ESM 50cc Corsair
Old 09-06-2014, 12:09 PM
  #2426
LBJ
My Feedback: (49)
Hi Ron. OK, modified the ad to settle all concerns. I have the ad already on RCU, so this is just a pointer to that ad. If it gets taken down, then that's OK. Just a heads up to those who might be interested on this thread.
Old 09-06-2014, 02:16 PM
  #2427
captainron
captainron's Avatar
Roger on that LBJ............What a beautiful Corsair. I have the ESM also...But it don't look nuttin like yours...............LOL.....Bone stock except I reengineered The whole inside to fit my idea of what and how it all should work in there. TOO bad you have to let it go............lot of work there.
Cheers Captain Ron
Old 09-11-2014, 01:57 PM
  #2428
Peter_OZ
Banned
tip for those with one of these.
Centre section of wing is inherantly very weak, it has a thin poor quality ply spar that has huge cut outs in it.
The ribs in this area have the same issue, poor quality ply and most of the substance has been removed leaving only very small areas of the ribs left to carry the load and they fail!!
Open up the centre section say on the top of the wing and check for yourselves.
Friend of mine lost his yesterday, wing failed in the centre and the model including saito 3 cylinder petrol engine is a total write off.
Old 09-11-2014, 02:06 PM
  #2429
kwik
kwik's Avatar
That is terrible!!! Good grief.
I am thinking of cutting away all the sheeting of the top of the center section, strengthen it up, and sheet it again.
Its quite some work, though.
And one gets a problem with the height difference between center and outer wingpanels.
I reckon one will have to shave off a mm or two from the top of all the spars...and the area in the bend up front over the leg will be a real pain....
I have been thinking of filling the front of the wing with building foam instead.....but unsure of how wise it would be.
Old 09-11-2014, 02:34 PM
  #2430
cosmo21
Bugger,
Mine is ready to go. But I don't want to lose such an expensive plane, cuz of sh&&t engineering.
I was thinking of the expandable foam option as well.
Matt
Old 09-11-2014, 02:40 PM
  #2431
kwik
kwik's Avatar
If the plane is brand new, there shoudnt be a problem?
I had 75 flights with the the first one before the wing ripped apart.
It had been weakened by some VERY hard "landings". It is easy to get a hard landing when you try to get used to those big flaps on a short airfield.
Not to mention a deadstick out in the fields......Started to cracking up in the leading edge.....
This is my new one....but I already had a hard landing with it......arggggh.
Old 09-11-2014, 03:13 PM
  #2432
Peter_OZ
Banned
open top of the centre of wing. Splice heavier spar in place, epoxy carbon fibre to it along its length. Put the wing skin back on and put a layer of 2 oz cloth over the opened section. Sand back smooth. Thickness would be less then 0.25mm
not overy difficult to do and will save your model from turning into a 40lb missile!!
Old 09-11-2014, 03:29 PM
  #2433
esacco
My Feedback: (30)
Mine failed the exact same way...... wing is just Very weak. I got the topflite and it is MUCH stronger with an alloy spar. ESM is just a nightmare here... same with the Stuka.
Old 09-11-2014, 03:37 PM
  #2434
Peter_OZ
Banned
the ESM tigercat has same issue. They cut so much out of the ribs they just pull away under load.
You can probably make a reasonable model out of it but there are a lot of structural mods to be done. Piss poor design work.
Old 09-11-2014, 07:58 PM
  #2435
LBJ
My Feedback: (49)
I have the 74 inch ESM Corsair and have flown it quite a bit under all kinds of conditions. Still holding together.
I wonder if some hard landings have come into play with the failures and also wonder if the ones coming apart have the outer panels glued on or not. I haven't flown my 85" corsair much yet. But like Kwik says, he's flown his old one 75 times to success. Guess I'll be quite aware of what happened before it hits the dirt, if mine comes apart inflight. ha
Old 09-11-2014, 08:19 PM
  #2436
Peter_OZ
Banned
or open it up Lou and have a squiz
its a simple fix!
Old 09-11-2014, 10:35 PM
  #2437
kwik
kwik's Avatar
Peter, which part of the skin are we talking about? To cut away, I mean ? Is it this part, or is it more;
Old 09-11-2014, 10:38 PM
  #2438
kwik
kwik's Avatar
And which spar are we talking about? The one that isnt there, up front, or the main spar?
Old 09-12-2014, 12:34 AM
  #2439
cosmo21
Arrrrrrrrrggghhhhhhhh! Thought mine was now ready to fly.
