Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
quick engine question
Old 08-09-2007 | 06:56 PM
Default quick engine question
Im having a little trouble getting my engine to start after the truck is warmed up. when its been sitting a while i prime it a little and it starts up on the first pull every time. But when i try to start it back up after its warm i cant get it. whether i prime it or not at this point doesnt seem to matter, it just doesnt wanna start. if i let it cool down for a short while its no problem again. Is this common? not quite sure how to fix this problem.
Defm
Old 08-09-2007 | 07:02 PM
AllAboutFunHobbies's Avatar
Default RE: quick engine question
What is the engine temp?
Old 08-09-2007 | 07:12 PM
sounds like a blown engine, how is the compression when its warm, if its really low, the engine is blown, you can try to run it a little richer to comensate for the low compression and it may start better
your running extremely hot
Old 08-09-2007 | 07:29 PM
I'm thinking running hot. I had a guy kept calling me about how it wouldn't start when it was hot and it turned out he had the thing running at like 250-270 degrees, since they have plastic carbs he wasn't getting boil off at the carb but when he tried to start it after stopping it wouldn't start because the fuel was actually boil off when it hit the crank shaft below the carb and since it wasn't running there wasn't enough flow to keep it running like it was so the fuel boiled off.
Old 08-09-2007 | 07:51 PM
I really dont think its blown, it runs extremely good right now. Im thinking im running it to lean, ill richen it up. thanks guys
Defm
Old 08-09-2007 | 07:54 PM
do the spit test if you dont have a temp gun, put some spit or water on your finger and wipe the head, if it sizzles, pops and evaporates right away then its too hot, if it take 3-5 seconds and evaporates slowly your ok.
Old 08-09-2007 | 08:25 PM
ok i was definately running lean and hot, i opened up the low and high about a half turn each, maybe a little more. lots more smoke. its dark now so ill have to wait till tomarrow to do the spit test and see if it starts up fine. thanks again guys !
Defm
