John What brand of primer are you using? I have always used Laqure primer but like to find something that doesen't stink so bad. Thanks Rich
#144
ORIGINAL: n8622t
Dont worry bro Im not going to crash yer thread...just showing others that there is another way Have a nice day
