Fury extreme scale fuse
RE: Fury extreme scale fuse
from what i can see of the fury, it will work fine for the bigger fuses like the indy apache and much of the vario stuff. however, for 60/90 size fuses,the mechs do not seem to be as fuselage friendly as most. see, the area just forward of the main mast has servos mounted in place where most fuselage doghouses start to slope down. now if the servos can be relocated then it may not be too bad as the fury is a very narow profiled heli with some serious performance.
