Pitts M12 26% plans available soon
#676
RE: Pitts M12 26% plans available soon
ORIGINAL: eromeros
Hello rgunder,
I have a full kit waiting to be assembled, I don't recall if the wood to build the tail surfaces is included in the full kit. Is it?
Regards
Hello rgunder,
Regards
Yes, the full wood kit does contain all of the balsa necessary for the tail build. Please post your pictures as your build progresses.
Cheers,
Rich
#677
Hey, I just noticed that the great planes M12 is 2 meters long and has about the same wignspan as this plane if I'm not mistaken.
It is set up for more high end 3D, so has anyone thought of stretching the fuselage and running it on a 50cc as a 3D plane?
What else would have to be changed?
#678
Hi,
my foto are here :
http://picasaweb.google.com/10751709...3941/PittsM12#
now is time for fuse building. I wrote twice to Gunderson but no answer to my request for a Fiberglass Cowling.
Are they alive ?
my foto are here :
Are they alive ?
#680
We are still here, but we had an issue with our spam filter - your email was unfortunately a victim of that filter. I have sent you the quote that you requested.
Great looking build, by the way. Can you give some detail on how you changed the tail structure?
Thanks!
Thanks!
#681
thank you for your quotation. Unfortunately shipping cost is more than items cost than i will try to solve in my local shop.
Tail structure :
I dislike flat tail and wires than i redraw it with a simmetrical profile. Please rename txt file with .dxf and import in your cad.
Obviously is not like the real one.
Hope you like it.
Tail structure :
Hope you like it.
#682
Glonline, the real M12 uses the flat plate airfoil created by making the tail sections from tubing and flat ribs so the use of a flat airfoil on the model was not just to make it cheaper to produce. It was actually a nod of the head towards scale fidelity.
#683
Hello friend I''m in Brazil, and I want to build PITTS MODEL 12 Gorter and your project for you congratulations on this project, I ask if possible please send me the plans for [email protected].
#684
ORIGINAL: cicerohora
Hi. To request the plans, please go to our website ([link=http://www.gundersonaerodesign.com/products/shortkits/burton/]www.gundersonaerodesign.com/products/shortkits/burton/[/link]), scroll to the bottom of the page and click on the picture of the plans - there is a form to fill out, after which we will email you the plans.
Rich
#685
fuse building problem :
wings are 350 mm wide but in fuselage from F2A to F5 there is only 332 mm.
Do I have to cut rear edge of the wing ?
GL
GL
AndreS12 (08-03-2022)
#686
ORIGINAL: glonline
GL
GL
#687
Hey all! Very interesting thread! I have been thinking about scratching a bipe for my Moki 210 for a long time now. I will read through the thread when I get back from work and see if this one will fit. If it does and I can acquire the necessary resources (balsa is getting scarce ...) I will definitely order the plans. Just figured I say a quick hello first
#688
ORIGINAL: rgunder
glonline, the plans (fuselage side view) show the trailing edge skins should be trimmed to fit. The amount of trimming depends on how sharp you make the trailing edge - a blunt trailing edge will not need as much trimming. I hope that makes sense.
ORIGINAL: glonline
GL
GL
ok, now I know how proceed
Thank you very much
Gabriele
#689
I've powered mine with a 1.80 Moki. Although it's short on power it flys very well. My only modification was to use music wire for cabanes and landing gear.
#690
ORIGINAL: Zpat
#691
I covered with Monocoat and used 3/16" music wire for the cabanes and landing gear.
I soldered some heavy duty electrical lugs to attach the wing.
The wire on the landing gear has been doubled up and wrapped in a couple of places with soldered copper wire.
The wood structure on the cabanes in the picture is a carrying handle to ease transportation. It's is removed to attach the top wing.
I've added a Bisson Sport Muffler to the Moki 1.80 in hopes of extracting more power from the engine.
I may build another for a G-62.
A picture of the plane I attempted to copy is also included.
#692
Hi all,
With the new year comes some changes to what we are going to offer in the future for the Spirit of Pitts. We will continue to offer the plans for download free of cost on our website, and we will continue to offer the short kits, but we will be phasing out all the accessories over time as we get through the stock on hand. As you know, I have been working to find an affordable way to continue to bring you a high quality canopy and cowling option, but alas the unit costs were simply too high and the market too small to make it feasible, so Gunderson AeroDesign will no longer offer these accessories. The full wood kit is suffering a similar fate, as having metric balsa custom milled requires a volume larger than the market can sustain at this time. I apologize for the inconvenience.
Please note that for the two most difficult parts to scratch build (canopy and cowling) the plans and the short kit still include the formers necessary to build a wood cowling and a canopy mold.
Thanks for the continued support and happy 2011!
Rich Gunderson
Rich Gunderson
#693
ORIGINAL: rgunder
Hi all,
Rich Gunderson
Hi all,
Rich Gunderson
Thanks!
Samuel - Brazil
#694
sbsam,
I can't seem to find your request, did you use the form on our website? Please send me a PM with your email address so that I can double check against the requests to make sure that I did not miss it.
Rich
Rich
#696
Hi guys,
I'm happy to tell you that my pitts was exposed in a little italian rc-plane show (only as static model)
photo's always here :
https://picasaweb.google.com/glonline/PittsM12#
Some problem with main landing gears ( it needs wires to avoid opening) but all seems to be ok.
Maiden flight in one month....
#697
My Feedback: (9)
Hi glonline
What an amazing beauty, congratulations.
Anyway i´m really interesting about how you made the canopy, please could you enlightme, until the mould i know, but what´s the proces and materials you used to make the canopy ( heater gun or vacumm), y really appreciate.
#698
ORIGINAL: glonline
Hi guys,
Hi guys,
#699
ORIGINAL: pacorro
Hi glonline
Hi glonline
I've made canopy master but I didn't use it. I found a canopy from another plane ( extra )...just after the master, as always....
#700
My Feedback: (9)
Anyway thaks glonline
I feel miserable, cause y try many different ways to make canopys but did´t find the right material (policarbonates and poietilentotaftalato are the best but difficult to find in the right thikness) so for middle and little canopy the best untill now it´s been go to the supermarket and got the biggest transparent and smooth bottle ( water or cold drink) cut it and with the heat gun molded.
