Go Back  RCU Forums > RC Airplanes > Seaplanes
 Float Length >
Float Length
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Float Length
Old 12-27-2006 | 03:45 PM
Default Float Length
Hi,
I understand floats are supposed to be about 75% of the plane length.
The floats I have for my Eagle II are around 85%.
What kind of problems will this cause?
Am I better off shorter or longer than 75%?
KW_Counter
Old 12-27-2006 | 04:30 PM
MinnFlyer's Avatar
Default RE: Float Length
You are better off with longer than shorter. The only problem will be the extra weight, but the Eagle can handle it easily
Old 12-27-2006 | 04:33 PM
My Feedback: (28)
I'd PM cublover. The guy knows floats like no one else. NOT TO OFFEND ANYONE....but he's good
Old 12-27-2006 | 04:53 PM
It's more important where the step is located (at or 0.5" behind the CG) than the overall length. Also, make sure that when you put the floats on the CG is the same as when the plane is on wheels. To do this add any necessary weight to the floats, not to the plane, or you are sure to forget to check the CG when you change over from one configuration to the other.
