Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
Bellanca aircruiser
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Bellanca aircruiser
Old 01-06-2008, 10:08 PM
cf-drg
cf-drg's Avatar
Default Bellanca aircruiser
Thought I'd post some pictures of the bellanca I'm building... After a 1.5 year hiatus I finally got back to it.. I'll power it with a Evolution 35 gasser ( MVVS 2.15).. Has a 120" WS (1440 sq/in) and as far as weight!!! your guess is as good as mine..
ID:	844361   Click image for larger version
Old 01-13-2008, 11:16 PM
joeccrc
joeccrc's Avatar
Default RE: Bellanca aircruiser
CF are you building this from plan. I have a set called Bellanca WB2 "Misas Columbia" Scale is 1 1/2" = A Foot Have you progressede any futher?
Old 01-20-2008, 09:52 PM
cf-drg
cf-drg's Avatar
Dillion I drew my own plans for this one.. It is 1/6 scale so has a wing span just over 10'.. I will power it with a Evo 26 gas engine.. And it will be on floats!!! As far as weight, it is going to be up there, high 20's mid 30's.. We'll see when it's all said and done... Have got a bit further, just puttering away at it...
ID:	856480   Click image for larger version
Old 01-21-2008, 12:34 PM
jrf
My Feedback: (551)
Your shop is too clean! You are a bad infuence.
Jim
Old 01-30-2008, 10:22 PM
cf-drg
cf-drg's Avatar
A bit more done.... Also I did clean up for the pic's.... Well now you can see why it is in the seaplane forum....
ID:	865710   Click image for larger version
Old 02-01-2008, 08:36 PM
bear 57
Good work Darren. Here for the perusal of all are the bare bones of my Bellanca Skyrocket.
Scratch built from Jerry Bates plans, 115 inch span. Power will be Zenoah 26.
All is built except the floats. Now to get it all together.
May be ready for spring if it ever warms up enough to use the shop.
Lorne
ID:	867401   Click image for larger version
ID:	867402   Click image for larger version
Old 02-02-2008, 10:44 AM
cf-drg
cf-drg's Avatar
So far so good Lorne... I hope to have it ready for Shuswap this spring, got the week off so I'm going to try and make it for the spring float fly.. I see we seem to be on a same kind of wave length Your building a Skyrocket, I'm building a Aircruiser, my next plane will be a Fairchild FC-2, yours "might" be a 71... And also your work table is like mine with the Makita drill and the Elmers polyurathane glue...
Old 02-02-2008, 11:49 AM
Kmot
My Feedback: (24)
Kmot's Avatar
cf-drg: This is a very interesting subject. BTW, all your paintings on your wall are of jets yet you are building an old round engine plane.
Old 02-03-2008, 10:44 AM
cf-drg
cf-drg's Avatar
Kmot, all those paintings and coloured drawings where done by "me"... Yes I have other hobbies.. I'm a big fan of 50's and Vietnam era jets... You know, when a new design came from one of the "10" or so companies every 6 months... My favourite is just over my left shoulder, it's a big old F-105 Thunderchief... And by the way all the Old Radial ones are on the wall to the right (out of the photo), but they're there..
Old 02-03-2008, 02:22 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Holy smokes! [X(]
Do you have an online gallery?
Old 02-21-2008, 09:25 PM
cf-drg
cf-drg's Avatar
Kmot, sorry I don't have an online gallery[]... but maybe me and some of the other artists on here could start a new post with some of our work... Anyways thought I would update the "Flying W's" progress, so here's a few pics...
ID:	885209   Click image for larger version
ID:	885210   Click image for larger version
Old 02-23-2008, 05:49 PM
Kmot
My Feedback: (24)
Kmot's Avatar
I like the scale muffler. Did you make that yourself?
Old 02-26-2008, 11:41 PM
fozjared
you are going to have to bust out a wall to get that thing out of the house! and then rent an 18 wheeler to haul it to the lake for you, then you will have to rent a boat house to put it in!
anyway.. i love the plane, you are incredibly talented and as such, should feel blessed! i love the plane, i could just stare at it.. keep us posted on how it is coming along, can't wait to see it completed!
