Redcat Racing Tsunami Thread
#627
RE: Redcat Racing Tsunami Thread
HI I was just wondering if there is anyone who can help me out i want to take the piston and rod out of my sh 18 but I cant seem to get the rod off the crank. Any help?
#628
You have to take the sleeve out first. Then you can pull on the con rod to sepereate it from the crank. Once its seperated you push the piston through the top.
#629
thats the problem man I cant slide the con rod all the way off the crank I can ge it to go about 2/3 of the way then it gets hard to I don want to force it off
#630
I don't suppose anyone can give me a parts list to go one speed with my Tsunami. I've tried ordering from Clermont but they are out of stock on the kits. If I had part #'s and manufacturer I would (hopefully) be able to buy them locally. I am going to basically be bashing my 'Nami and from ehroof says direct drive is the way to go. Thanks
#631
BC, CANADA
for now just tighten the shift scew all the way so it dosent shift. redcats site shows what clutch bell to use with the one speed. its just a steel clutch bell.
#632
TN
ORIGINAL: imanurd
1 x RCE10423 13 Tooth Vented Racing Clutch Bell
1 x 05126 Single Speed Transmission (Center Gear Box)
#633
Does anyone know when Redcat is going to be getting in repair parts for the Tsunamis in? I am in need of a couple dogbones for an ultrawide and they are sold out and have been for sometime. Or better yet, is there an alternative source for 115mm dogbones that I can use instead.
#634
Wow should I set my suspension on redcat tsunami if I use it on the street? Should it be hard or soft? It set soft now and roll it twice, busted back hub and rim.
#636
DE
can anyone tell me if there are any other axles i can sub for the redcat ones? on their site it says they are out of stock.
Thanks in advance.
Thanks in advance.
#637
CA
ORIGINAL: ddnbc
Thanks in advance.
Thanks in advance.
i found some today..rufaster.com & clermont
#641
Hi everyone, I just purchased a Tsunami ultra wide the other day and finished breaking it in this afternoon. I was curious what glow plug works best for it. After the break in, the glow plug was burned out and the owner of my local hobby shop sold me the OS A3 glow plug and told me that it was fine for it. Because I am only familiar with the Classic T-Maxx and their glow plugs, I was thrown aback when the glow plug they sold me was significantly different than the stock one.
Any suggestions??? [sm=71_71.gif]
#642
i use the os a3 and love it, use it in all my .18 and smaller engines.
I just got my ultrawide a couple of days ago, weather wont let me break it in yet, how do you like it, i think the suspension looks awesome.
#643
Thank you for letting me know about the glow plug.
The suspension is awesome! The break in went smooth and easy. It sure is a nice RC. Tried a couple of times to flip it and just could not get it to. I want to switch out the tires for some beefier ones though - my only complaint. Let me know what you think of it when you get a chance to run it.
#644
Are the cvd shafts fairly durable? and when do you know if you should use a hot nedium or cool glo plug? I put a hot plug in my max cvrx 18 and it seems to be working the same as the a3 plug.
#646
oh lol. When do you want a cooler plug? under more compression? I totally re did my sh 18 and even decked it for more compression and want to know what plug would be best for that ingine now.
#648
sometimes you want to use a cooler plug for higher % nitro's. The cvd's for the volcano sv is the same for the pro.
http://www.redcatracing.com/itemdeta...?partno=188015
