NEW Top Flight P-40??? 1/5 scale
#976
My Feedback: (12)
IL
RE: NEW Top Flight P-40??? 1/5 scale
ORIGINAL: lomcevac540T
Sorry I haven't talked with him in a while, but I hope to get up with him this weekend.
Thought about maybe making it removable in case I change engines and or sell it and the new owner wants to.
#977
FL
I do not have a G-62 in mine but I have a Super Tigre 4500 in mine. The big Tigre weighs 79 oz. approx. 5 lbs. and I moved my battery pack in back of the tail wheel opening to get it to balance . I 'am not sure but the G-62 may be almost the same , you may have to move your ignition battery back farther and your flight pack back where I placed mine. I 'am going to build another one with a DLE-55 in it and I suspect that I will need nose weight unless I move the batteries forward to balance. Great flying plane , I flew mine this past weekend at our WAR-Bird event and a lot of people were shocked to see how great the SUPER TIGRE pulled it.
good luck
thanks bob
good luck
thanks bob
#978
I just finished mine. It is equipped with a DLE. Balance point is 1/4 inch behind the recommended starting point, which is still 1/8th inch ahead of the rear-most recommended balance point. I'm fine with it at this position.
Lokking forward to the maiden but there are 3 other untried newbies ahead of it. Should be a great flying season!
#979
My Feedback: (10)
ORIGINAL: Lifer
#981
My Feedback: (7)
Here is mine with a G-62. Relocated the carb to the rear and it is electronic ignition. No cutouts in the cowl. I moved my battery back and had to add a fair amount of lead in the tail to balance. I made the lead removeable in order to fine tune it. Flys great and lands very nicely.
#983
My Feedback: (12)
IL
ORIGINAL: JackL
Cut my cowl up pretty good due to useing Bennent side mount.
Knew that going in, had the muffler.
Mine 62 is magneto, only battery I have to move back would be for RX.
I will probably glue in weight this weekend.
Thanks for the replies.
#984
My Feedback: (7)
It is a Jtec. www.jtecrc.com They make them custom to fit in the cowl. Works great!
[/quote]
What muffler did you used to get it all in the cowl?
[/quote]
[/quote]
[/quote]
#985
My Feedback: (7)
Sierra makes them in several lengths. www.sierragiant.com Makes is a lot easier to fit everything in the cowl.
ORIGINAL: B Shipp
I like the prop extension!
#986
KY
Has anyone used different wheels on this bird? i dont like the ones that came with it.. Also is the 24 oz tank big enough? How much flight time are you getting.
#987
My Feedback: (8)
ORIGINAL: warhawk demon
A 24ozs tank is good for about 13 minutes with a G-62 at full throttle. My Mustang now has a 32 oz it it.
#990
My Feedback: (8)
Just painted my three blade spinner and prop...dont use the missile red paint from top flight...get a can of rustoleum cherry red...it goes on very smooth and matches very well. If you want a superior finish then use the rustoleum grey primer first.
#995
KY
Thanks!! Im close to finishing it up. really want to put the 32 ounce tank in. Im using a DLE 55 and ive been breaking it in using the 32 oz tank and she runs for a long time. i followed your postings
your bird turned out nice. how does the DA 60 do? bet shes got tons of power. How does the stock wheels hold up? Ive been watching people fly them on u-tube and seems like they bounce really
easy. i was wondering if the hard foam was cousing it?
#996
My Feedback: (8)
Thanks for the comments Warhawk im really doubting the cause of the bounced landing to be the tires The DA60 is a horse and I just painted the new 3 Blade spinner and prop tips...hoping to fly with the new prop soon. LMK if you need any help
#999
Hope to get to fly mine this weekend. The DA 60 and 22/12/3 prop seem to be a good combo. This thing pulls like a horse. New fill valve came and is installed, still waiting on pilot. I ordered him off of ebay on the 6th of this month and 21 day later I still haven't got anything. I hope I'm not getting hosed on this deal. It is one of the Dragon P-40 pilots. Did any of you guys have to modify the Dragon pilot to fit?
#1000
KY
The Dragon pilot fits fine. its more of an issue getting it to stay in place. and keeping the body parts from moving around. I snaged one off ebay myself. missed the
first two. it was about the same time period. must of been bidding aginst you.. lol
