Himoto Cheetah Help
Well i got it all tuned up i even took out the baffel in the pipe its got some serious power now but i lost controle and smashed it up and broke the part that goes from the lower controle arm to the upper now i have to try to fand another one. Is there an upgrade for that part?
the diffs are pretty strong. they are metal gears.
heres the part you need: http://www.clermontmotorsports.com/s...s-*2PCS/Detail
That is the front that I broke. They make aluminum ones. Just get a few extras because I think thats the weak link in the front end. It sure isnt the flimsy a arms. If you get aluminum you will move the weak link somewhere else. Its easier to change the c hub than to change the whole a arm.
#31
exactly, i dont believe in aluminum, look at all my cars, all plastic, i would rather change a cheap and easy plastic part then an expensive hard to get to part.
#33
Nope. They are slow. Go through Clermont or allaboutfunhobbies. They will have what you need and you will have it in a few days. Both take paypal also. Never had a problem with either company.
#34
Is there anything els I can do to make this thing better? I bought some high torque servos for it to replace that shorted out one. Its a futaba works great. Should it be able to spin the tires off the line on damp pavement?
