First Spad
Hi,
Just finished a SPA3D, powered with a older OS 70 4C.
But the muffler snapped off[:@] and the engine must have muffler pressure to operate. $50 for a new muffler[X(][X(]
So still haven't flown[:'(]
Looks like it'll be fun!!!!!!!!!!!!!
John
John
My Feedback: (18)
You'll have a good time with it, but wow you really have to stay on top of that plane it can be a handful.
Mine would do a loop in less than its own length! While you wait for the new muffler why dont you put the profile fuselage on it? I did that on mine and it seemed like it was easier to see. It will probably help with knifeedge as well. Although mine never flew knife edge all that great. I think its a little short for a clean KE.
Had the first flight today in about 3-5 knots.
Yikes, a bit (aka A LOT) tail heavy, with a Saito 56 up front. Take off roll of about 1.5 meters (2-3ft) and straight up[X(]. Seems like the prop will cut off the tail it loops so tight, inside and outside. Inverted climbing flat spins, I had trouble with a decsending one, but now I'm bl00dly climbing[8D]
Landing was scary, deadstick, and travelling downwind. Touched the mains, and yawed to the right. Main caught and skidded to a stop
, looked great but not suppose to happen
I've moved the tank, and I'll move the battery forward. I put the profile on and that added to the tail weight unfortunaty.
Convinced the local SPAD man to build one!!!!!!!!!!!!!!!!!!!
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
![EEK!](https://www.rcuniverse.com/forum/images/smilies/eek.gif)
My Feedback: (18)
I was having some engine problems with mine and I know how tough those deadstick landings are with that plane. I had a bunch of pretty hard landings with it. Fortunately with a SPAD the worst I had to do was change the landing gear.
Have you had any problems with the wing flexing with full aleiron deflection? With mine I could see the wing flex.
Don't know!!
Had a combat today
, but the engine mount failed and the engine flew off[X(], cut my own streamer avioding the oppenet(sp?).
Harrier landing on the first flight, refuelled and took off again and back into it. 5 min in the engine flew off.
Had a combat today
No flutter on the wing during full aileron, but a full throttle dive had some fluttler
Surprised the wing is still together
John
John
NY
No flutter on the wing during full aileron, but a full throttle dive had some fluttler Surprised the wing is still together
You know the SPA3D was designed to fly at 1/2 throttle or less in level flight.
That being said there are mods like filling the LE area with foam, making the center 5/32 rod go through the fuse and a full length 5/32 CF rod in the last flute before the aileron hing. These mods all help stop flutter at higher speeds.
Thats the greatest thing about Spads , so easy to experiment with, that's half the fun for Me.
I have a Jett 46 on My first one and built a BigMcDDD with a Irvine 61, there both a blast to fly.
Jeff
