REDCAT TORNADO XP 2 SPEED
MO
Are these little buggys very good? I just ordered one from a guy on e-bay, iiis it pretty easy to get parts for? before i run it i am going to lock-tite all the nuts on the buggy. What about break-in procedures, how do you guys think i can break it in with out harming the .18 engine. i will be using 20% nitro.BOBCAT
it a good and fun buggy, just upgrad the clutch bell and spring, here is the link, its the second post with the information, parst are easy to get, i get all mine from clermontmotorsports.com and there are some that are compatable parts too from different companies.
http://www.rcuniverse.com/forum/m_5342050/tm.htm
its a pretty good buggy just make sure you loctite everything and you may wanna change out your clutch bell and clutch spring the clutch bells from the factory are out of round and the springs seem to break easily but if you do that you should have good service out of your rig check the clutch bell post at the top of the forums it has all of the info there i'm runnin the bell/pinion gears w/the teflon clutch and its great
if you need parts for it there is
www.clermontmotorsports.com
www.allaboutfunhobbies.com
www.redcatracing.com
www.himotoracing.com
and for misc parts is
www.towerhobbies.com
they are really nice for the money. break it in slow, also richen it up alittle before you drive it, mine came in a little lean and i dont have very good compression now.
they are hard to get to stay running so get a big parkinglot and make slow laps for the first few tanks, alittle faster than idle. the engines are so tight that it will not idle very good at first.
also get you a hpi clutch bell cause the stocker is probly out of round( will eat up your sper gear).
and some bigger street tires like in my profile. proline speed hogs i think is what i got. makes driving on the road great and it also has a better more ballanced feel to it.
and you must get a clutch spring. i dont notice much differance in the traxxas $8
and the cheap pair for 3.
but you will need one.
a cheap servo will also be nice to have laying around cause i burned up 1 in my tornado and 1 in my hurricane. itsd bound to happen cause the stockers suck
http://www.rcuniverse.com/forum/m_5342050/tm.htm 2nd post
heres all the info on the stuff you will need.
this servo would be sweet in that buggy though, but i have the cheap o $10 in mine i just ordered this one for my hurricane
http://www2.towerhobbies.com/cgi-bin...&I=LXDWF8&P=RF
anythings better than the stockers
I own a REDCAT TORNADO XP 2 SPEED and I have had it for almost 2 weeks I have ran it through about 2 quarts of nitro. Now my engine seems to go half speed at full throttle and I have no clue what the problem is. Maybe because I was not using air filter oil. Any help would be apreciated. Thanks
