Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Spirit of Pitts build
Old 06-13-2014, 02:09 PM
Brian Roth
Default Spirit of Pitts build
Hello all, A couple weeks ago i came across the plans and thread on this 25% Pitts inspired Spirit of Pitts. The plans looked great so i had them printed and bought some wood!
Pics to follow.
Old 06-15-2014, 02:55 PM
Brian Roth
Some pics.I spent about four days just cutting parts. Couldnt of done it without the SCROLL SAW! $100 at lowes!
ID:	2005181   Click image for larger version
ID:	2005182   Click image for larger version
Old 06-15-2014, 03:12 PM
Calvinman
Nice looking work Brian, those are some intricate pieces!
Calvi
Old 06-15-2014, 05:14 PM
Brian Roth
Thanks Calvi.
Im about half way on the fuse. To keep it all on center line i built that little jig to butt up against the fire wall. Just a couple tacks of glue to hold it.
ID:	2005383   Click image for larger version
ID:	2005384   Click image for larger version
Old 06-15-2014, 05:41 PM
Brian Roth
Sorry, need to rotate the pics.
ID:	2005472   Click image for larger version
ID:	2005473   Click image for larger version
Old 06-16-2014, 08:38 AM
ALO 111
ALO 111's Avatar
Nice ! will be watching,
Old 06-17-2014, 10:13 AM
Brian Roth
This is a fun fuse to build! I needed to start it upside down so the tops of the formers kept it flat on the bench. After the first 5 formers were glued, i flipped the fuse over and glued it back to the jig to keep the fire wall centered and had to prop it up level with some scrap stanchions. Then i installed the rest of the formers. At the last former i made another scrap jig to hold the aft end centered over the plan.
ID:	2006179   Click image for larger version
Old 06-17-2014, 12:15 PM
Brian Roth
If anyone wants the plans i can email them to ya.
Old 06-17-2014, 06:25 PM
Brian Roth
A few more.
ID:	2006329   Click image for larger version
Old 06-18-2014, 09:50 AM
acerc
acerc's Avatar
Nice looking assembly, simple but sturdy design. I am subscribed and Pm sent for a set of the plans.
Old 06-18-2014, 10:41 AM
sir crashallot
sir crashallot's Avatar
Looks like a great build in progress. will be watching with intrest. Ps PM sent
Old 06-20-2014, 04:05 PM
flyingagin
flyingagin's Avatar
Subscribe
Some dang good work here
Ken
Old 06-22-2014, 09:39 AM
Brian Roth
If you guys are building to the plans you will run into the same issues as i have. One major change i have made was the cockpit area. The plans have it removable frame F6 all the way to the firewall F1. This obviously interferes with the cabane struts. I added two extra formers just behind F3. This is where the removable cockpit will connect to the fuse. I added some notes to the plans in the pic below. I modified FT3a so that i can drill peg holes for mounting the cockpit. FT3a i glued to the aft side of F3.
ID:	2007637   Click image for larger version
Old 06-22-2014, 11:27 AM
Brian Roth
The top 10 x 10mm stick, i glued to the bottom stick and shaved flat and level with F4 and F5 from the aft side of FT3a to F6. This is so i can make a flat surface for the removable cockpit to lay. Hope that makes sense. If not the pics should do the job.
ID:	2007655   Click image for larger version
Old 06-22-2014, 11:32 AM
Brian Roth
Anyone done vacuum forming? I really dont want the cowl to be built up.
Old 06-22-2014, 12:04 PM
Brian Roth
Just a few pics of the tail coming together. Had to notch the 10mm stick to accept the 5mm sticks.
ID:	2007691   Click image for larger version
ID:	2007692   Click image for larger version
Old 06-22-2014, 02:33 PM
Brian Roth
Some more of the removable cockpit.
ID:	2007730   Click image for larger version
ID:	2007731   Click image for larger version
ID:	2007732   Click image for larger version
ID:	2007733   Click image for larger version
ID:	2007734   Click image for larger version
Old 06-22-2014, 03:56 PM
acerc
acerc's Avatar
If you don't mind a dumb question, why is the cockpit removable?
Old 06-22-2014, 06:33 PM
flyingagin
flyingagin's Avatar
I would be interested
Ken Pitts (notice the last name)
pm sent
Old 06-23-2014, 03:18 PM
Brian Roth
If done right you can make it look seamless. I also like as much access as i can to the radio gear. In my opinion there is not quite enough access through the bottom of the fuse and i would hate to have to disassemble the wings to do some minor adjustments.
Old 06-23-2014, 03:30 PM
acerc
acerc's Avatar
Sounds good, makes perfect sense. So far all my other Pitts have removable aluminum skins, but I probably would not do it that way on this type of Pitts.
Old 06-25-2014, 02:54 AM
Prboz
Very nice, will keep watching. PM Sent
Old 07-01-2014, 04:33 PM
Brian Roth
A few more of the cockpit. On all my models i like to cut the cockpit floor out so that the guts are visible. I think it looks cool. Unless its a super scale project.
ID:	2010455   Click image for larger version
ID:	2010456   Click image for larger version
ID:	2010457   Click image for larger version
ID:	2010458   Click image for larger version
AndreS12 (08-01-2022)
Old 07-13-2015, 10:52 AM
speednuri
I want the plans please! thank you. [email protected]
Old 10-21-2015, 09:35 AM
sscherin
sscherin's Avatar
Anyone think a 6.7 gear reduction Neu 1521-1.5Y on 12S would be overkill? (50cc gas equivalent) I can swing a 22x10 2 blade or 20x10 3 blade.
