has anyone upgraded the center dogbones on landslide??
i have the 1/8 landslide ....im tryna figure out if i need to take the whole diff gear box apart to change the center driven joint cup..i took it apart once to upgrade the rear dogbones...there is a lil screw that looks like its holding the cup on from the outside.....anybody know?
RE: has anyone upgraded the center dogbones on landslide??
i have went thru a few sets of rear dogbones, jus snapped during run...i upgraded those, now the center dogbone snapped..im about to upgrade this and the center drive cups etc..these ultralites are very fragile...i wish i woulda researched more beforehand
pull the case apart to expose the spider gears. pull them out. on both halves, pull the gear off and remove the pin that's under it. the grub screw you see on the case is for the pin to go through. remove the screw, and get a magnet to pull the gear off the pin.
hope i didn't just confuse you
no u didnt confuse me..because i have done that already to remove the REAR DOGBONES (side)..i was asking about the center drive cups that the center bones go into...didnt have to take apart the gear box to do it..but thanks anyway
