Your first thoughts on FlyZone's new SeaWind?
#101
I really appreciate your assistance. I'm so lost I don't know what to do. I may end up taking it down to HobbyTown USA and have them take a look at it. That's where I got the Spectrum transmitter. You got a replacement Seawind? Did I miss something? What happened?
#102
TX
Now, I unboxed the model's fuse, installed and bound a FrSky 8 channel Rx to my Aurora 9 Tx, with the rudder servo hooked up to prove the link worked. Looked at the SW instruction manual in order to sort out the servo cables. Found a separate sheet in the SW manual. It's entitled "ESC Programming and Failsafe Technical Notice." It is the ESC programming manual I wrote of before. You should have that sheet. You need to read and follow the instructions under "Operation/Startup" and "Throttle Calibration." Once you get that done you can set the Brake & Failsafe functions per the sheet. It's worth noting that the Failsafe instructions that come first on the sheet assume you are using a Tactic radio. Note also that they say to set the throttle channel to "Reverse." This may or may not be right for your Spektrum Tx.
Finally; Tailskid may be right in that if you can restore the factory defaults in your Tx it may be worthwhile to start out that way, just to get a new baseline. I came close to recommending that a few posts back.
CR
#103
TX
Another Thread
smitty,
There's a Seawind thread on RC Groups that you might want to check out: http://www.rcgroups.com/forums/showt...5#post34090960
Meanwhile, I unboxed the fuse & installed a new Frsky Delta 8, 8-channel Rx, in order to ensure compatibility with the model's electronics and my Aurora 9 Tx. I followed the instruction in the ESC instruction sheet: everything works OK.
I took the liberty to invite Spektrum users from the RCG thread to look at this thread with an eye to helping you out. Also told them I'd encourage you to check in with them over there. Between us all we ought to be able to get you up and running.
Cheers,
CR
Cheers,
CR
#104
smitty,
Cheers,
CR
Cheers,
CR
#106
I got it! It works! I went through the steps and it worked with the throttle up but not down. I messed around with the throttle trim (got it in the neutral, if that's the right term,) tried it again and it worked as advertised! Listen carefully. Do you hear anything? Me neither; the BEEPING HAS STOPPED! Thank you so much for hanging in there with me.
#108
I am still having a minor issue with the flaps. It seems I'm only getting 50 percent travel with the flap actuator. At zero flaps the actuator should be up by the right wing but mine is pointing almost straight down. You'd think that would be simple to fix. Maybe it is and I'm just simpler!
#110
I found some very helpful videos on you tube that gave a detailed how, what and why set-up of the various functions of the Spectrum DX6 transmitter. The book that came with it is definitely for people that already know what they're doing. I had a minor surgery which set back my maiden flight but I'm good to go and waiting for the wind to die down. I have all my flight controls set up for dual rates at the correct throws. The only thing I'm wondering about now is the expo setting (last week I didn't even know what it meant so I'm making progress). I'm wondering particularly about the elevators during landing. Should I set any expo in or just go fly it and see how I do?
#112
Parotid gland below the left ear had a benign tumor. Had it removed before it becomes a problem. Recovering just fine, thanks. Okay then, if it's not too windy tomorrow I'll give it a go. I'm going to use a grass runway before I try the water. I want an idea of turn radius etc. before I go to the river. The last thing I want to do is put it in a tree hanging off the bank!
#113
My Feedback: (34)
Smitty, did you watch my video? I included a segment near the end that showed the turning radius....just hope the wind isn't blowing too hard
(http://www.rcgroups.com/forums/showt...0#post34202025)
Jerry
Jerry
#114
Jerry
Jerry
#117
TX
CR
#118
Finishing assembly using Spektrum AS3X AR636 and DX6i. Still learning the App on my iPad to program the receiver. Got the flaps working and trying to understand the gear. It seems to be threshold operated, so if the signal goes over the threshold, the gear cycles full down. When signal goes below the gear cycles full full up. It has a nice built in delay system and looks very real. Hoping Hobbico will answer my threshold question soon, since their instruction manual says nothing on the subject. The flaps are proportional as you'd expect. Dalpiaz 3-8-16
#122
I was hoping to have my maiden flight on the Seawind today. I took it and the Gamma Pro 370 to the flying field but the wind was strong and gusty. I flew the small plane a couple of times but it was very difficult to control. Amazingly I didn't have a glue and tape requirement after those flights but I was afraid to try the Seawind. Everyone tells me the bigger the plane is the easier it is to fly which makes sense to me but the prudent decision seemed to be wait for the wind to die down.
#123
TX
WTH lousy for flying in So. Central TX currently but we can always use the rain.
CR
#124
Hobbico sent the answer today, and all it takes is plus/minus 50% throw on the actuating channel to cause the gear to cycle up/down. Made the change and it works well. Thanks, Hobbico Tech Support! Need to put that in the manual -- Cpdalpiaz 3-9-16
#125
