Go Back  RCU Forums > RC Airplanes > Seaplanes
 Neptune Question >
Neptune Question
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Neptune Question
Old 12-19-2008 | 10:39 PM
Default Neptune Question
The instructions recommend to install the float in alignment with the wing rib end. I've seen pictures that show two differents positions as pictured here. Which one is right ? Left or Right picture ?
ID:	1092890   Click image for larger version
Old 12-20-2008 | 09:53 AM
MinnFlyer's Avatar
Default RE: Neptune Question
I would do it like pic #2 because you can center the float over the rib. In Pic #1, the rib is along one edge of the float.
Old 12-20-2008 | 10:05 AM
beau0090_99's Avatar
I would agree with Mike, knowing that most flying boats have water issues when their tip floats are mounted all the way out on the wingtips(i.e. Seawind), I would move it in like #2.
Good luck,
Curtis
Old 12-20-2008 | 11:42 PM
Ok, thank you guys. Exactly what I tought but wanted to get someone with more experience comment.
Séb