Old 03-13-2008, 05:26 PM
cf-drg
cf-drg's Avatar
The pilot and copilot are here and checking on my progress... It's primed and ready for some paint, so going to go with red/yellow... Thought about scale colours, and they just weren't appealing to me, (only 4 ever really done up as bush planes)...So going with my own... Still have to sheet the floats and get them glassed and mounted... Did a weight check (engine,muffler,radio gear,batts,servos) without the floats, so far were at 22.5 pounds, so might come in under 30lbs (that would be nice)... We'll see....
Old 03-13-2008, 05:51 PM
cf-drg
cf-drg's Avatar
Kmot, I did make the "scale-ish" muffler just out of K&S and other brass and copper fittings.. It's all silver soldered together, but might have to modify it... That long pipe to the canister, might be a wee bit too long.. So I will just add another expansion chamber close the the manifold... We'll see what happens... Also it (the bellanca) does come apart, wings unplug,struts all come off and floats and that whole main strut assembly unbolt from the main air frame... So should be able to get it into my full size truck and canopy[8D]...
And last.. I do paintings of radial air planes... It's not that great, but I did the Stearman just after I got out of Highschool, so it's "ROUGH"... the others are from the 80's-90's, the F-102 is pencil crayon... The others are acrylic (no oil, take to long to dry)...
ID:	902650   Click image for larger version
ID:	902651   Click image for larger version
ID:	902652   Click image for larger version
Old 03-15-2008, 05:17 PM
cf-drg
cf-drg's Avatar
Latest update... Muffler is modified, wings are primed and floats are sheeted, also hinged the ailerons... Did up a colour picture of what I might paint it as, and call it the 5th one to be used in the bush... Slow but sure...
ID:	904109   Click image for larger version
ID:	904110   Click image for larger version
Old 03-16-2008, 06:50 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Darren: You have a lot of talent and a real gift. I am glad you are sharing it with us.
I have made some custom mufflers myself. You did a super job on yours!
Old 03-24-2008, 08:58 AM
cf-drg
cf-drg's Avatar
Still puttering away... Got a cowl plug from my Uncle, he turned one out of MDF.. So will have to pop a mould out of it.. And its some what painted, still have to do some panel lines and get all the lettering on it (CF-IRV)....
ID:	912121   Click image for larger version
Old 05-04-2008, 10:35 PM
cf-drg
cf-drg's Avatar
All done and an end to this post.. [)]...
ID:	943084   Click image for larger version
Old 05-04-2008, 11:42 PM
Kmot
My Feedback: (24)
Kmot's Avatar
ORIGINAL: cf-drg
Oh no you don't!!! Before you end this thread you must post flight photos and flight video!!!
Old 05-05-2008, 09:18 AM
Oregon Craig
Oregon Craig's Avatar
Yeah, or at least a report. Come on, I see it sitting NEXT TO the water!
Old 05-05-2008, 10:12 AM
cf-drg
cf-drg's Avatar
OK.. flight pics to come... But I didn't get any video though.. I still need to iron out some querks..N7OR you should be honoured to live in Oregon (State (place) with the only flying Bellanca Aircruiser in the world [)] ) went and saw it last summer.. Only 2 in the world now, other one is at a Manitoba air museum (slowly getting restored)....
Old 05-10-2008, 12:18 AM
Ralphbf
My Feedback: (27)
Ralphbf's Avatar
It's just awsome.
I love planes from this era and I appreciate the work and talent it took
to get this far.
It took me a year to build a Birdi Old Timer.
I am truely looking forward to seeing more photos.
Thank You
Old 05-10-2008, 12:21 AM
Ralphbf
My Feedback: (27)
Ralphbf's Avatar
My work in progress.
143" wing and 84" long.
Old 05-10-2008, 02:49 AM
Tracon
Tracon's Avatar
Team Tracon's pictures from the "Dan Jude Memorial" Aluoette Lake Float Fly are now posted on our website.
Please visit:
http://teamtracon.netfirms.com/event.../nfpicturepro/
Sam & Beverly
