Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
problem
Old 04-10-2007 | 06:43 AM
Default RE: problem
ORIGINAL: MiniCwik
Should get the HPI A886, it's what I have and has two sets of the spring/tension clips.
Gold = high stall rate
Black = standard stall rate
http://www2.towerhobbies.com/cgi-bin...86&FVPROFIL=++
The HPI A885 is a good set too (but still has a wrap around spring) adjustable stall rate by cutting the clutch shoes.
you dont adjust the stall rate by cutting the shoes, it comes with 3 holes to put the clutches in and depending what hole you put it in gives you the different stall rate.
Old 04-10-2007 | 06:48 AM
MiniCwik's Avatar
Default RE: problem
Okay, maybe not on our rides it's not necessary but I was speaking from manufacturer instructions:
http://www.hpiracing.com/graphics/instr/a885.jpg
Cutting them reduces their weight, thuslly increasing engagement speed
Old 04-10-2007 | 06:51 AM
Default RE: problem
wow, i have that in my hpi and never seen that, i read the instructions too, lol.
Old 04-10-2007 | 06:57 AM
MiniCwik's Avatar
Default RE: problem
So I guess we do learn something new every day :LOL:
Old 04-10-2007 | 06:59 AM
Default RE: problem
yes we do,
Old 04-10-2007 | 07:00 AM
  #31
MiniCwik's Avatar
Default RE: problem
I know I do every day on this forum [8D]
Old 04-10-2007 | 08:27 PM
  #32
Default RE: problem
so should i put it in the third hole ( or letter C in the instructions) for better low end?
Old 04-10-2007 | 08:29 PM
  #33
Default RE: problem
ORIGINAL: MiniCwik
BTW great info thanks
Old 04-21-2007 | 06:25 PM
  #34
Default RE: problem
Ok i finally replaced my clutch shoes and springs. What they looked like when i took them off.
Hpi racing clutch's spring was pain in the butt to keep two sides connected. I also tried to install 13/18 clutch bell but no luck. Couldnt figure it out.
Old 04-21-2007 | 06:32 PM
  #35
Default RE: problem
get the firestom clutch it fis coz i have it in my volcano.it is perfection nicely fitted in.
