Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
diff gear
Old 01-16-2008 | 01:05 AM
Default diff gear
my son stripped the diff gear this evening on his volcano was there a reason for this already? 3rd time out just got it just put new plug in it was running great going thru the snow with no problem then just stopped going forward with engine running but no drive. took top off and gear was warn down???
Old 01-16-2008 | 01:23 AM
Default RE: diff gear
did you make sure the gears meashed properly before you drove it???
Old 01-16-2008 | 01:31 AM
2 other times we took it out no problems so i assume they were ok
Old 01-16-2008 | 04:35 AM
Macanan's Avatar
With this sport/hobby you need to add blue locktite to all metal to metal screws, or the motor will vibrate them lose, including the screws that hold the motor down, the c cup grub screw's, if it has a 2 speed tranny in it the 2 way drive clutch grub screw's.
Old 01-16-2008 | 06:54 AM
BTW- thats a spur gear not a diff gear. The diff gears are unadjustable and steel. Doubt you are gonna strip those
Old 01-16-2008 | 07:12 AM
yes diff gears strip. It happens all the time. If your pinion bearing goes out, or if it is not shimmed correctly, you can strip a diff gear But yes he is talking about a spur lol
