Redcat Racing Volcano Thread
#1277
Banned
RE: Redcat Racing Volcano Thread
ok i need some more help here, when sitting in nuetral without applying the brake my wheels spin like crazy shouldnt they be "in nuetral"
any help would be greatly appreciated.
also if anyone is from or around woodhaven michigan lets hook up,im riding by my self right now.
#1279
AZ
if your idle is low and your car wont stay running, put it on some blocks, when you start it and it runs with the wheels spinning, and then you put it on the ground and the wheels stop and the engine cuts (this is with low good idle) then the clutch spring probably broke
#1281
AZ
sometimes they do, but if you get the traxxas higher stall spring it gets better take off, i would recommend it even if its not broken
#1282
Banned
cool i will have to get one then,and are they easy to install.i mean ive done a decent amount of work on real cars so this should be a breeze right...well maybe not a breeze but it cant be that hard
ps i searched for traxxas higher stall spring on ebay and cant find it,is it called something else maybe.
#1285
AZ
you need to use the stock clutch shoes, or find some other ones that fit, i have seen some around somewhere. but the ones that come with the spring wont fit
#1287
ORIGINAL: wingedwheel-0420
ok i found the part.do i need to install the clutch shoes with that as well.
#1290
hey guys. i had my truck running two days ago and it was fine. I put in a new spur gear and now when i start it it will run for 1 second and then the pull start will pull back into itself. Anyone know whats goin on?
#1291
NJ
ORIGINAL: tazzman52304
i have the volcano and was told that the t maxx shocks are good, but i did not get a part # can someone help me get a part #
#1292
Banned
ok get this earlier im driving my s30 no problems decide to give her one more run b4 night falls and all of a sudden on start up it justrevs up super high wheels just a spinng,i get it under control and try adjusting the high needle and nothing , gave the low a slight turn each way and nothing its just going berzerk. can some one please help me out with this. its really starting to get to me .oh yea and im on my 4th glow plug is that normal.
#1293
Banned
ok if anyone wants to buy a volcano s30 email me at [email protected]
im pretty much done with this it now just revs up and up controls dont respond cant get much help with this so im calling it quits it hasnt even had 2 full quarts ran thru it.i just have no idea what to do.with out ever touching the screws it goes haywire and the will not respond so maybe someone with experience will want this bad boy. i have only had it one week now.
#1294
Banned
ok dont mind me with the ranting i know this hobby calls for patience and im working on that,i finally get her going and the damn pull start comes apart.im starting to think the guy at the hobby shop was about having nothing but problems with these darn things.this is craziness.
#1295
AZ
dude i used to feel the same way, everytime i went out i would run a tank or two and something would break, and then you bet better and better and now i go out everytime and never break one thing. i havent broke anything myself in months. trust me it will get better. you will learn you truck and when something goes wrong you just fix it real quick and your cruisin again
#1296
MN
ORIGINAL: tihstae
it's not always that something is broke either, sometimes it just needed to be tweeked, like bent drive shafts, just use a hammer and straighten them out. The reason stuff breaks is driver mistakes, and incorrect maintenance, the more experienced you get the less stuff you break.
#1299
Banned
ok seeing i have so much down time at the moment i decided to paint my truck black put some detroit red wings stickers on it,upgraded my air filter to a savage xl and a savage xl 160 cc fuel tank,and put a t-bone racing bumper on it.thats about all for now. im waiting for a new receiver switch and pull start and i should be good to go.i think i got this patience thing down pat. WOOT WOOT!
oh yea and once the funds are sufficient im going to get the trans upgrade from allaboutfunhobbies
