Retrieval?
Just flew my first float plane. A .40 size trainer with a .61fx on geebee floats.
The first dead stick, plane is floating toward opposite shore aided by the wind. I see the plane rotate forward and the motor goes under. After I went swimming, found out the floats had a leak! Has anyone seen an electric motor/prop used as a backup/retrieval device. I was thinking a small 280 with a speed control plugged into the gear channel, flip the gear switch and motor back to shore. I figure the weight would be around 3-4 ozs. Any comments or suggestions? |
rc boat
I've used an rc boat in the past to retrieve aircraft. It was a logging dozer boat with a functional boom on the front controlled by a 3rd channel. It worked quite well except if the plane was over 200' out ( my depth perseption was off ) it was hard to manouver the boat around.
Retrieval?
A guy at out annual float fly had a small pod on top of the wing with a folding pusher prop and elect motor.
He rubberbanded the folding prop closed. He said it would throw the ruberband off if he powered up the motor. |
Retrieval?
if your plane is upside down, the electric motor is not going to be much help......
Retrieval?
You have a point on the upside down part. The floats filled becasue it could not be retrieved in a timely manner(thats were the backup system comes in).
The leak has been plugged! I was considering a model boat drive system to "bring it back". |
retreval of plane
Nothing works better than a really good dog. My personal favorite is a good Lab. It is important to remember to keep him tied up untill needed or he will try to retrieve one you have landed and catching a rotating prop will ruin him forever. If you rub a little liver on the plane before every flight this will also encourage the dog to go get the plane. I hope this helps. You will however need a lot of planes.
Retrieval?
No, the Dog idea won't work for us here in Florida. It's too expensive. Gators are ubiquitous around here, and dogs are their favorite delicacy. It's cheaper to have a boat.
Retrieval?
Love the thought of the alligators, we don't have then in Canada -but better you had used foam core floats. They don't sink. However. if the floats have too narrow a track, the wind can get under the windward wing and tip the plane over. But you'll never get a water-logged float!
Look at http://www.foamcorefloats.com/ |
float with prop
Did it 20 years ago install a small motor with drive shaft in the float that has no rudder on it the prop sticks out about 1/2 inch hook up to switch and two 1.5 V dry cells to make 3V AA's work good Working on a new set up Hobby Lobby sells a folding prop for sail boats that way there is no prop drag Also putting one in the hull of sea plane comes out of step has small cut out in hull bottom like half moon so when blades open they wont hit the hull but are flush with the bottom when folded so they dont hang up on anything also will work on float step if you do not want it at the back of float
Retrieval?
Dogs, Fishing poles, long sticks, onboard battery-driven propellors, radio-controlled boats, and tractor beams are all useful. Sometimes.
Ultimately, you're going to need a boat. You will have to get in the water and physically retrieve your airplane. The other things are handy for those times when you can get by without taking a boat ride. A man-carrying boat will ALWAYS get the plane. Any of the other tricks works SOMETIMES. Which is fine if you USUALLY want to get your plane back. |
Dog of Choice
Newfoundlands (I have seven) are the best. They have softmouth and won't damage the plane. They want to "rescue" everything that is in the water, your plane won't smell like liver, and they probably are too big for a gator to get in their mouth (mine are between 160 and 190 lbs) Like the lab you have to keep them ashore until needed or they will rescue every plane.
Retrieval?
Why send a dog when a wife will work so much better and you don't have to tie her to shore. It may take some coaching to get her swimming at first. Normally shiny or sparkly things work best. If properly trained she can also fuel, start, and tune your plane pryor to takeoff. *lmao*
Retrieval?
On small ponds or narrow waterways you might try a casting rod with a ball on the end of the line. It worked for us when we flew out of a farm pond. If a crash disabled a plane we'd take the ball off, put the lures back on cast for supper to take home. Oh yes, the pond was stocked.
Retrieval?
Originally posted by trailingedge Why send a dog when a wife will work so much better and you don't have to tie her to shore. It may take some coaching to get her swimming at first. Normally shiny or sparkly things work best. If properly trained she can also fuel, start, and tune your plane pryor to takeoff. *lmao* |
That's why!!!!!
Originally posted by Cdallas2 And if a gator gets her you might have solved another problem. :drowning: :D :p LMAO I think I stay on dry land! Cheers Steff ;) |
Retrieval?
I hope you know I was just kidding.
My solution
1 Attachment(s)
Greetings,
Just received my Donald 4 Seaplane kit. While waiting for the kit I used the guts (motor, circuit board servos) from an Aerobird (RTF) to make a air boat for a possible Donald 4 retrieval form shore. If I land in the center of a lake and lack the power to taxi in...my plan is to use my trusty marsh boat to circle the plane with tethered flyfishing line (line floats on water with attached bobbers at 3-4 feet intervals) Then slowly pull the Donald back to shore. (I may also be able to just push the plane in directly...??) Anyway, I finished my home-made air-boat and it handles great and has a run time (7.2V NiMH) of around 20-25min. I’ve enclosed a picture of the "Rescue" craft. PS Notice the "dual tupperware" chambers, one for the NiMH battery and the other for the servo/circuit board. I've never had to "BURP" a R/C craft before.... --Kevin |
Retrieval?
