.25 Size Floats
WA
I like to build .25 sized planes and am looking for a good set of floats to try. My planes are usually around 3 lbs. I was looking at the tower website and found that the great planes .20 size float kit has a finished weight of just under 2 lbs. That seems like alot of weight to me for a .25 size plane. They also have some geebee 28" floats but do not list the weight. Has anybody built the GP .25 sized floats? Are they really practical for a .25 plane with about 360 sq in wing area? Any info about the geebee floats? Thanks.
I have never built the GP floats but have had the smaller GeeBee floats on many airplanes and highly recommend them, the are rugged, come ready to use with all hardware except a water rudder, good instructions about not only the floats but how to mount them and how to position them in relation to your airplane. They are cheap and work good, what else do you need? I have had them on airplane ranging from small trainers to small pattern planes and funfly airplanes. right now I have them on a GP Dazzler, but use it more on snow than water as I have a few other float planes.
The larger Geebee floats are a nother story, while they are the same design madfe bigger they are flexible and can fold on high sppeed landings. My experience with them has been poor.
