Pullstart problem-Un raveled-help =)
NY
Well i got my 4 things from cler yesterday with his amazingly fast shipping =D. I'm very satisfied with everything but I had a slight problem that arose. I went and opened my new OEM Pull start from redcat and i guess on accident i pull it a little bit and everything decided to pop out. the plastic middle piece and the wiring and crap and the string is un raveled too and i have no idea how too put it back together like it came out of the package! Anyone know ?
NY
i kinda got how its supposed to go in but this is a pain in the ass and i cant get the long metal piece thats like a spring to go back in =( i shoulda never pulled the damn thing
took mine apart to see how it works..got an idea how to do it but I need to run to the shop and get some really thin wire to wire tie the coil so it doesnt unraveal
bro, its not easy to rewind the spring, you should never pull on a plull start when its not on, the string holder will pop out and you will have a mess. i will see if i can drum up some pictures for you, i remember a site that had pictures of the pullstart rebuild
NY
oo and thanks Eddie yeah i have no idea when i pulled on it, i didnt intentionally do it I think it grabbed onto something and it happend. But i keep getting closer to getting it into place but like firebird said it just isnt staying tight enough for me too push it down into place.
get ya some thin wire...wire tie it..put it down in...snip wires and remove..hard part then is to line up spool with the coil...mines back together
i cant find that site, i dont remember where it is.
heres a couple of links to explain:
http://findarticles.com/p/articles/m...05/ai_n8942077
found it bro:
http://www.hpieurope.com/pdfs/rebuild_pullstarter.pdf
found it bro:
NY
yeah idk the tape isnt holding how much did you use i tried what the gfuide said but its diff since its deeper..
I just wrapped it a couple times...more on the side the hook isnt on..put it in the housing and put the hook in its place and slid it off with a pick
lol...far from god..im sure theres a proper way..I do however think I messed up the spring from winding the spool the wrong ways and try pulling on the cord..I use a roto start so I just had my pullstart handy
i put in my roto start today and dont like it. i couldnt get the engine to start. So i just put the pull start back on and it started with 1 pull.
TN
ORIGINAL: webbl19
NY
OKAY! I FINALLY GOT IT. I put the thing in with the string wrapped up and its ready too go but one question where does the little spring go? Idk Anyone?