Wont be flying it until I take the top or bottom skins of and engineer it properly. This f*&(&in annoys me.
I mean I do my job properly, why cant other people?
Would it be easier to open the bottom of wing up I wonder. We'll see.
I guess I got some work to do.
I'll get some pics when I open her up.
Old 09-12-2014, 12:41 AM
  #2440
midastouch_73
My Feedback: (27)
midastouch_73's Avatar
Take a really good look inside there. When I opened mine I notice there was no glue holding the skin to the spars causing it to warp the outer skin. I used Kevlar Carbon fiber and epoxy to cover the inner part of the wings top and bottom. It's solid as steel now and the outer skin doesn't have the ability to flex or warp because it's stuck to the Kevlar. I also used spray in foam to strengthen the area so is solid instead of hollow. I posted pics on this forum of my repair. Instead of cutting the wing open I accessed that area via the radiator covers. You can sand around them and the will come off rather easy. You can reglue them then paint around them when your done. Refer to post 1826 on page 74
Old 09-12-2014, 03:29 AM
  #2441
vasek
vasek's Avatar
That's because you're not a Chinese communist! lol
Old 09-12-2014, 04:40 AM
  #2442
LBJ
My Feedback: (49)
I've read thru the latest comments about failures several times and still not sure what is failing. Is it the spar or the glass covering?
Old 09-12-2014, 04:58 AM
  #2443
splatoman
splatoman's Avatar
Hi I am the one that Peter was talking about. First the plane fly's very well and with the FG84 sounds so good. I spent about 12 months building the aircraft up and doing all of the scale bits on it I could not see any of the problems with the centre section. On the first test flight all was well came in did some adjustments and went up again that's when it happened. On inspection of the centre section we found that the fiberglass was a very dry lay up and that a lot of the ribs were not glued to the skin. The spare was not up to the job at all it would have been at home on a 40" model not on a 85" one. After this and m ESM Tigercat I don't think that I will buy any more.
ID:	2031307   Click image for larger version
ID:	2031308   Click image for larger version
ID:	2031309   Click image for larger version
Old 09-12-2014, 05:37 AM
  #2444
CafeenMan
It went down on the second flight? So sorry man. I've lost a lot of planes but nothing with that kind of money in it. But some with tons of time. I know what that feels like. I wish people didn't make things if they didn't care enough to do it right.
Old 09-12-2014, 05:42 AM
  #2445
CafeenMan
Some people only care about the money. Look around you at work. If you owned your own business, what percentage of the people you work with would you take with you knowing you would get value for what you paid them?
Old 09-12-2014, 05:44 AM
  #2446
CafeenMan
From the photos it looks like everything. The skin is delaminating, the spars are failing, the ribs are coming apart. Normally ribs don't have to do much but shape things, but the spars are probably buckling which helps the skins come loose but the spars and skins together are probably causing catastrophic failure.
Old 09-12-2014, 09:43 AM
  #2447
Anderson Pereira
Perfect to Evolution 7- 77 radial engine!!!
Old 09-12-2014, 08:30 PM
  #2448
cosmo21
That is true.
Old 09-12-2014, 08:43 PM
  #2449
cosmo21
Well, I took the bottom wing skin off fwd of the spar. It come off VERY easy.... Horrifiefing what I found. For starters the glue is very soft, it is not bonded properly, there were several 5mm gaps of fresh air!. The spar is no where near adequate ect ect. I thought I got some pics, but it seems my iphone is playing up. Grrrr.
My fix so far has to be< I made some spar doublers out of 6mm aircraft ply and fitted with Hysol glue, filled the gaps ect, I mixed up a slurry of carbon fibre rovings and polyester resin and created fillets on all the joins between skin and rib, Ive also laid down carbon fibre cloth on all those flexible areas. I will wait till everything is cured. Then I will make another spar out the 6mm ply and place fwd of the main spar. Then I will place doublers on all the ribs in the area. I will then replace top skin using Hysol. After its cured I will fill the voids with expanding foam.
May sound like I'm over engineering, but it's required.
I also have the FG 84 Saito, I don't want to wreck such a beauty.
I reccomed everyone who has this plane to do some investigating.
It is a time bomb tick tick tick.
Matt
Old 09-12-2014, 10:28 PM
  #2450
splatoman
splatoman's Avatar
Hi, I though I would put some more photos of the wing up.
And this was the FG84 at the front.
ID:	2031514   Click image for larger version
ID:	2031515   Click image for larger version
ID:	2031516   Click image for larger version
ID:	2031517   Click image for larger version