Hi Kevin4,
Your retrieval craft looks promising. We built a couple of flat bottomed barge type hulls from RCM plans back in the early 70s and had a ball putt-putting around the farm pond sitting under an oak tree sipping cool ones while the 30 min epoxy was drying back at the house. I started to lay out a barge type of hull, but this time instead of air props, I figured maybe an inboard E-Motor with Forward and Reverse control. would be better. Forward would get it out to the plane, and Reverse would allow it to back in between the pontoons. I figured to secure a long stiff wire off the stern with a hook and a one to two inch hook on the end. Back in under the nose until the hook hit the pontoon crossbar. A little more power would cause it to ride up and over coming down behind it. Forward motor would snug it up and then the plane could be towed in. Sounds feasible but I have no experience with inboard E-motors and submerged props. That calls for a little more investigating unless some guys have some rhoughts on usable motors and throttles and such. Maybe Hobby Lobby is a good place to seek help. |
Retrieval?
1 Attachment(s)
Kevin,
Cool job on the boat. I hope it works for you. R/C Boats "sound" like a good idea but I think Grampaw hit on some of the "challenges" to resolve. 1. you're working at a distance. depth perception is not very accurate, and it's difficult to place the boat relative to the plane. 2. If you hook the plane with the boat, you'll probably be off-center. the boat better have POWERFUL steering capability to be able to drag a crooked airplane in a straight line. 3. If the airplane is other than upright or is damaged, dragging it with the R/C boat can cause additional damage 4. Lost parts get REALLY lost. We have fooled around with R/C boats for retrieval in the FLFLFL, and relegated them about ninth out of four choices in order of usefulness. They SOUND like a good idea, but making it work is so complicated it's just easier to drain the pond. In order of percentage of events that the method will work: (my estimate-not scientific data) 1. Man-Carrying boat : 99% 2. Fishing pole to cast over the plane and pull it in: 30-40% 3. Long pole with a big hooked end: 10-15% 4. Radio-Controlled boat: 10% maybe You can ALWAYS go for a boat-ride and get the plane, unless it's in a tree or "missing", and I have needed the boat to get to the tree. Sometimes, you can cast out and snag one: we use a large torpedo float and a one-ounce egg weight, (no hook)and we can cast about 75 yards. Airplanes are very "Snaggable", and it is rare that the line slides off once we start to pull the plane (gently). For the planes that quit while taxiing out or in, or if a deadstick can be landed pretty close, a long pole with a shepherd's crook is handy. Last time we experimented with the R/C boat, we got the towline wrapped up in the prop and had to go get both the boat AND the plane. :rolleyes: |
Retrieval?
Jim, you touched on some very good points, and the survey is very enlightening. I am the only one in our club at this point that's interested in water flying, but that could change if just one plane gets going, as you probably know.
The retrieval of a stalled plane out on the water is my no. one cencern at present. They do quit in the damdest places, and I don't swim too well above water. The boat was an idea that appeared fair to start with, but once I played it out in my mind I came to same conclusion you mentioned about getting the plane secured in a proper position for towing, especially from any distance away that makes a good visual a bit dicey. If others show any interest, maybe one will have a small boat or dingy we can use. One of those "peddle boats" you use foot power on would work. We have lots of Commercial Crawfish Ponds around this area, but the farmers take a dim view of distrubing those precious creatures. Even a three foot deep body of water about ten foot wide would be great. I have a horse pasture that I may be able to convince the wife and kids...aw stop dreaming GP! |
Retrieval?
Just so nobody thinks I'm a scroogy ol' grouch, there is ONE technique we have found that works with an R/C boat. I am NOT "Mr. Negative"
Attach the fishing line from a Rod and Reel to the boat. Drive the boat past the plane and make a broad sweeping "U" turn behind the plane. When the line catches the plane, use the fishing reel to pull it in. THe Boat driver can pull, too, but he should stay far enough from the plane that he still has maneuvering room. If the boat has a problem, it is still retrieved by the fishing reel. |
Retrieval?
You're not grumpy or grouchy, you've just done this long enough to know what doesn't work. ;)
Wanna start a curmudgeon's club here? :D --Bill |
Retrieval?
It's an occupational hazard of engineers, sitting around growling "Aww we already tried that, it won't work!"
Then some smart-alecky kid comes along and makes it work anyway. |
Retrieval?
Grampaw,
As wet as cajunland is, you should have no trouble finding a place to fly floaties. Even a low spot in a field after a good rainstorm will work. You only need a couple of inches of water. For a boat, a bateau or jon-boat works great. I had one of those Coleman plastic 12' jon-boats with a trolling motor and it was near ideal. A canoe would work if you can reach over the side and lift the plane in without tipping the boat. If you are in bigger water, a bass boat or a pontoon boat would be cool. You just have to go slow with the bass boat or the plane will blow around when you're carrying it and not flying it. I had an 18' runabout that was not very good for flying from because the freeboard was too high and it was uncomfortable reaching the water to lift the plane. You could host the Lake Ponchartrain float-fly and Crawfish Festival. |
Retrieval?
Hey Jim ....aside from the gator thing (I live near Lake Tarpon), any experience with a small inflatable (mini-liferaft)?
| All times are GMT -8. The time now is 05:47 AM. |
