Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Nitro motor cleaning.
Old 05-25-2010 | 09:51 AM
Default Nitro motor cleaning.
I would like to clean the motor of all of the sand and stuff inside the cooling head and off the motor. I used compressed air to get all of the sand off of it. Now, the stuff that is stuck on and is not coming off with compressed air I would like to get off. I've heard that some people use WD-40. Now that it is running correctly I would like to keep it clean. Thanks.
Old 05-26-2010 | 11:20 AM
AllAboutFunHobbies's Avatar
Default RE: Nitro motor cleaning.
WD-40 and compressed air. The WD-40 won't hurt the electronics so you can spray the whole thing down and then blow it off. It also helps to lube the bearings and stuff.
Old 05-26-2010 | 03:44 PM
Yep that's all that I use.
Old 05-27-2010 | 09:30 AM
Ok. That is what I was looking for. I must go buy some WD-40 now. Or soap and water and an old tooth brush?
Old 05-27-2010 | 04:15 PM
With the WD-40 you dont have to worry about the oil getting into the bearings and breaking down the grease like you would if you used soap and water. WD-40 is safe on the electronics as well...the best stuff if you ask me.
Old 07-09-2010 | 05:58 AM
 Yikes!
Old 07-09-2010 | 08:06 AM
