YAAAAAAAAAAAAY!!!!!!!!!!!!!!!!!!!!
AB, CANADA
I just got my Tornado S-30 and I am EXTREMELY impressed. The quality is FAR BETTER than I thought it would be and I can't wait until I can get it out and break it in. MANY thanks to Redcat for producing top quality products.
My only question, and I am sure a few of you other noobs have had the same one, is how do I PROPERLY install the antenna tube onto the car? I know that I am to slide the antenna itself through the tube but there is a considerable amount of extra wire that comes out the end. Am I to trim it off, which I know for other type models is a huge nono, or leave it and not use the end cap that came with the tube........ what do I do?
Steve
P.S. Likely ALOT more questions to follow lol....
Steve
RE: YAAAAAAAAAAAAY!!!!!!!!!!!!!!!!!!!!
Please do NOT trim your antenna wire! Leave it trail behind the antenna, from under the cap. If you neatly push the antenna wire down into the receiver box, it will pick up servo noise from the steering servo. These cars and trucks operate in the 27MHz band, and this frequency is pretty darn noisy, and easy to detune. Changing the length of your antenna wire will alter your SWR (Standing Wave Ratio), and allow undesirable harmonics of the 27mhz band to tell your car to do bad bad things. Please let it trail, do not change the length, AND A BONUS...
STAY AWAY FROM CB RADIOS!!! This is the same freq truckers use on the interstate! Their rigs sometimes pump several hundred watts output. Not only will this make youir pride and joy go whacky, but could burn out the receiver.
Another bonus? If you have a couple bucks laying around? Upgrade the radio gear with one of those 2.4 GHz digital radios out there. Those guys are spot on, and hard to glitch out. Try one, you love the response!!
ENJOY YOUR NEW TOY AND HAVE A BALL!!!!
AB, CANADA
Thanks for the info, much appreciated. I know about the CB's as well because I drive truck and I know how the CB's can mess around with certain other frequencies as well. Does the S-30 really go 60MPH like I have been told it does?
AB, CANADA
Hey that's fast enough for me lol.... It's my first RC car so I don't need anything faster than that for now. Thanks.
being its you first....make sure you take the time to go over the entire buggy...take you time and lock tite all the screws going into metal with blue lock tite....check the needle settings...make sure u count the turns...and allow the lock tite to set up...and as far as your reciever antanna...cap it off..then coil whats left around the tube..then put a small rubber band at the end...
Do not forget to loctite the starter screws that hold it on! As long as you are in there, get teh screws that hold the engine back plate on too. As well as the motor mount screws!
Use CA glue on the screws that go into plastic. Just dont get any on the heads. Only the threads. You'll be ok.
AZ
i got my truck up to 40, and my regular buggy, just the tornado not the s-30, is faster than my truck. ill test it next time i have it out, they are pretty fast
AB, CANADA
Ya I have seen some videos of them running and they seem to go pretty quick. Just trying to decide if I should lose my pull starter and stick to a bumper box or a drill. Not sure how I am gonna like the pull starter on this one I am one of those guys who like to giver it all he's got lol........
AZ
I like pull starts, if you have a bump box or a drill start its just more things and more weight to carry. say your at a park drivin, and you leave your car to drive other places too, you have to bring your drill start or bump box in case it dies
