THREADED CLEVIS
I feel that I have need for a threaded 4/40 clevis.
Most everything that I have seen available (locally) is nothing but a solder unit.
Q) If I add an acid/flux solder to the core of my non threaded clevis, can I drill out the proper amount then "tap" the threads into it?
Will I need to use a SILVER SOLDER or again, must I BRAZE with something like copper?
I know that I can do this, but, will the new threads HOLD UP?
marwen1
marwen1
MN
this is better
Great Planes Steel Clevis 4-40 (12) Search this site: Die-Cast-Models.com Model-Ships.com Plastic-Models.com PuzzleWonder.com RocketFun.com RTFplanes.com ScienceHobby.com Tower Hobbies (All) TrainModels.com
Search: Help | AdvancedSearch
Radio Control Products
General Hobby Products
Shop by Brand
Parts Wizard
Additional Listings
Aircraft Accessories > Control Linkages / Hinges > Pushrod Connectors - View Only Popular Selections Bookmark this Page
Tech Notes
Possible Substitutions
Other Items of Interest
Browse Great Planes
Manufacturer's Product Web page
Parts Express Eligible: Yes
Tower Catalog Page: 92
E-mail This Page To A Friend
Manufacturer Stock#
GPMQ3795
Stock Number
LXK079
Tower's Low Price
6.49
Stock Status
In Stock
Move your mouse over the listed items to view pictures. Click any listed item for product details.
Customers who purchased the above product also bought:
1. LXK077 Great Planes Steel Clevis 2-56 (12) 5.49 Buy Now
2. LXK085 Great Planes Solder Clevis 4-40 (12) 6.59 Buy Now
3. LXD871 Dubro Threaded Rod 4-40 12" (6) 3.09 Buy Now
4. LXK066 Great Planes Threaded Pushrods 4-40x12" (6) 3.29 Buy Now
5. LXK089 Great Planes Threaded Coupler 4-40 (.095") (2) 1.39 Buy Now
6. LXK083 Great Planes Solder Clevis 2-56 (12) 5.49 Buy Now
7. LXK064 Great Planes Threaded Pushrods 2-56x12" (6) 2.99 Buy Now
8. LXD937 Dubro Control Horns T-Style Large (2) 1.89 Buy Now
9. LXK099 Great Planes Screw-Lock Connector Bulk (12) 7.49 Buy Now
10. LXK129 Great Planes Silicone Fuel Tubing Standard 3' 2.19 Buy Now
11. LXK081 Great Planes Nylon Clevis 2-56 (12) 3.79 Buy Now
12. LXK108 Great Planes Nylon Control Horns Large (2) .95 Buy Now
Click for more items of interest...
Tech Notes
NOTES FROM OUR TECH DEPARTMENT
This is a package of twelve 4-40 threaded steel clevises.
FEATURES: Made of steel
Has a barb on the clevis to hold the retainer in place
Has a stepped clevis pin to reduce friction
INCLUDES: Twelve threaded steel clevises
Twelve retainers (sections of standard fuel tubing)
SPECS: Fits 4-40 threaded rods
Length: 1.2" (30.4mm) end to end
.75" (19.1mm) of clevis opening
Width: .18" (4.7mm) @ widest point on the pin end
Height: .17" (4.3mm) @ highest point on the pin end
.12" (3.1mm) of clevis opening
Diameter: .06" (1.5mm) of pin
COMMENTS: These steel clevises are used to connect a 4-40 pushrod to a control
such as a control horn or throttle lever.
btm 06/14/94
ir/jl
updated 070204 tjt
Click here for Units of Measure Conversion Calculators
TOWER HOBBIES (Serving Hobbyists Since 1971) 800-637-6050 or 217-398-3636
© 1994 - 2007 Tower Hobbies
All materials copyright 2007 Tower Hobbies. Unauthorized use of any materials presented here is prohibited. Copying or reproducing any elements from this page is not permitted. All prices, descriptions and availability subject to change.
Shop by Brand
Parts Wizard
Additional Listings
Tech Notes
Browse Great Planes
Manufacturer Stock#
GPMQ3795
Stock Number
LXK079
Tower's Low Price
6.49
Stock Status
In Stock
Tech Notes
btm 06/14/94
ir/jl
updated 070204 tjt
QC, CANADA
If you can buy the part, buy it.. No use futsing with making your own!
Du-Bro have one, a 4-40 clevis.
The solder, despite 'silver', would be soft..
Great Hobbies can do you... Kinda local too (or the day's drive to Edmonton!!
Hi Jim
Every time I go up there, they are always "out-of-stock" on that item
MIke:
What mt time is worth -- isn't the issue. MAINLY, I use thios RC stuff as a HOBBY, not a business. If I need something and I can't find it, I
ll try to make it.
at the risk of being repetetive: I believe my question was " would the silver solder hold or would I have to go to brazing?
marwen1
MIke:
ll try to make it.
marwen1
