Redcat Racing Tornado Thread
#2702
SC
RE: Redcat Racing Tornado Thread
gOTTA QUICK QUESTION, I bought some traxxas wheels, with the 12 mm hex. They fit but the back spacing is to deep on the fronts. I was wondering if they make some thing to extend the axles, i just need about 1 inch per side. Thanks jeff
#2703
KY
3 questions-
1. will the tornado bb or xp shocks fit on the shock wave?
2. will the tornado bb or xp chrome rims fit on the shock wave?
3. what is the distance between the 2 bottom screw holes on the vertex .16 back plate that comes with he rtr shock wave?
thanks dudes
thanks dudes
#2704
ORIGINAL: numskull223
#2705
Hey im totally new to the gas rc cars and am having trouble getting my car to shift. i have a redcat tornado xp. i checked my clutch spring before and it was broke but i fixed it and it still did not shift. i dont know how to fix it or what i should check first. i dont know much at all about these cars but i dont remember it shifting even when it was right out of the box. let me know asap if you know what it is or what i should check first. it could be possible i didnt fix the clutch spring right but i have no idea. so help me out if you can... thanks.
#2706
OH
this problem is too common. on your trans. there are two set screws one locks the hub in place and the other is for shift points. if it's stuck in first gear turn the shift point set screw out 1/2 turn at a time and test it it can be a long and painfull process if it's in 2nd gear just do the opp. this is why most of us go with the single speed trany. hope this helps anyone eles have some info if i'm wrong wich i think i'm not
#2707
SC
ORIGINAL: Hibityhupla!
cut and paste at ebay.. - 12MM HEX WHEEL EXTENSIONS FOR TRAXXAS STAMPEDE VXL
#2708
ORIGINAL: huejohnson
#2709
PA
I'm a newbie to RC Nitro cars and I have a problem. When I run my Shockwave in the grass I loose all power to the wheels. The buggy seems to get more and more slugish until I can go full throttle and it just sits there. The engine revs, but no power at the wheels. I will stop running it for some time and the problem goes away. Any Ideas on what is wrong?
-DAK
-DAK
#2710
ORIGINAL: dak70
-DAK
-DAK
#2711
BC, CANADA
1 Post
ORIGINAL: dak70
-DAK
-DAK
that could be a buntch of things... Spurgear, Diffs, Differential pinion gear, Drive cup (had the grub screw come loose and the cup would just spin) or a broken shaft... so check all of thows things and report back with photos if you can...
-Cam-
p.s. the Diff pinion gear would be located behind the diff. when you pull the diff out the gear will be right behind it, it will be held in by a "E" Clip and the way to get them off is take a pare on Needle nose plyers and squeze it shut and put it in the open part and open the plyers and it should come right off, may take some time and "E" clips are notorious for springing in to the un-known... so try not to loose any... if you do take one off some ware elts, they are all the same size except the clutch it uses a big one...
#2714
OH
I've been into rc cars for a long time, now my son is into them. So for his first car i bought him a shockwave. I've upgraded the shocks,clutch,clutch springs, a few other small things, and of course the motor to O.S .18. But with this car something keeps happening that I've never seen before, the bog bones keep snapping in half. At first I thought it was something that he was doing. So I fixed it then I took it for a drive, I drove it around for a while with no problems untill i put it on the track. I was sitting on the front stretch and put the hammer down the car moved about 10 feet. this time 2 bones broke. I've looked through all my books and all my notes and can't find anything even similar, and nobody I,ve talked to has anythig stronger. So what I'm asking is has anyone eles had this problem or know of where I can find stronger dogbones. Thanks for the input
#2715
KY
once agian i must say redcat needs to manufacture and sell diamond parts. those dog bones wouldn't break if they were made of diamonds!
#2717
i've had that happen too. It will either happen when a rock gets stuck somewhere it shouldn't while moving or they will bind if you have it set to high with stiff suspension. It sounds like you getting it moving and it gets stuck with all that force and "snap".
#2719
OH
the suspension is set very soft with 40wt. oil and as for stones there is none my back yard is all clay and my track gets groomed before every use. the only thing I can figure is torque and tons of it.
#2720
#2721
CA
Hi, im super newb at this nitro rc. I have a tornado xl, and I bought an O.S. .18 CVR for it. doesnt have the flywheel, clutch shoes, bell, or any of that, just the engine. Can someone tell me what parts i need to get that will make the CVR compatible with the tornado? I called hobby people for help but they don't carry redcat stuff so they couldn't help me much. I am looking preferably for lower gearing. if anyone has links to the parts, that would be real nice. Thanks
#2722
AR
I got all my parts in today for a 2 speed transmission, cup a, cup b, and steering set a. I put the 2 cups/ends on the transmission WITHOUT lock tight so I could get them off if a gear was to strip (unlike stock that was lock tight on forever). I was meshing the motor and the transmission today, but was unsure if I did it properly. I put a strip of paper .5 inch long around the spool, then pushed the motor with the muffler mount on the engine snuggly against the transmission, and screwed the motor screws in tight. I am wondering if I properly meshed it when I pressed on the muffler mount to get a good fit. Is there any way to test the mesh after the motor is mounted? Should I be pressing on the motor in a different spot to get a good mesh?
Thanks.
Thanks.
