WHAT ENGINE TO USE?
A 15 or 20 will be fine, from what i've heard the smaller OS LA series engines are comparativly better than the larger 40 sive LA's
for my money i'd go with a TT or GMS.
You might have to work on your GMS to get it to shut down on command.
My GMS 32 seems to have an air-leak, so I have to pinch the fuel line
after landing. Next time I break a prop, I might seal up the bearing to see if it works better.
