volcano SV
I just got my Volcano sv and it works great but after the 4th tank i lost my rear wheel drive, the fornt has power but not the back any ideas .
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
RE: volcano SV
Hey Matthew Good to have you on here![sm=thumbs_up.gif] The rear gearbox was just went over pretty good in this thread below.
Click on it and read through you will probably find the anwser in there. http://www.rcuniverse.com/forum/m_4572186/tm.htm ------------------------------------------------------------------ The Truck thread will also help you out alot with your truck http://www.rcuniverse.com/forum/m_37...92/key_/tm.htm |
RE: volcano SV
check grub screw hooked to drive cups that hold the dogbones in if loose use loctite on them or you burtnt up diff. gears
| All times are GMT -8. The time now is 08:22 AM. |
