Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
only 2wd??!?!-Help?!!?
Old 03-31-2007 | 07:34 PM
Default only 2wd??!?!-Help?!!?
http://redcatracing.com/itemdetail_p...p?partno=08060 I was drivin and this part FELL OUT!!! and i didnt realize it for a while that i was driving with 2wd instead of 4wd. Is that bad, and can i drive it in 2wd while im waiting for hat part to come in, and how could this of fell out? Is that all i need?,,
Old 03-31-2007 | 07:36 PM
Default RE: only 2wd??!?!-Help?!!?
Is the universal joint still there with the grub screw?
Old 03-31-2007 | 07:50 PM
idk it looks like its just the straight rod but where is that part that u said?
Old 03-31-2007 | 08:38 PM
It is what the straight rod goes in IT looks like this. It is either one of these. I painted my rods yellow so if they fall out they would be easier to find. You have to make sure these things are screwed on tight . Use blue locktite on the grub screws.
Old 03-31-2007 | 08:48 PM
ok thanks but is it bad to drive with 2wd on my Sv?
Old 03-31-2007 | 08:56 PM
not at all, i like 2 do fwd burnouts with my tornado. and doughnut are kinda fun 2. i only run it on the street btw, the 2sp always messes up in the dirt
Old 03-31-2007 | 09:27 PM
you can run 2wd no problem, just wont handle as good
Old 04-01-2007 | 07:32 AM
its no problem to run 2 speed bro i did for a while when before i found this website and was still ordering parts from exceed believe you'll learn to refine your drivin skill s doin it cause it dont handle as well
Old 04-01-2007 | 03:34 PM
ok thanks guys but anyway, i took it apart and i need teh rod and the part the rod goes into in the front of the car, i think its the part with the grub screw but theres universal joint A and a universal Joint B, which one?
Old 04-03-2007 | 06:21 PM
Come on please help, i need http://redcatracing.com/itemdetail_p...p?partno=08060 that part but idk which one of these, i need the one that connects to the transmission shaft then to the front gear box.
Is it
http://redcatracing.com/itemdetail_p...p?partno=02034
http://redcatracing.com/itemdetail_p...p?partno=02032
http://redcatracing.com/itemdetail_p...p?partno=02016
wut one, Thanks very much
Old 04-03-2007 | 06:32 PM
what car are you talking about? and do you mean the shaft that goes form the center diff to the front diff and the holder with the grub screw on it for the front diff?
Old 04-03-2007 | 06:33 PM
The SV i heard its the B one but im not sure
Old 04-03-2007 | 06:36 PM
it the b one that mounts on the front diff, i just ordered some myself: http://www.clermontmotorsports.com/s...B-*2PCS/Detail
Old 04-03-2007 | 06:40 PM
aight thanks a bucnh
Old 04-03-2007 | 06:43 PM
your welcome, good luck
