RE: Ziroli Stuka
Yes, its supposed to read the same way from both sides.
Holy smokes thats some dark black on black! You are right even with the flash I cannot see it clearly. |
RE: Ziroli Stuka
Just ordered my Ziroli plans and kit from Precisions Cut Kits today..... Looking forward to hiding in the garage this winter building it...
Any suggestions would be welcome! |
RE: Ziroli Stuka
what motors are you guys using.are the landing gear robart struts?I am looking to build a warbird that doesnt require retractable gear.this plane looks like you can scare spectators lol.
RE: Ziroli Stuka
G62 with Sierra struts designed for the Stuka (http://www.sierragiant.com/prod40.html)
RE: Ziroli Stuka
1 Attachment(s)
The Sierra struts are a work of art. I convinced a friend to buy a set at this year's Toledo Show. He's glad that he did.
Another friend had the JCWhitney siren, the smaller one. It's mounted under the fuselage belly, and the sound is quite audible. I have a Walker Sachs 4.2 in mine, but I haven't flown the model, yet. I can't comment on the performance, but I did need the larger motor for nose weight. |
RE: Ziroli Stuka
Tom,
Every time I see your Stuka in the snow, I have to look a couple of times, you did a fantastic job on that bird. |
RE: Ziroli Stuka
Are there any Foam Kits of a Stuka???
This is my FAVORITE Warbird and would love to have an Electric Flyer of a Stuka Any Help Guys would be great |
RE: Ziroli Stuka
There used to be a Flying Styro foamie, a smaller one.
Rumor has it that there may be a larger Stuka in foam from Parkzone some time in late 2010. |
RE: Ziroli Stuka
That would be KILLER Merlin
Ill keep my STUKA fingers crossed Thanks Bud |
RE: Ziroli Stuka
ORIGINAL: stavman11 Are there any Foam Kits of a Stuka??? This is my FAVORITE Warbird and would love to have an Electric Flyer of a Stuka Any Help Guys would be great |
RE: Ziroli Stuka
Didnt see anything on kyosho
got a link by chance????? |
RE: Ziroli Stuka
http://www.kyosho.com/eng/products/r...uct_no_1=56509
I'm not too sure about the fuse, it looks REALLY long... |
RE: Ziroli Stuka
Ok - before I pull the plug... G62 or DA50...?
RE: Ziroli Stuka
G62. Its a bit heavier than the DA50 making the bird a bit easier to balance.
The DA50 would fit in the cowl better. But I would go DLE55... |
RE: Ziroli Stuka
I guess I should preface this by saying that I've never run fuel engines before... I have an ASM P-61D (Electric conversion), TF P-47D (Electric Conversion), 60 size Cessna 421 (Electric Conversion), and the list goes on... but can't bring myself to put an electric motor into this plane... so I'd like the most hassle free motor with the best fit.
Thanks, Chuck |
RE: Ziroli Stuka
The G-62 probably wuld be the most hassle free. It has a long history of reliability, and good customer support.
Problems arise when trying to fit everything inside the cowl. I understand that an adapter is available that allows the carb to be moved, and therefore hidden. Mufflers/manifolds, are another problem. Most seem to be too wide to remain enclosed. I have a Slimline on my 4.2. Only one mounting bolt protrudes, which I hid under a non-scale blister. |
RE: Ziroli Stuka
Found the Stuka
Thundertiger makes one Getting an account set up today so I can Order Direct Sweet Thanks all Stav |
RE: Ziroli Stuka
ORIGINAL: TomCrump The G-62 probably wuld be the most hassle free. It has a long history of reliability, and good customer support. Problems arise when trying to fit everything inside the cowl. I understand that an adapter is available that allows the carb to be moved, and therefore hidden. Mufflers/manifolds, are another problem. Most seem to be too wide to remain enclosed. I have a Slimline on my 4.2. Only one mounting bolt protrudes, which I hid under a non-scale blister. |
RE: Ziroli Stuka
1 Attachment(s)
I'll be the third guy to vote for the G-62 in the Ziroli Stuka. It is the most hassle free engine on the market for this size airplane. Every one of the Zenoah G-62's is the same. They all run flawlessly out of the box and you'll get years of service from them. It will comfortably swing a 22 X 10 where the DA-50 is a little more complicated engine to install and it only handles a 21 X 10.
Here is my G-62 in a Ziroli Stuka. Slimline Pitts style muffler as mentioned by someone above. You can see the muffler protruding out on the port side just a little. It's not bad. I put a 1/4" plywood spacer behind the prop so that the engine fins did not his the front of the cowl. It works well. Leo |
RE: Ziroli Stuka
Thanks - the photos really help! Ok.. G62 it is.
Another question... for covering I see a variety of different weights on the glass cloth.... looks like there's 3 of you that have built these.... what's the concensus on cloth weight? Also Stuka Barry - sent you a PM regarding the engine. Thanks again, Chuck |
RE: Ziroli Stuka
Another question about the photos - it looks like you have the carb adapter on this..... is that the case?
Thanks, Chuck |
RE: Ziroli Stuka
ORIGINAL: cdbtx Thanks - the photos really help! Ok.. G62 it is. Another question... for covering I see a variety of different weights on the glass cloth.... looks like there's 3 of you that have built these.... what's the concensus on cloth weight? Also Stuka Barry - sent you a PM regarding the engine. Thanks again, Chuck 3/4 to 1 oz. glass cloth will work. BTW, Since you're going with a G62 you could use a 22" 3-blade prop and make it look more realistic. I put a Bolly 22-10 3-blade on my 32# Ziroli Dauntless (G62) and am still amazed at how well it hauls the model around. RPMs are much lower and it sounds like a four-stroke, but it flies great. Jim |
RE: Ziroli Stuka
A friend flies his G-62 powered Stuka with a 3 blade 22" prop, too. The Zenoah handles it well.
I used .58oz cloth, when I glassed mine. |
RE: Ziroli Stuka
I used .5oz cloth for my outer wing panels and 1 oz cloth for the center section and around the strut legs.
RE: Ziroli Stuka
1 Attachment(s)
ORIGINAL: cdbtx Ok - before I pull the plug... G62 or DA50...? The G-62 can be a shaker. (((( [:o] )))) But I love it also. It's also in a big round cowled Gee Bee, and nothing hangs out. That's important to some scale people. Ed |
