fail safe ?'s
IN
i got a fail safe for my volcano sv, but i have no idea how to set it. I thought i read somewhere that you have to push a button on the fail safe to set it up, but do you do that with the throttle servo in the wide open position, or with it closed?
can anyone tell me how to set the failsafe once it's plugged in ??
thanks.
thanks.
Here you go. Hope it helps
Set up instructions:
1. Remove throttle servo plug from receiver.
2. Plug male failsafe plug into receiver where servo was plugged into, plug servo plug into female plug of failsafe.
3. Do not start car, put transmitter and car power on, apply full braking on transmitter, press and hold set button on failsafe for 5 seconds.
4. Test failsafe by turning transmitter off and leaving car power on, if failsafe is set up properly, brakes will be applied fully when transmitter power is turned off.
