Lanier Mariner 40 MKII ARF 62"
#151
RE: Lanier Mariner 40 MKII ARF 62"
I forgot to mention, I read a review on the Sig Sealane. Maybe a week ago. I was surprised to see the reviewer give it high marks for water handling, flight and getting up on plane without "submarining".
I might give one of those a try this winter, as I have found Sig kits to be great fun in the building.
#152
If that's their plan
#153
ORIGINAL: Tsutomu Mabuchi
I had a maiden flight for my Mariner last friday.
The first flight was successful, however I noticed a drift to the
right when it turns left.
So I had to add left rudder to make a coordinate turn.
There was no drift and no right rudder was required at right
turn. The wing is straight, not twisting.
If I trimmed the rudder to the left, it needed an aileron trim
to the right of course to make a straight and level flight.
I suspect this type of airplane requires engine thrust to the left
instead of neutral thrust of original design, but I don't know the
answer, appreciate your opinions. Contrary to my thinking, it
may need right engine thrust.
Tsutomu Mabuchi
Tsutomu Mabuchi
Also increased wing incidence.
That made mine be a very honest and stable airplane. I was surprised.
Tsutomu Mabuchi
#154
ORIGINAL: f2titan
We like our Mariner 40. Its only had a few flight, but its nice. It's the original version, and don't have too many issues with assembily. We have an OS 61 installed. I've posted this video before. If you haven't seen it...enjoy! Or, go to Google Video, and search for "mariner 40".
http://video.google.com/videoplay?do...riner+40&hl=en
and up, increased wing incidence.
Tsutomu Mabuchi
#156
WI
[8D] Beautiful photo Mustang! I have the original Mariner with probably over 200 water flights on it. The fuse has been completely overhauled including stripping all covering, sealing up all lightening holes with sheet balsa, fiberglassing and finally repainting entire fuse. No covering on fuse for me as the maintenance is too high. I'll recover the wings this winter. Plane is a little heavier, but it flies very scale like. Too bad Great Planes bought out Lanier and essentially put all their planes out to pasture. I wanted to purchase a Mariner MK. II, but missed the opportunity. I'll keep flying my Mariner until it literally falls apart. Maybe I'll attempt to draw up a set of plans before it dies! Know where I can score a Mariner MK. II?
#158
WI
[8D] Bob, Just got off e-bay and saw a Lanier Shrike in the rc airplane category. Might want to check it out. Would make a nice Xmas present for yourself!
Cheers!
Cheers!
