Reload this Page >
Fliteskin Ta-152 H1
View Poll Results: A poll
Foam 2 piece wing.
13.74%
Built up 2 piece wing.
23.66%
Foam 3 piece wing.
16.79%
Built up 3 piece wing.
45.80%
Voters: 131. You may not vote on this poll
Fliteskin Ta-152 H1
Old 03-12-2015, 12:18 PM
  #326
alanc
Looks superb, well done sir, i am just about to let loose with my 2nd kyosho version, yours is awsome, Regarding the V gas engine, i know laser are experimenting with gas fourstrokes, fingers crossed for a V motor, with decent carb
Old 03-12-2015, 12:38 PM
  #327
JGrc
My Feedback: (29)
JGrc's Avatar
Thank you for the kind words. It would be nice to see a gasoline Laser!
JG
Old 03-23-2015, 10:16 AM
  #328
JGrc
My Feedback: (29)
JGrc's Avatar
another flyby pic, need to fix that tail retract and get rid of the spark plug wire!
JG
Old 03-23-2015, 12:05 PM
  #329
vertical grimmace
vertical grimmace's Avatar
JG
Very nice! The tail wheel did not retract anyway. It was supposed to, but malfunctioned. I did not even bother putting the retract mechanism in mine.
Old 03-23-2015, 12:12 PM
  #330
JGrc
My Feedback: (29)
JGrc's Avatar
tail retract never was never functioning in the full size? I thought I saw a pic with the tail retracted but maybe it was a D9.
J
Old 03-23-2015, 12:15 PM
  #331
vertical grimmace
I do not have a pic of a full scale flying, and I have a lot of books. It is documented though that it did not function. German aircraft are known for having tail wheel retract issues throughout the war. Even the ME 109
Old 03-23-2015, 12:40 PM
  #332
JGrc
My Feedback: (29)
JGrc's Avatar
but it would look so cool!
Thanks!
JG
Old 03-23-2015, 12:45 PM
  #333
wurger
Vertical Grimmace is correct. The full-size 152 suffered from defective retracting tailwheels all their (shortish) life. I cannot give specific references at the moment, but I have been researching the 152/190 in depth since c1974....... HTH :-)
Old 03-23-2015, 03:17 PM
  #334
fw190
My Feedback: (37)
So the guys fixed the tail issues, now you can fix the spark plug by just banking the plane a little bit when they take pics, so you don't see it in the picture... plus it always looks kewl seeing some of the top wing.
Old 03-23-2015, 03:28 PM
  #335
vertical grimmace
David Andersen notes in his construction article RCM November 1997, that this particular publication speaks about the tail wheel issue. This info may be necessary for anyone entering a TA 152 in competition.
http://www.goodreads.com/book/show/2...ke-wulf-ta-152
As far as the spark plug wire goes, It may bother some, but again from a competition side of things, parts of the engine such as this have to be ignored by the judges.
Old 03-24-2015, 01:04 PM
  #336
deatonbt
I found the following info on the tail wheel retraction problems in "Focke-Wulf Ta 152 The Story of the Luftwaffe's Late-War, High-Altitude Fighter" by Dietmar Harmann; ISBN 0-7643-0860-2.
In a report from front line unit III/JG 301 it is mentioned that there are problems with retracting the tail wheel. The cause is unkown, but the load on the hydraulics could be to high. Also, the rollers on the retracting mechanism were jumping out of the tracks.
Brian
Old 03-24-2015, 01:58 PM
  #337
JGrc
My Feedback: (29)
JGrc's Avatar
Thanks guys!
I just found this book on Ebay
JG
Old 03-24-2015, 04:45 PM
  #338
invertmast
My Feedback: (23)
invertmast's Avatar
Brian
i highly doubt the load on the hydraulics was the problem, this would of been accounted for in the design of the hyd. System.
But, the way the tailwheel retraction cable on the Ta-152 is done would be very problematic if any twisting if the roller was encountered or the tracks were incorrectly spaced which would allow the roller to pop out.
The Jg301 account was fairly early in the 152's service life snd no other commention is made about tailwheel retraction issues, so it is possible it could have been fixed. Honestly, their are more questions than answers when it comes to many late way German aircraft, which allows us to do what we expect based on known documents.
Old 03-24-2015, 05:11 PM
  #339
vertical grimmace
Early in the service life? The duration was what, 2 months? How many units operated the TA 152? 2 maybe.
Old 03-24-2015, 05:15 PM
  #340
invertmast
My Feedback: (23)
invertmast's Avatar
Alot can happen in two months
Old 03-24-2015, 05:40 PM
  #341
vertical grimmace
True that. I had planned to make mine functional, but did not want to deal with any reliability issues from the Sierra unit I have. Well, I guess it would have still been scale!
Old 03-24-2015, 08:00 PM
  #342
JGrc
My Feedback: (29)
JGrc's Avatar
I'd like to make mine functional since it looks much the part and the rest of the arguments are debatable.
The problem is the Sierra air cylinder is too short and if you mount it in the scale position, it doesn't even retract half way.
The solution will be when we design a truly scale tail retract (I'm working on 100% scale mains in 1/5scale at the moment). If I can find a longer cylinder to replace the stock Sierra, it may work.
JG
Old 03-25-2015, 07:35 AM
  #343
invertmast
My Feedback: (23)
invertmast's Avatar
JG
Ive got a 1:1 drawing of the fullscale main gear struts and scissors already that can be scaled to any size necessary. Im actually going to be placing the order to my machinist for my 1/4 scale struts mid to late april. If you want, i can resize my drawings for 1/5 and get a quote on them for you.
Old 03-25-2015, 07:40 AM
  #344
vertical grimmace
Check McMaster Carr for Bimba cylinders. They have a ton of different sizes.
Old 03-25-2015, 09:26 AM
  #345
JGrc
My Feedback: (29)
JGrc's Avatar
Thomas,
thanks for the offer, I wished we I had known before but I have been working on this quite a while. All the parts are now being CNCed by a friend in WA and a wing mock up will be built to try the retrofit process. The correct pintle angle and rake is built in and will bolt to the main spar.
The down lock parts are for the A and D models though not for the 152 and will be driven by a linear servo.
VG, I will try Carr see what they have.
JG
ID:	2084066   Click image for larger version
Old 06-01-2015, 08:48 PM
  #346
JGrc
My Feedback: (29)
JGrc's Avatar
Finally I was able to shrink the video and post (I hope). Third flight March 2015, still pretty shy about flying the new airplane!
Some changes were made on set up after the first few flights, reduce the rate and expo to 40%. Also increase the aileron differential from neutral to 20º up 15º down.
https://youtu.be/AodWwKQQsm4
Hopefully better quality videos will come later.
JG
Old 06-01-2015, 09:00 PM
  #347
dgiatr
dgiatr's Avatar
https://www.rcuniverse.com/forum/AodWwKQQsm4 Hopefully better quality videos will come later.
JG
OK!!!!!
We have been looking forward for that video for a long time !!!
very nice!!!!
One of the most beautiful planes.
Old 06-01-2015, 09:10 PM
  #348
fw190
My Feedback: (37)
Very nice Jose and the DLE 55RA moves it right along
Old 06-01-2015, 09:30 PM
  #349
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Awesome.....
Old 06-02-2015, 01:13 AM
  #350
w1nd6urfa
w1nd6urfa's Avatar
Very nice Jose, great plane flies gracefully
Thanks for sharing!
