Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Engine Temperature
Old 01-04-2008 | 03:53 PM
Default Engine Temperature
Hi ii'm from Puerto Rico, two days ago i use first time my Monsoon, i do the brake in proced very wel, but after i setting my engine for performance it is very fast and powerful but never past of 190grades, it is normal? i think i need more temperature right? if is yes what i do incorrect? My Monsoon hace smoke every time, quikly response, never blow a glow plug, i use 20% nitro gas. Pleas help me i not like blow the engine, thanks and sorry for the bad english....
Old 01-04-2008 | 08:11 PM
Default RE: Engine Temperature
if its running good and powerful dont worry about it, if its 190F.
Old 01-04-2008 | 10:19 PM
In other threads some people explain to me that the best temperature are from 200 to 250 but mine never reach the 200
Old 01-04-2008 | 10:25 PM
If you lean it just a tad to get temps up about 225 it will be fine. Just turn in teh high speed needle about 1/16 turn at a time. What is your outside temps.
Old 01-04-2008 | 10:34 PM
In Puerto Rico is about 80-98F all year
Old 01-04-2008 | 10:37 PM
honestly, if its running good then dont worry, 190 is close enough to 200. you usually want 200 and over to break the engine in but if you broke it in already just run it.
Old 01-04-2008 | 10:38 PM
See if you can lean it out just a tad on the high end needle. If not then dont worry about it.
Old 01-05-2008 | 07:59 AM
Thanks people for the help, today i go to the park and check the needle
Old 01-05-2008 | 11:15 PM
Ok, im setting todya the engine with the new JP3 header and muffler and the temp go up at least 225degrees, i think now is better, i lean a little bit the engine ang go more fast... thanks for help
